Im looking at a 2005, I would like to have all the info I can get my hands on. Thanks in advance.
1FTWW31P85EA82950
Thanks
Andy
Ford OEM Parts Supplier
OASIS RESULT:
1FTWW31P85EA82950
USA
EN
04/26/2010
08:05:29
FCXWS446
© Copyright 2002-2010 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
PAINT COLOR
EBONY WB C/C-W/B RADIO
AM/FM STRO/CD CHANGER/CLK GROSS VEHICLE WEIGHT
11,400 LB. GVW
AXLE RATIO
3.73 FINAL DRIVE RATIO WHEEL SIZE
8X18" FORGED POLISHED ALU WHL FRONT TIRE
LT 275/70R18E A/T OWL
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
Click here for CUDL
P05 MULTIPLE REPAIR VISIT POLICY DOES NOT APPLY TO CLP REPAIRS
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
INSTALL 6A642-CA KIT WHEN REPLACING EGR COOLER UNDER 09-08-03
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/16/2005 BUILD DATE
09/26/2004 SALE MILEAGE
New Vehicle Base Warranty
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0968 - USA 2007 NEW 84/200,000 DIESELCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 0 USD
OWNER NAME: BRADLEY BJERKE
OPTIONS:
EXPIRATION DATE: 02/16/2012
DISTANCE: 200,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 09757
ESP CONTRACT START DATE: 02/16/2005
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
08/19/2009
DEALER: Luther Family Ford
WARRANTY CLAIM NUMBER: 214691 ODOMETER: 136115M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9B246E KIT-FUEL SYSTEM SERV 001 081806C 42 DOES NOT OPERATE PROPERLY
W302725 001 081806D
W300020 001 081806B
5C3Z 9C968CA FUEL PRESSURE REG 001
Standard Claims List For Model Year 2005
1FTWW31P85EA82950 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-SEP-2004 16-FEB-2005 158633 USA 3 3A11 070100 5C3Z 7000 KB L73 42 13578
AWS Claim Key: 998860 Trx Code: E84 Labor Hrs: 9.6
Dlr Cd-Sub Cd: 09572 - * Name: HOLT MOTORS, INC. Ph: 320-2862176 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2005 Doc #:02289851
Cust Comments: CUSTOMER STATES VEHICLE LEAKS TRANSMISSION FLUID, LEAVES A BIG PUDDLE OF FLUID ON GROUND, TRANSMISSION IS SLIPPING
Tech Comments: DOES NOT OPERATE PROPERLY EEC (QUICK TEST) DIAGNOSIS, AUTOMATIC TRANSMISSION EXTERNAL OIL LEAKS DIAGNOSIS, REPLACE TRANS WITH REMAN UNIT, MOUNT TRANS ON BENCH FIXTURE, FLUSH COOLER LINES, REPLACE AUTO TRANS OIL COOLER, INSTALL INLINE FILTER KIT, TIME NEEDED TO DIS ASSEMBLE UNIT DO COST CAP, RE ASSEMBLE CORE, FLUSH COOLER LINES, RECHECK OK
1FTWW31P85EA82950 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-SEP-2004 16-FEB-2005 158633 USA 4 3A15 070100 3C3Z 7H103 AA A85 01 13579
AWS Claim Key: 988889 Trx Code: E91 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 09572 - * Name: HOLT MOTORS, INC. Ph: 320-2862176 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:19-MAY-2005 Doc #:02298451
Cust Comments: OUTPUT SHAFT SPEED SENSOR BROKEN ON NEW TRANSMISSION
Tech Comments: BROKEN CRACKED REMOVE BROKEN OSS SENSOR AND INSTALL A NEW OSS SENSOR, RECHECK OK
1FTWW31P85EA82950 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-SEP-2004 16-FEB-2005 158633 USA 12 * * * * * * * 21677
AWS Claim Key: 3328788 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09572 - * Name: HOLT MOTORS, INC. Ph: 320-2862176 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2006 Doc #:02956452
Cust Comments: 59B01 PROGRAM ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE
Tech Comments: OTHER CUSTOMER ASSURANCE TEST DRIVE PER FORD PROGRAM
AWS Claim Key: 3328789 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09572 - * Name: HOLT MOTORS, INC. Ph: 320-2862176 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2006 Doc #:02956453
Cust Comments: 05B32 RECALL DEGAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: OTHER INSTALL LABEL AND, IF NECESSARY, REMOVE FLUID PER FORD PROGRAM
AWS Claim Key: 3328787 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 09572 - * Name: HOLT MOTORS, INC. Ph: 320-2862176 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2006 Doc #:02956451
Cust Comments: 05E15 RECALL EXHAUST PRESSURE SENSOR REPLACEMENT
Tech Comments: OTHER REPLACE EXHAUST PRESSURE (EP) SENSOR AND RECALIBRATE CONTROL MODULES PER FORD RECALL
1FTWW31P85EA82950 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-SEP-2004 16-FEB-2005 158633 USA 13 2H01 030008 5C3Z 6K682 CA D42 42 25758
AWS Claim Key: 3816503 Trx Code: S07 Labor Hrs: 6
Dlr Cd-Sub Cd: 09572 - * Name: HOLT MOTORS, INC. Ph: 320-2862176 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:20-FEB-2006 Doc #:03018551
Cust Comments: CUSTOMER STATES THERE IS NO BOOST AT TIMES AND POOR POWER, SURGES THEN BOOST GOES UP AND DOWN AT TIMES
Tech Comments: DOES NOT OPERATE PROPERLY ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS, KEY ON ENGINE OFF KOEO CHECK TEST CODES P0299, P0404, P0478, TEST BOOST PRESSURE OK, CHECK FUEL PRESSURE, CHECK EGR POSITION, TEST VGT, REPLACE EGR VALVE, RECHECK BETTER BUT STILL HAS INTERMITTENT POOR POWER, REPLACE TURBO CHARGER ASSEMBLY WAS STICKING, RETEST AND RECHECK OK
1FTWW31P85EA82950 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-SEP-2004 16-FEB-2005 158633 USA 13 1F06 030304 F6DZ 8100 A L87 42 25758
AWS Claim Key: 3816504 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 09572 - * Name: HOLT MOTORS, INC. Ph: 320-2862176 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:20-FEB-2006 Doc #:03018554
Cust Comments: CUST STATES VEHICLE LOOSES COOLANT AT TIMES, TEMP GAUGE GOES UP
Tech Comments: DOES NOT OPERATE PROPERLY PRESSURE TEST COOLING SYSTEM CHECK FOR LEAKS DIAGNOSE, REPLACE RADIATOR CAP, RECHECK OK, EXTRA TIME NEEDED TO CHECK FOR COOLANT LEAK AND CHECK FOR BAD HEAD GASKETS
1FTWW31P85EA82950 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-SEP-2004 16-FEB-2005 158633 USA 13 1H05 03XXXX 3C3Z 6766 CA L65 42 25788
AWS Claim Key: 3816505 Trx Code: S07 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 09572 - * Name: HOLT MOTORS, INC. Ph: 320-2862176 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2006 Doc #:03023351
Cust Comments: CUST STATES MOTOR LEAKS OIL
Tech Comments: DOES NOT OPERATE PROPERLY CHECK FOR LEAK ADD DYE, CHECK FOR LEAK WITH BLACK LIGHT DIAGNOSE, REPLACE OIL FILTER CAP WONT SEAL PROPER, DEGREASE MOTOR AND WASH OFF AS NECESSARY, RECHECK OK
1FTWW31P85EA82950 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-SEP-2004 16-FEB-2005 158633 USA 27 1A02 030102 * 6051 * L87 42 39985
AWS Claim Key: 7637644 Trx Code: E72 Labor Hrs: 9.8
Dlr Cd-Sub Cd: 09757 - * Name: LUTHER FAMILY FORD Ph: 701-2822350 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:23-APR-2007 Doc #:129856A
Cust Comments: CUSTOMER STATES HE HAS HAD TO ADD COOLANT TWICE, ABOUT A GALLON EACH TIME
Tech Comments: 40008 PREFOMRED DIAGNOSIS PER TSB 06 21 2 SPEPS 1 7 FOUND EGR COOLER LEAKING INTERNALLY ALSO FOUND OIL COOLER RESTRICTED REPLACE EGR COOLER ALSO REPLACE OIL COOLER CLEAN OUT EXCESSIVE STICKY CARBON INSIDE INTAKE MANIFOLD FROM LEAKING EGR COOLER CLEAN TURBO AND EXHAUST DOWN PIPE FROM SAME DEBRIS REASSAMBLE REFILL WITH NEW COOLANT CHANGE OIL AND FILTER ROAD TEST ENGINE SURGES EEC
1FTWW31P85EA82950 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-SEP-2004 16-FEB-2005 158633 USA 27 7B02 140201 * 10346 * G29 42 41504
AWS Claim Key: 7807138 Trx Code: P05 Labor Hrs: 0
Dlr Cd-Sub Cd: 09572 - * Name: HOLT MOTORS, INC. Ph: 320-2862176 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:04-MAY-2007 Doc #:00831701
Cust Comments: CUSTOMER STATES THE BATTERY LIGHT WAS ON CUSTOMER REFUND FOR $547.94 FOR REPLACEMENT OF ALTERNATOR AND CABLE
Tech Comments: DOES NOT OPERATE PROPERLY SEE INVOICE NO. 131183 FROM LUTHER FORD, DATED 5 4 07 FOR $547.94
1FTWW31P85EA82950 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-SEP-2004 16-FEB-2005 158633 USA 29 1A02 030102 * 6051 * L87 42 47945
AWS Claim Key: 8077745 Trx Code: E72 Labor Hrs: 21.5
Dlr Cd-Sub Cd: 09757 - * Name: LUTHER FAMILY FORD Ph: 701-2822350 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:21-JUN-2007 Doc #:135920A
Cust Comments: C S: HE IS HAVING TO KEEP ADDING COOLANT, ABOUT A 1 4 OF A GALLON IN A WEEKS TIME
Tech Comments: 47968 PREFOMRED DIAGNOSIS PER TSB 06 21 2 STEPS 1 7 INCLUDING EEC CK KOEO KOER PID DATA MONITORING BOOST TEST COOLING SYSTEM PRESSURE TEST REMOVE EGR VALVE INSPECT FOR COOLANT IN INTAKE NONE FOUND HOOK UP PRESSURE GAUGE INTO COOLING SYTEM ROAD TEST EXCESSIVE PRESSURE PREFOMRED C COMPRESSION TEST REMOVE CYL HEADS FOUND GASKETS LEAKING CYL 3,5,2,4,6,HEAVY CARBON LIKE MATERIAL
1FTWW31P85EA82950 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-SEP-2004 16-FEB-2005 158633 USA 31 7T03 061003 6C3Z 2C006 AA A85 42 56825
AWS Claim Key: 8514908 Trx Code: P05 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09757 - * Name: LUTHER FAMILY FORD Ph: 701-2822350 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2007 Doc #:143353A
Cust Comments: CUSTOMER STATES THE MESSAGE CENTER READOUT SHOWS TRAILER DISCONNECT FAULT
Tech Comments: 56825 R150 HOOKED UP SCAN TOOL RAN SELF TEST B1342 BAD TBC MODULE R AND R TRAILER BRAKE CONTROL MODULE
1FTWW31P85EA82950 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-SEP-2004 16-FEB-2005 158633 USA 36 2E03 0304XX 4C3Z 9E527 AA D42 42 73094
AWS Claim Key: 9226677 Trx Code: S07 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 09757 - * Name: LUTHER FAMILY FORD Ph: 701-2822350 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:04-JAN-2008 Doc #:156095A
Cust Comments: CUSTOMER STATES THE VEHICLE IS RUNNING ROUGH, JUST HAD FILTERS CHANGED AND THAT DIDNT HELP
Tech Comments: 73104 PREFOMRED DIESEL ENGINE PERFORMANCE DIAGNOSIS PER PCED MANUAL CODES 263 281 284 528 CHECK MAINTAINCE OK POWER BALANCE TEST MISSING CYL 1,3,5,7 ROAD TEST CHECK FUEL PRESSURE WAS GOOD 47PSI PREFOMRED RELATIVE COMPRESSION TEST WAS OK PREFOMRED CRANKCASE PRESSURE TEST WAS OK PER PINPOINT TESTS P1 P15 REPLACE 4 INJECTORS 1,3,5,7 RIGHT SIDE REASSAMBLE CLEAR CODES ROAD
1FTWW31P85EA82950 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-SEP-2004 16-FEB-2005 158633 USA 55 2E01 030408 4C3Z 9B246 E D02 42 136115
AWS Claim Key: 11128485 Trx Code: 0968D Labor Hrs: 8
Dlr Cd-Sub Cd: 09757 - * Name: LUTHER FAMILY FORD Ph: 701-2822350 St:ND Ctry Cd: USA Reg Cd: NA Repr Date:19-AUG-2009 Doc #:214691A
Cust Comments: CUSTOMER STATES THE VEHICLE IS HARD TO START AT TIMES, WILL CRANK OVER A LONG TIME BEFORE IT STARTS, HAPPENS OCCOSIONALLY
Tech Comments: 136115 EEC CK CODES P2291 P2290 PREFOMRED DIAGNOSIS PER TSB 08 18 6 GRAPH HARD START USING DATALOGGER LEAK CHECK HEAR LEAK REMOVE HIGH PRESSURE PUMP COVER FOUND STC CONNECTOR LEAKING REPLACE STC CONNECTOR REINSTALL PUMP RECK FOR LEAKS HEAR LARGER THAN NORMAL LEAK FROM IPR DRAIN WHEN CLOSING IPR VALVE HEAR CHANGE BUT STILL HAVE LARGE LEAK REPLACE IPR VALVE RECK FOR LEAKS DOING
