Don't know if this can be done on an Escape, but i found one i was interested in and would like to know of any work done on it.
The vin is: 1FMCU96H85KC53285
Thank you in advance for your time and I do appreciate and welcome any comments.
OASIS RESULT: 1FMCU96H85KC53285 USA: EN 16-JANUARY-2013 / 04:18:43 EST/ APP1
Local Time: 16-JANUARY-2013 / 2:18:47 AM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2005 ESCAPE HYBRID
BODY STYLE: 4WD
ENGINE: 2.3LI4 16v Gas/Electric DOHC Hybrid
TRANSMISSION: CVT Auto Trans Powersplit Elec
AXLE CODE: AA
ENGINE CALIBRATION: 5M61AH0A
PAINT COLOR: Oxford White Solid C/C
PAINT CODE: YZ
RADIO: AM/FM Stereo/6 CD/Navigation System
AXLE RATIO WHEEL SIZE: 7J x 16" 5 Spoke Aluminium Wheel
FRONT TIRE: P235/70R-16T BSW A-S
GROSS VEHICLE WEIGHT: 4720 LB. GVW
WARNING MESSAGES
VERIFY STATE REGISTRATION, VIN MAY BE ELIGIBLE FOR 15/150 CALIF PZEV EMISS WTY
CLAIMS:
Customer Concern Code
B43-LOOSE, POOR FIT, WARPED, WRINKLED-DOOR TRIM PANEL
Condition Code 33-LOOSE PART
Technician Comment FELL OFF REPLACE RUBBER STOPS
Customer Comment:CUST. STATES RUBBER STOP ON DRIVERS DOOR FELL OFF.
Condition Code 34-DISTORTED/WRINKLED/WAVY
Technician Comment RUSTED MTIME TO REMOVE DOOR PANELS TO REPLACE DOOR BRKS
Customer Comment CUST. STATES DOOR BRAKES ON BOTH SIDES ARE SEVERELY RUSTED
S39-AIR BAG WARNING LIGHT TROUBLES
Condition Code 42-DOES NOT OPERATE PROPERLY
Technician Comment ABS DIAGNOSIS... NECESSARY TO PULL CODES DUE TO ABS LIGHT AND BRK LIGHT PRESENTRECIEVED CODES C1475...SPOKE WITH HOTLINE. NEEDED TO REPLACE HECU AND BLEED SYSTEM....BLEED SYSTEM WITH NEW BLEEDER SUPPLIED...NECEESARY TO BLEED 3 TIMES TO CONTAIN ABS LIGHT...TEST DROVE BRK LIGHT STILL ON..NECESARY TO RETEST SYSTEM AND BLEED AGAIN DUE TO MANAGEMENT TAKING ME OFF VEHICLE IN THE MIDDLE OF ANOTHER BLEED
Customer Comment CUST. STATES ABS LIGHT AND RED BRAKE LIGHT ON. VEHICLE DOESNT SEEM TO BE CHARGING WITH THESE LIGHTS ON. ADVISE
S40-OTHER RESTRAINT TROUBLES
Technician Comment CK N VERIFIED CONERN. R N R L SIDE B PILLAR 2 ACC. REPLACED LF SEAT BELT RETRACTOR
Customer Comment CUSTOMER STATES DRIVER SEATBELT CONNECTOR KEEPS SLIDING TO BOTTOM SOP PART IN
D11-ENGINE IDLES TOO FAST
Technician Comment VERFIY CHECK ENG LIGHT ON HOOK UP IDS TEST EEC CODE P1AOF P1AOF TEST MONITOR PIDS ALL READINGS ARE WITHIN RANGE PINPOINT TEST TO COOLIN PUMP FOUND LOW OUTPUT REPLACE RETEST ROAD TEST OK
Customer Comment CUSTOMER STATES ENGINE RACING AT IDLE IN PARK AND IN DRIVE,DOES NOT GO TO BATTERY WHEN STOPPED AND ENGINE DIED TWICE. DIAGNOSE AND REPORT
Customer Concern Code *-N/A
Condition Code *-[N/A]
Technician Comment RECALL INSTALL JUMPER HARNES
Customer Comment 07B48 SERVICE HARNESS INSTALLATION
Customer Concern Code C02-A/C NOT COLD ENOUGH
Technician Comment TEST AC SYSTEM FOUND BOTH GAUGES READING WRONG WHEN AC IS ON GAUGES 60 PSI LOW 100 PSI HIGH FOUND AC COMPRESSOR METAL FLAKES IN LINES AC DOES NOT BLOW COLD SOMETHING BROKE INSIDE AC COMPRESSOR. REPLACE COMPRESSOR AND FLUSH AC SYSTEM CONDITION CORRECTED AFTER REPAIRS MADE 32 LOW 200 HIGH DUCT TEMP 48 DEG
Customer Comment CUSTOMER STATES THE A C ISNT REAL COLD S O COMPRESSOR 100.00 DEDUCTIBLE
