OASIS RESULT: 1FTSW21P95ED34858 USA: EN 22-JANUARY-2013 / 00:47:06 EST/ APP2
Local Time: 21-JANUARY-2013 / 10:47:12 PM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2005 F-SERIES
BODY STYLE: F-250 CREW CAB 4X4
ENGINE: 6.0L OHV Diesel V8
TRANSMISSION: M6HD-W 6 Speed Manual Transmission
AXLE CODE: 3L
ENGINE CALIBRATION
PAINT COLOR: Dark Green Satin WB
PAINT CODE: FW
RADIO: With AM/FM CD Player
AXLE RATIO: 3.73 Ratio
WHEEL SIZE: 7.5 X 17 Polished Alum Wheel
FRONT TIRE: LT265/70/R17E A/T BSW
GROSS VEHICLE WEIGHT: 10,000 LB. GVW
CLAIMS:
Customer Comments CUSTOMER STATES PERFORM OUTSTANDING FIELD SERVICE ACTIONS 05B35 ENGINE CONTROL MODULES RECALIBRATION
Tech Comments RECALIBRATE CONTROL MODULES
Customer Comments CUSTOMER STATES PERFORM OUTSTANDING FIELD SERVICE ACTIONS 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments INSTALL LABEL AND, IF NECESSARY, REMOVE FLUID
Customer Comments CUSTOMER STATES CK SPEEDOMETER QUITS WORKING AT TIMES SEEMS WORSE IN COLD TEMPATURES
Tech Comments RAN ABS SELF TEST AND CLUSTER TEST PASSED NO CODES CK OASIS CK G105 PER SSM 18445 OK REM INSTURMENT CLUSTER TRIM PANEL REPL INSTRUMENT CLUSTER PROGRAM AND CK OPERATION
Customer Comments CUSTOMER STATES CK BOTH REAR DOOR MOULDINGS ARE LOOSE
Tech Comments CK BOTH REAR DOOR MOULDINGS COMING OFF APE WAS LOOSE REM MOULINDGS REM TAPE AND REAPPLY TAPE AND REATTACH MOULDINGS
Customer Comments CUSTOMER STATES CK EMERGENCY BRAKE WILL NOT SET HAVE TO PUSH PEDAL SEVERAL TIMES
Tech Comments CK E BRAKE ASSY WOULD RATCHET ALL THE WAY DOWN MOST OF THE TIME REP E BRAKE PEDAL ASSSY TEST E BRAKE OK
Customer Comments CUSTOMER STATES REPAIR LICENSE PLATE LIGHTS
Tech Comments CK AND REPL BULB
Customer Comments CUSTOMER STATES CK EXHAUST LEAK FROM ENGINE COMPARTMENT SMELLS INSIDE VEHICLE
Tech Comments CK FOR EXHAUST SMELL IN CAB INSPECT EXHAUST CK OASIS AND REPL EXHAUST MANIFOLD GASKETS PER TSB INSTRUCTIONS 05 13 9
