I am a new user to this site, I purchased a 2007 F250 SD 6.0 2 months ago. I am beginning to see signs of puking while towing and want to learn the history of the vehicle. I am looking for the OASIS report fir the vehicle, my VIN is 1FTSW21PX7EB11098. Any help would be appreciated.
OASIS RESULT: 1FTSW21PX7EB11098 USA: EN 16-JANUARY-2013 / 05:38:20 EST/ APP2
Local Time: 16-JANUARY-2013 / 3:38:25 AM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2007 F-SERIES
BODY STYLE: F-250 CREW CAB 4X4
ENGINE: 6.0L OHV Diesel V8
TRANSMISSION: 5 Speed Auto 5R110W - HI/Torque
AXLE CODE: 3L
ENGINE CALIBRATION: 6F710H0A
PAINT COLOR: Dark Toreador WB
PAINT CODE: JM
RADIO: With AM/FM CD Player
AXLE RATIO: 3.73 Ratio
WHEEL SIZE: 7.5 X 17 Polished Alum Wheel
FRONT TIRE: LT265/70/R17E A/T OWL
GROSS VEHICLE WEIGHT: 10,000 LB. GVW
CLAIMS:
Customer Comments CUSTOMER STATES CHECK ENGINE LIGHT IS ON
Tech Comments CHECK DIAGNOSTIC TROUBLE CODES, REPLACE THE EGR VALVE
Customer Comments CUSTOMER STATES CHECK FOR SFRT END SHIMMY WHEN GOING OVER ROUGH SURFACES AT HIGHWAY SPEEDS
Tech Comments DOES NOT OPERATE PROPERLY PERFORMED REPAIR PER TSB# 071010B
Customer Comments CUSTOMER STATES CHECK FOR REAR END LEAK
Tech Comments FAILED SEAL OIL SEAL REAR AXLE DRIVE PINION SEAL REPLACE
Customer Comments CUSTOMER STATES NO POWER AND BLOWS BLACK SMOKE. WORSE AFTER CLIMBING HILL OR UNDER LOAD.
Tech Comments ROAD TEST NO PWR BLOWING BLACK SMOKE TEST SYSTEM, FUEL PASS CYL BAL PASS INTAKE OK EXHUAST NOT RESTRICTED FUEL AERATION OK RR EGR VALVE AND REPLACE PERF EGR TESTING PASS REOAD TEST STILL LOW PWR ONLY 16PSI BOOST RR TURBO ASSY VANES COKED UP CLEAN TURBO REASSY ROAD TEST RETEST OK
Customer Comments TOWED TO SHOP WAS LOOSING COOLANT AND RUNNING ROUGH NOW WONT TURN OVER DIAG AND ADVISE
Tech Comments CK FOR NO START COOLANT EMPTY EG HYDROLOCKED HAD TO REMOVE GLOW PLUGS TO GET ENG TO CRANK PRESS TEST FOUND EGR COOLER LEAKING AND OIL COOLER PLUGGED TEMP 21 REPL COOLER AND EGR RECONDITION TURBO VANES COKED UP FLUSH SYSTEM RETEST OK
Customer Comments BLOWING BLACK SMOKE NO POWER NO CHECK ENGINE LIGHT ON
Tech Comments RUNS ROUGH VERIFIED ENGINE RUNS ROUGH AFTER COLD SOAK FOUND RANDOM MISFIRE AFTER COLD START. PERFORMED SELF TEST NO DTC CHECKED FUEL PRESSURE 45 PSI RAN OASIS FOUND TSB 09 24 3. UPDATED PCM PER TSB 09 24 3 RETESTED AFTER COLD SOAK NO MISFIRE ROAD TESTED FOR CUSTOMER CONCERN FOR LACK OF POWER AND BLACK SMOKE UNABLE TO DUPLICATE PERFORMED IDS EGR TEST AND TURBO VVT TEST PASS TURBO BOOST TEST PASS
