kinda bad to be making my first post a request, but hey :blah:
here's the VIN: 1FTNX21F1XEC70996
thanks for the help
Sky
OASIS RESULT:
1FTNX21F1XEC70996
See bottom of the OASIS result for contact ID
02/01/2006
18:49:07
VEHICLE INFORMATION
VEHICLE DESCRIPTION
1999 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
ZF M6HD-C 6-SPEED AXLE CODE
C1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/19/1999 BUILD DATE
11/06/1998 SALE MILEAGE
00457
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
1FTNX21F1XEC70996 T/F7 * T/BD T/BD T/E A1 T/VF T/DS 06-NOV-1998 19-JUN-1999 174440 USA 0 * * * * * * * 10
AWS Claim Key: 955636 Trx Code: 98B32 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08622 - * Name: NORTHSIDE TRUCKS & EQUIPMENT Ph: 503-2827773 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:01-FEB-1999 Doc #:041977A
Cust Comments: PERFORM 98B32
1FTNX21F1XEC70996 T/F7 * T/BD T/BD T/E A1 T/VF T/DS 06-NOV-1998 19-JUN-1999 174440 USA 2 2A01 031201 XC3Z 9K635 AA D21 49 4019
AWS Claim Key: 3725256 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 00471 - * Name: COLUMBIA CENTER FORD, INC. Ph: 509-7352511 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:13-AUG-1999 Doc #:103539A
1FTNX21F1XEC70996 T/F7 * T/BD T/BD T/E A1 T/VF T/DS 06-NOV-1998 19-JUN-1999 174440 USA 2 6P04 010301 * 2820125 * B09 33 4019
AWS Claim Key: 3725257 Trx Code: 2 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 00471 - * Name: COLUMBIA CENTER FORD, INC. Ph: 509-7352511 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:13-AUG-1999 Doc #:103539B
Tech Comments: CHKD FOR NOISE,REMVD DOOR PANEL,FOUND LOOSE CONNECTOR IN DOOR,SECURED AND VERIFIED REPAIR.
1FTNX21F1XEC70996 T/F7 * T/BD T/BD T/E A1 T/VF T/DS 06-NOV-1998 19-JUN-1999 174440 USA 2 5B03 050301 F81Z 1175 HA N50 D8 4019
AWS Claim Key: 3725258 Trx Code: 2 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 00471 - * Name: COLUMBIA CENTER FORD, INC. Ph: 509-7352511 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:13-AUG-1999 Doc #:103539C
Tech Comments: AXLE DUST SHEILDS NOISY,REMVD,BOTH FRT AXLESHAFTS,REPLCD SEALS,LUBRICATED W/ HIGH TEMP 4X4 GREASE.VERFIED REPAIR. NO LAB OPS AVAILABLE.
1FTNX21F1XEC70996 T/F7 * T/BD T/BD T/E A1 T/VF T/DS 06-NOV-1998 19-JUN-1999 174440 USA 6 6Y21 * * * * ** * 12089
AWS Claim Key: 5850781 Trx Code: 99S11 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 00471 - * Name: COLUMBIA CENTER FORD, INC. Ph: 509-7352511 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:30-NOV-1999 Doc #:106878A
1FTNX21F1XEC70996 T/F7 * T/BD T/BD T/E A1 T/VF T/DS 06-NOV-1998 19-JUN-1999 174440 USA 13 6P06 010301 * 2820125 * B05 42 28346
AWS Claim Key: 10422310 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 00471 - * Name: COLUMBIA CENTER FORD, INC. Ph: 509-7352511 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:05-JUL-2000 Doc #:113444A
Tech Comments: RR DOOR UNABLE TO OPEN,FOUND CLOGGED WITH DIRT.CLEANED,LUBED,ALL 4 DOOR LATCHES,VERIFIED OPPERATION.
1FTNX21F1XEC70996 T/F7 * T/BD T/BD T/E A1 T/VF T/DS 06-NOV-1998 19-JUN-1999 174440 USA 13 6H06 011108 XC3Z 2523201 BB G07 42 28346
AWS Claim Key: 10422311 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00471 - * Name: COLUMBIA CENTER FORD, INC. Ph: 509-7352511 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:05-JUL-2000 Doc #:113444C
1FTNX21F1XEC70996 T/F7 * T/BD T/BD T/E A1 T/VF T/DS 06-NOV-1998 19-JUN-1999 174440 USA 13 7W05 170503 XF1Z 10B987 AA L19 41 28346
AWS Claim Key: 10422312 Trx Code: E83 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 00471 - * Name: COLUMBIA CENTER FORD, INC. Ph: 509-7352511 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:05-JUL-2000 Doc #:113444D
Tech Comments: VERIFIED DOOR AJAR LIGHT ON,RAN DIAG,FOUND LF DOOR AJAR SWITCH STICKING.R&R SWITCH,VERIFIED REPAIRS.
1FTNX21F1XEC70996 T/F7 * T/BD T/BD T/E A1 T/VF T/DS 06-NOV-1998 19-JUN-1999 174440 USA 13 7H06 120300 * 19700 * C05 42 28346
AWS Claim Key: 10422313 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 00471 - * Name: COLUMBIA CENTER FORD, INC. Ph: 509-7352511 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:05-JUL-2000 Doc #:113444F
1FTNX21F1XEC70996 T/F7 * T/BD T/BD T/E A1 T/VF T/DS 06-NOV-1998 19-JUN-1999 174440 USA 23 4A02 031103 YC3Z 6375 DA D50 87 47487
AWS Claim Key: 15685217 Trx Code: E72 Labor Hrs: 4.8
Dlr Cd-Sub Cd: 08631 - * Name: TOM DENCHEL FORD COUNTRY INC Ph: 509-7862155 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:18-APR-2001 Doc #:00976551
Cust Comments: CUSTOMER STATES VEHICLE MAKES NOISE WHEN STARTING
Tech Comments: RING GEAR NOT FULLY SEATED, STARTER CHECK, STARTER MOTOR R+R, MANUAL TRANSMISSION R+R, FLYWHELL R+R
1FTNX21F1XEC70996 T/F7 * T/BD T/BD T/E A1 T/VF T/DS 06-NOV-1998 19-JUN-1999 174440 USA 34 2E01 030008 F81Z 9E527 BRM E29 42 66743
AWS Claim Key: 20466286 Trx Code: E72 Labor Hrs: 6.1
Dlr Cd-Sub Cd: 08631 - * Name: TOM DENCHEL FORD COUNTRY INC Ph: 509-7862155 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:06-MAR-2002 Doc #:01663251
Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT ON
Tech Comments: EEC TEST PINTEST BAD EBP RR EBP ENGINE MISSFIRE CYL INJ TEST CYL 7 BALANCE FAIL RR VALVE COVER PINTEST 7 INJ RR INJ AS PER PINTEST NA26 RR 7 INJ RETEST P1293 ELEC TEST WIGGLED SHORT HARNESS CONN AT VALVE COVER GASKET GOOD CONT WHEN CONN WAS FORCED DOWN BAD SHORT HARNESS RR VALVE COVER GASKET SHORT HARNESS ASSY REPLACE SHORT HARNESS IN VALVE COVER GASKET RETEST PURGED AIR FROM OIL AND FUEL SYSTEM
1FTNX21F1XEC70996 T/F7 * T/BD T/BD T/E A1 T/VF T/DS 06-NOV-1998 19-JUN-1999 174440 USA 47 1G02 030008 F81Z 8501 ARM L87 42 89303
AWS Claim Key: 22311331 Trx Code: E72 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 08514 - * Name: DIEHL FORD Ph: 360-7342640 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:21-APR-2003 Doc #:12549901
Cust Comments: CUST STATES COOLANT LEAKAGE FRT OF ENGINE AREA
Tech Comments: PRESSURE TEST COOLING SYSTEM. WATER LEAKING FROM PUMP. REPLACE LEAKING WATER PUMP
I guess I'll be next. I don'e know if my truck is too old but it would be nice to know it's history.
1EF1S2929X2953848
Thanks
Tim
Ok, heres mine
1ftww32f9xed31121
Hey thanks man I really appreciate it....
