I was just thinking of installing my double deep trans pan, but I don't know how much ATF that holds. Can anyone help me with this one? I can call Mag-Hytec tomorrow, but they aren't open today. Thanks,
yeah, I figured that, I was just trying to gauge how much to buy. A buddy of mine said that his 96 took 13 quarts, which seemed quite a bit high to me. So I guess I'll just pick up a case and go from there.
Thanks,
If you work fast,you might be able to get by with a case.I preffer to loosen the VB or let it drain for a while if you dont have a TC drain plug.You will likely need 13-16 if you drain the tc too.
I was pretty much planning on draining the TC as well, just so all of my fluid is fresh. What is the procedure for refilling the TC, I'm not really transmission Savvy, but I figure this can't be that difficult.
B
Dodge TQ do not have a drain plug. The easiest way I know is drain the pan, change the filter, put it back together, etc. Measure how much fluid you got out and subtract it from the amount your sytem holds. That is how many is left in the TQ. Put the amount you took out, plus the 4 quarts for the new pan. Then unhook the supply line to your transmission cooler and stick it in a gallon jug. Have someone start the truck and put it in neutral. Catch however many quarts are supposed to be left in the TQ as it will pump it out, shut the truck off, and hook the cooler line back up. Then add what's left of your new fluid and top off.
Might not be the best way or the recommended way, but that's how we do it around here when no TQ darin plug is present.
