Smokin'
Relays under the hood, multiple angles.
How to make your own boost fooler.
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/SuperDuty/?action=view&current=DIYBoostFooler.flv]
[/ame]
How to remove your turbo.
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/Turbo/?action=view&current=TurboRemoval_0001.flv]
[/ame]
Turbo Dissembly, out of truck.
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/SuperDuty/?action=view&current=TurboHelp.flv]
[/ame]
Rear bind clamp info.
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/Turbo/?action=view&current=MOV00004.flv]
[/ame]
What the Exhaust Back Pressure Valve sounds like when Activating.
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/Turbo/?action=view&current=Exhaustbackpressurevalve.flv]
[/ame]
Gutting/Plugging the Pedistal (I know it says exhaust back pressuve valve but that part of the video got cut off)
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/Turbo/?action=view&current=GutandPlug.flv]
[/ame]
DP Tuner Chip Install.
http://www.dieselmovies.com/view_video.php?viewkey=b0395e163467c9dae521
Fuel Filter Drain O rings
http://home.centurytel.net/sabre/drainvalve.html
Oil Rail Plug Removal (under valve cover)
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/Engine%20Pull/?action=view&current=OilPlug.flv]
[/ame]
Injector Removal
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/Engine%20Pull/?action=view&current=InjectorRemoval.flv]
[/ame]
Injector Installation
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/Engine%20Pull/?action=view&current=Final.flv]
[/ame]
Purging cylinders after Injector installed (glow plugs out).
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/Injectors/?action=view&current=injectors015.flv]
[/ame]
Glow Plug Wire, under it is a 10mm bolt that requires a 1/4" drive, deep socket 10mm.
Glow Plugs
Buzz Test
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/Injectors/?action=view&current=MattsGTG001.flv]
[/ame]
Testing for Bent pushrods
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/Injectors/?action=view&current=injectors028.flv]
[/ame]
Head Removal
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/Engine%20Pull/?action=view&current=HeadRemoval.flv]
[/ame]
Hpop Information
HPOP and Resevoir removed.
Fuel Pressure Regulator
Headstud Install
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/Engine%20Pull/?action=view&current=Movie-2.flv]
[/ame]
Valve Spring R&R
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/Engine%20Pull/?action=view&current=ValveSpringRnR.flv]
[/ame]
Headstuds and Aftermarket Valve springs installed
03 Turbo Swap into an 05+
[ame=http://smg.photobucket.com/albums/v315/MazdaMartinb4k/SixOh%20Turbo/?action=view&current=FinalMovie.flv]
[/ame]
Water Pump Replacement
Cruising around
http://smg.photobucket.com/albums/v315/MazdaMartinb4k/madmatts%20house/?action=view&current=M2U00078.flv
You can use silicon on the dipstick tube O ring that goes on the tube and into the holder as well to keep it in place and from leaking.[/B
