What does everyone think of Meth Injection? Anyone running it? My truck and Magaflow Straight Pipe, AFE Intake, and Edge Plat....think it would work ok?
That crap will rot your teeth out. LOL
Seriously...keep the meth at 30-40% max...anything else and you're asking for melted pistons.
Mix your own to be sure...don't just use washer fluid.
Unbroken's right on both accounts.
Stick with a low mixture of methanol and you'll be fine. I normally keep it down to a 15-25% mixture on the high power programs.
can u really use washer fluid?
Yes, you can use washer fluid. Just make sure that it's the type with methanol. The label will tell you if it has it or not.
Ford sells a concentrate that works well with a 50/50 mix of water.
