1 - 17 of 17 Posts
Diesel Outlaw
ok guys my buddy has a 92 he has the gov spring and the pump turned up i just got him into sled pulling but he still needs the truck for work what can you do to these 1st gens with keeping it street legal? size injectors? etc. i told him put a p-pump on it but he wants to see what he can do for now with the pump he has.
does he have a EGT gauge yet? what exactly did u do to the pump? theres a good bit u can do to a ve pump. and theres plenty of injectors to chose from. how about upgrading the turbo? whats his budget? u can get thee trucks movin pretty good. if he doesn't have a fuel pin. get one. then then crank ur power screw in till its about to run away and back it off a hare. adjust your AFR down abit. then ur goin to want to upgrade ur lift lift. to either a 2nd gen one, a holley blue label, or one of an old 8.3 with a ve pump. get a sweet turbo and sum fat injectors. and u'll be movin. thats what i got and i drive n tow every day on 40''s and get 19 mpg.
good luck
Do Not use a 2nd gen lift pump. That pump is rated for 30 PSI output. That will push the front seal out of the VE injection pump. You need the lift put off an VE ag engine. That piston pump puts out 15 PSI.
oh yea sorry i forgot to add u need a psi regulator. my bad :bang
I'm not sure about the holley blue thing. I can pull a Holley black down to 0 psi! And you can fix the whole front seal thing, locktite snap ring and good to go!
Don't get me wrong for everyday driving the blue and/or low lift will be ok, Just letting you know there are more options out there if you want more.
Diesel Outlaw
im not sure on his budget he got in my truck and said he wants his modded he isnt going all out like i did but he needs to be able to tow a skid loader and other equipment with it. its on 35's now i told him a 62mm turbo and some injectors, he did the fuel pin and the power screw. is there any other free or cheap mods for now to get this thing moving he also did the gov. spring. and its a 5 speed by the way. thanks guys
Before he goes to far murder the kdp!! if it hasn't been done.
Timing, 1/8" then 1/4" then jump a tooth. This is free
But warn him on driving with a cold engine. More timing is more cyl pressure. Not good for a head gasket. You won't need to worry about the 1/16" or the 1/8" but much more than that you need to drive like a sane person.
Yes, while I shake my head no. If you are just wanting to do the 1/16 or 1/8 bump then you can do just that. If you are getting critical and after that last few ponies to squeeze out of you truck then yes.
Also He can put his KSB on a hobs switch, to kick in with more that... lets say 15psi of boost. Or on a switch at anything over 3/4throttle. Or just a toggle.
The choice is yours.
Just watch for surging. And tell him to have fun with his extra 2mpg's and lower egt's, also a small amount of boost loss has been noted by some after the timing mod.
He can also shave the afc or get rid of it all together. I don't think anyone should do this but lots do it and say they are putting down more power. I have done it and now I'm back to stock.
What pin is he Running? Home brew or one from a shop?
Your in PA. That means hills. He is towing. The mods you can do towing and keeping EGt's down are few.
Does he have gages installed??
Diesel Outlaw
yes he has gauges but currently has the pyro behind the turbo which he is moving to the manifold. the pin he grinded himself he said he grinded it and its thin a lot more then a bd pin. i havnt personally seen it.
The BD fuel pin is a copy of the old smokey. Grinding your stock pin doesn't add that much fuel. The aftermarket pins go a lot deeper.
Diesel Outlaw
Discussion Starter #13
thanks ill have to tell him that and wheres the cheapest place to pick one up at?
Over on DTR is a guy named DennyT that makes fuel pins.
On cumminsforum a member named alwaysworking makes the M&H fuel pin.
The M&H can be had in 5 different profiles. The DennyT is one profile now. It used to be two.
Right around $100 from what I have heard.
Diesel Outlaw
Discussion Starter #17
ok thanks guys ill try and get ahold of them guys thanks for all the help if you guys think of any other cheap mods let me no
1 - 17 of 17 Posts
