1 - 13 of 13 Posts
I drove 1100 miles to OK. 250 tune on the way down, 70 to 79mph. averaged about 15, 210 tune on the way home,maybe 15.5 avg.truck has 3.55 rear end, stock tires, anything going to get me better mileage,I want to hear it, thanks
Spartan, True Performance
Need more info!!! F250, 350, 4x4, 4x2?????
it is a F250 CC SB. 3.55 stock 18" tires, tonneau cover.4X4. dpf delete. S&B CAI, would it help to delete the DOC?
gear set
With the diesel option I thought that they only offered 3:73/4:10/4:30 gear set. 5.4 and the 6.8 have 3:55 gears. As for my cat. when I did the DPF delete I hallowed it out.
Late 2008 models and the 2009 models can be bought with the 3.55 ratio. I have the 3.55's in my 2008 F250 Lariat 4x4 CrewCab Shortbed (built 5/08) and am getting 18.2 mpg with the Spartan 210 Tune + DPF/CAT delete at 72mph and have less than 3,000 miles on my truck. I'd expect to see around 20 mpg on the highway once the truck gets around 8,000 to 10.000 miles on it.
My experience with all of the diesel trucks that I have owned (Ford, Chevy and Dodge) is that once you get above 2,000 rpms, the mileage begins to suffer. I wouldn't expect much more than 16 mpg if I were running near 80 mph.
i got a 08 3.73 6 speed and i run 275 every day towing and not and i got 709 miles outa my last tank all highway to nj and back to mass. and i was running it hard 85 90 the hole way this truck never comes outta 6th gear on the interstate i love it just my .oo2:thumbsup
jeremy
Is this hand calculated too, thanks
Hand cal. mine with the 275 tune and I got 23.78 US mpg, which is about 27.9 Eng mpg or 10.1 L/100. This is highway driving. So looking at my dash on the highway its pretty close. Dash reads 28.2 and I am getting 27.9
I like Pretty Girls!
:haha:haha Is it all down hill where you live?? How many miles are you going on how many gallons??
Whipersnapper
I just took a 2500 mile trip and got an average of 15mpg and now my truck at 3500miles on it. However if i just slowed down to 50mph which I had to on one tank because of the road I got 21mpg. Later I will post my own thread with all my fillups and mpg etc.
All of this with a 2008 F350 CC SB dually with 4.10s empty
I drive 80 mph on interstate, last two 200 mile trips im getting maybe 15mpg but dash says 20 i almost always get 375> miles on a tank
This is correcting for tire size as well, truck scales at 9200#lbs with normal crap in it. Has anyone else noticed on the dd Ford Vss and OBD II vss are different? The speedo seems to run off obdII which from what i can tell is less accurate than ford Check it out
1 - 13 of 13 Posts
