problem started with engine stalling when I came to a stop,progressivley got worse and now it hunts very bad and won't idle at all,any suggestions out there?
does it pull well above 1500 rpm? or do you have breakup or a regular miss past 2000 rpm?
keydl
runs great obove 1500 rpm,you wouldn't know anything was wrong
How many miles on those injectors?
Most of the time when injectors get over 150k on them they are pretty much done for.
High on the trouble shooting tree is the injection pump, if there is not a change that is confined to 1 injector when the injection lines are cracked loose. If it has been run a ways that might be 2.
Double check by doing it agin above 1500 rpm, the change should be the same for all injectors.
If 1 or 2 injectors show no change then service the injectors, if all 6 are close to the same do the pump.
keydk
