honda629
Shut my truck off an my hazards turned on an can't get em to shut off is this a common problem or what's the deal what do I gotta do to fix it??
Thanks Brian
Remove the flasher! most vehicles have two one for the turn signals and one for the 4 ways. The flasher has stuck.
You never said what truck you had? But you should be able to hear it and when you find the area feel it.
Super Moderator
Ford hasn't used flashers in over 10 years, no matter how long you look you won't find it.
Either the Hazard switch is stuck on or the LCM (Lighting Control Module) is bad.
honda629
i am thinking that its the LCM because if it turns an i flash the brights or turn lights on an off some times they willl shut off it will go away for a day or so an then they will come back on an flash then go right back off
