1 - 20 of 20 Posts
Since i get questions ocassionally about the switches that i have
installed in my truck i thought id create a thread w/ the information
as a reference ->
the switches are "CARLING" switches, available from Shane L.
the switches are NOT cheap, but they are TOP NOTCH HIGH QUALITY
& VERY VERY DURABLE (i have two switches that have probably been
cycled on and off at least 100 times).
My switches have been in use since early feb. 2006
After an exhaustive search i could find nothing <cheaper> that looked
as good & that had labeling appropriate for a my truck or car.
The closest i could find (in style and quality) were available at
BOAT US & marine stores...and they were nearly $30 dollars for EACH
switch !
In the next post is UPDATED info & Pricing on the switches which
includes several photos of installations (in different brand trucks)
the photos also so the all the labeling / options that Shane sells.
Again these switches are TOP QUALITY / HEAVY DUTY !
Ive just verified the pricing w/ Shane & he is still selling the switches.
Pictures:
You can view the actuators, brackets, switches, and tool at:
http://community.webshots.com/album/114685432SwLxOb
You can also view some install pictures at: http://community.webshots.com/album/115793651CUFFqj
Shipping:
I try to get orders out as soon as I receive payment, however this is a hobby and from time to time things get busy. It may take up to a week or more to orders shipped. I live in Alaska and my shipping options are limited. I only do priority or first class mail and you SHOULD receive a shipment in 3-7 days from when I ship it out depending where you are located.
US S&H: $10.00
UK S&H: $12.00
Payment:
I Prefer payment threw Paypal to my e-mail address of [email protected]
**New Prices as of 8-1-08**
Prices:
You need 1 actuator per switch. You do not need a mounting bracket, but makes for a cleaner and easier install, especially for multiple switches.
SPST (ON-OFF) switch with green light with red action light $9.00
DPDT (ON-OFF-ON) switch with green light and red action light $9.00
DPDT Momentary (ON-OFF-ON) NON LIGHTED switch: $6.00
DPDT Momentary (ON-OFF-ON) LIGHTED green light with red action light $9.00
SPST Momentary (ON-OFF) with green light only, no action light: $9.00
Actuators: $4.00
Single, end, or middle brackets: $1.50
3 mount bracket: $3.00
6 mount bracket: $6.00
Bracket Plug: $1.50
Removal tools: $1.00 ea (recommend 2)
clear 3/8 spiral split Wire loom: .20 ft
Currant Actuators available:
ACT101 Head Lights
ACT102 CL/ID Lights
ACT103 Trailer CL/ID lights
ACT104 Driving Lights
ACT105 Fog Lights
ACT106 Backup Lights
*ACT107 Dash Lights
ACT108 Power Window
ACT109 Engine Fan
ACT110 Mirror Defog
*ACT111 Mirror (In and Out)
ACT112 Engine Brake
ACT114 High / Low
ACT118 LH/RH Tank
ACT121 Beacon
ACT124 Idle Speed
ACT202 Air Axle
*ACT204 Mirror
ACT205 Marker
ACT206 Flood
*ACT214 Gener
ACT215 Rear Flood Lts
ACT216 Hyd Pump
ACT218 Body Lights
*ACT219 Blower
ACT220 AUX Heater
ACT328 0/0 Lights
ACT332 Engine Warm up
*ACT333 Fender Marker
ACT334 (pic only) Engine Warmup
ACT335 Spare
ACT336 Trailer Backup
ACT338 Rack Lights
ACT341 AUX
ACT345 Load Lite
ACT346 Work Lights
ACT348 Power Take Off
ACT000 Blank
(* limited supply, once they are gone I will not be getting any more)
Shane Linse [email protected]
907-715-6577
Discussion Starter #4 (Edited)
Don, you have any more pics of the install and what all did you order to get it set up like you have it?
no more photos of my install...but its pretty simple...cut the hole to
fit...
I built my switch set (CUSTOM Size) using these bracket pieces...you
just buy the correct number of "middle" and "end" pieces -
Shane offers some "pre-built" (one piece) brackets in 1, 3 or 6
switch blanks, if you dont want to build your own.
Shane even offers "blanks" to fill holes where you may not YET have
a switch...assuming your smart and are planning ahead (like i SHOULD
have done).
THE LASER labeled ACTUATORS are purched separately (one per switch)
and then the type of SWITCH (to fill the braket) is purchased,
on/off, on/off/on or momentary - DPDT or SPST
I wired mine simular to this (tieing the grounds together as well as the "illumination")
TDG MAFIA MEMBER #71
very nice!!!!!!!!!!!!!!!!
Discussion Starter #6 (Edited)
heres some installations that Shane has posted in his links.
MAFIA MEMBER 106
sweet i use those type switches with my air locker in my jeep they just work always
********* and Mafia #90
I thought i was the only one that did that, someone said it was wrong, i say its alot better and cleaver then a million wires :thumbsup
Done that stuff looks really nice
Another thread making me spend money....I might need a 4 piece set and holder. I have to go count the switches on my truck
my suggestion...buy the modular switch brackets...that way you can expand
(or shrink) it as needed later !
I bought extras (spares) just in case...and i just bought some MORE from
Shane last week....
when you place your order tell 'em DON (bushpilot) from TDG sent you !
you should come out.....grab a case and put them in...better make it a gallon a captain....switches may take a while
is there any of these left ? can i get custom ones such ad bottle blanket and N2O, led
Discussion Starter #19
depends on the switch you buy...not all are back lit and not all have "on" indicators.
the switches that are lit use a red & green LED.
the GREEN LED is illuminated when the parking lights are on, the RED LED is illuminated
when the switch it turned on, theyre not blinding bright...perfectly illuminated id say.
Discussion Starter #20
Update - had to add two more switches
one for the BlueSea ACR Relay and
one for the Remote Turn on for the Inverter
1 - 20 of 20 Posts
