I am chasing a miss at idle again with my cummins n14. It is in a 98 fld120 425hp It will miss and sound like the motor is kind of loping after it warms up for a few minutes. It is pulling real good but sounds bad at idle. I have replaced the ecm, injector harness, and 5 injectors in the last 3 months. The 6th injector is 1 year old. When I unplug each injector, they all seem to make a difference in idle but I know that this is not the correct method since the Insite program isolates the amount of fuel going to each injector when doing the cutout test. I think that maybe I have an injector that is over fueling possible and causing the ecm to compensate fuel supply to other injectors but I dont know how to isolate this . If I set the idle up to 1000rpm it will run a little rough for about 3-4 seconds and then clear up and run smooth. I have been reading this forum for years and finding solutions from everyone's input but this is my first thread because I cant find where someone else has had this particular issue. Thanks in advance for any help
Have you made basic fuel checks like air in fuel, fuel restriction and rail pressure? Were the injectors you put in new or recon? Recon's don't exactly have a stellar reputation. Maybe try checking exhaust temps to isolate a cylinder. You're not wrong in suspecting one injector could be over fueling at idle. You didn't say if you've tried a cylinder balance test with insite. This can be a difficult problem to find.
