I got my '97 GMC TopKick with the cummins 5.9 and 13 speed is all going good, I have hauled 4 or 5 loads of hay with it and I really like it, but on hot days pulling hay it gets to hot.
I have a pair of electric fans but they are not cooling enough, I need a fan hub out of a medium duty truck the on that brings the center of the fan to the same level of the valve cover, it looks like these can be found on Freightiner FL 50,60,70. I have an air compressor so I would like to find a fan hub assembly with an air operated clutch.
The F650 with 5.9 have (from what I have seen) a thermostatically controlled fan clutch like a Ford pickup. I will use the Ford set up if i can't come up with an air clutch set up.
i got a electric fan clutch set up off of a 5.9 that was in a school bus, I ran it the past 3 days, runs great temp never went over 195.
I got the parts from P&S truck and parts in Lunenburg Mass. They have everything from 3/4 ton to class 8.
Check them out www.pstrucksandparts.com
