I just got the truck last week and am hoping I got a good one. So far it seems to be running fine, but I would like to see the history on it.
Thanks in advance for the help... This website is great!
2005 Super Duty F-250 4x4
VIN: 1FTSX21P35EB13883
:ford
OASIS RESULT:
1FTSX21P35EB13883
02/04/2008
19:59:18
FCXWS447
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-02-11
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/11/2004 BUILD DATE
10/18/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
| On-line 1878
END OF OASIS REPORT FOR 1FTSX21P35EB13883
Standard Claims List For Model Year 2005
1FTSX21P35EB13883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 18-OCT-2004 11-DEC-2004 121432 USA 0 6N01 010806 2C3Z 99291A40 BAA B66 12 25
AWS Claim Key: 133359 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00365 - * Name: VERNIE JONES FORD COMPANY, INC. Ph: 706-6926467 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-2004 Doc #:12171001
Cust Comments: CUSTOMER STATES TRIM ON R S BED OUT OF POSITION
Tech Comments: TRIM INSTALLED WRONG ANT ASSEMBLY,TRIM WARPED. REPLACED TRIM.
1FTSX21P35EB13883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 18-OCT-2004 11-DEC-2004 121432 USA 2 3A02 070100 5C3Z 7D483 B P68 01 2267
AWS Claim Key: 363696 Trx Code: 1 Labor Hrs: 12.6
Dlr Cd-Sub Cd: 00365 - * Name: VERNIE JONES FORD COMPANY, INC. Ph: 706-6926467 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:19-JAN-2005 Doc #:12360201
Cust Comments: CUSTOMER STATES TRANS HESITATES WHEN SHIFTING INTO REVERSE FROM PARK ,THEN JERKS AND POPS WHEN ENGAGING HOT OR COLD
Tech Comments: ELEC TRANS DIAG PASS CODES,PRESSURE HIGH IN REVERSE,MATERIAL IN AUX.FILTER.REMOVED TRANSMISSION,DISASSEMBLED REAR SNAP
1FTSX21P35EB13883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 18-OCT-2004 11-DEC-2004 121432 USA 6 6N04 010802 5C3Z 16720 EB B62 81 12991
AWS Claim Key: 1011006 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00365 - * Name: VERNIE JONES FORD COMPANY, INC. Ph: 706-6926467 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:02-JUN-2005 Doc #:12685501
Cust Comments: CUSTOMER STATES FINISH COMING OFF F 250 EMBLEM ON R F FENDER
Tech Comments: REPLACED EMBLEM.
1FTSX21P35EB13883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 18-OCT-2004 11-DEC-2004 121432 USA 19 * * * * * * * 44754
AWS Claim Key: 5061280 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 00365 - * Name: VERNIE JONES FORD COMPANY, INC. Ph: 706-6926467 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:16-JUN-2006 Doc #:13599801
Cust Comments: RECALL 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT ON BOARD DIAGNOSTIC SYSTEM AND ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: REPLACED EP SENSOR AND RECALIBRATED CONTROL MODULES.
AWS Claim Key: 5061279 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00365 - * Name: VERNIE JONES FORD COMPANY, INC. Ph: 706-6926467 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:16-JUN-2006 Doc #:13599802
Cust Comments: RECALL 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE
Tech Comments: RECALIBRATED CONTROL MODULES.
AWS Claim Key: 5061278 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00365 - * Name: VERNIE JONES FORD COMPANY, INC. Ph: 706-6926467 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:16-JUN-2006 Doc #:13599803
Cust Comments: RECALL 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: 1 INSPECTED AND INSTALLED LABEL.
1FTSX21P35EB13883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 18-OCT-2004 11-DEC-2004 121432 USA 23 2E06 100106 3C3Z 9C407 AB D21 42 55178
AWS Claim Key: 6131723 Trx Code: E72 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 00302 - * Name: RONNIE THOMPSON FORD-MERCURY Ph: 706-2762777 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:11-OCT-2006 Doc #:09753501
Cust Comments: CUST STATES VEHICLE DIED WHILE DRIVING WILL NOT START BACK CHECK AND ADVISE ESP.....
Tech Comments: PERFORM HARD START NO START DIAG SHEET NO FUEL PRESSURE PERFORMED PPTS M14 M17 FOUND FUEL PUMP BAD. REPLACED FUEL PUMP ASSY RETEST OK AT THIS TIME.
1FTSX21P35EB13883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 18-OCT-2004 11-DEC-2004 121432 USA 26 1A02 030102 * 6051 * E23 D8 62280
AWS Claim Key: 6871147 Trx Code: E72 Labor Hrs: 22.7
Dlr Cd-Sub Cd: 00302 - * Name: RONNIE THOMPSON FORD-MERCURY Ph: 706-2762777 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:03-JAN-2007 Doc #:10029501
Cust Comments: C S INTERMITTENLY IN 45 SECOND SPAN, TEMP GAUGE GOES FROM NORMAL MIDDLE POSITION TO ALMOST RED LINE THAN DROPS BACK TO NORMAL, HAPPENS MORE WHEN PULLING SOMETHING, AND EVERY TIME HE HAS TO
Tech Comments: PERF DIESEL DIAG SHEET 8 CYLINDERS DROPPPING AT DIFFERENT TIMES PERF REL COMP PERF PPT PERF COMP TEST ALL ABOVE 395# ALL INJECTORS FAILING TURBO VANES STICKING EGR FAILS POSITION TEST 06 21 02 REVEALED HD GASKETS AND EGR COOLER LEAKING CONTACTED HOTLINE VERIFIED REPAIRS TO BE MADE REPL HD GASKETS COOLER ALL INJECTORS CLEANED CLEANED TURBO DRAINED CRANKCASE REFILL FLUIDS TEST DRIVE
1FTSX21P35EB13883 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 18-OCT-2004 11-DEC-2004 121432 USA 26 1B03 030204 3C3Z 6A642 AA L87 55 62718
AWS Claim Key: 6962315 Trx Code: E72 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 00302 - * Name: RONNIE THOMPSON FORD-MERCURY Ph: 706-2762777 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2007 Doc #:10077501
Cust Comments: CUSTOMER STATES VEHICLE IS LOOSING COOLANT
Tech Comments: OIL COOLER PLUGGED RESTRICTED. PERFORMED DIAGNOSTICS, REPLACED THE OIL COOLER, AND RADIATOR CAP, AND ROAD TESTED.
Thanks! Glad to see no reoccurring head problems on it... ;)
