TDG Mafia Member#67
1FTWW31R28EC65122
thanks!!
TDG Mafia Member#67
1FTSW21R28EB59987
forget the first one, it got sold, this is the one im getting...
anybody still doing this? looks like a lot of recent threads havent gotten replies...
1FTSW21R28EB59987 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 13-JUN-2007 17-JUL-2007 152068 USA 9 7G03 12XXXX 7C3Z 19E624 C C02 42 27192
AWS Claim Key: 707796 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN MERCURY Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2008 Doc #:587108B
Cust Comments: CUSTOMER STATES THE A C DOES NOT BLOW
Tech Comments: 27200 FW VERIFIED CUSTOMER CONCERN. PERFORMED OASIS. FOUND TSB 07 26 5. REPLACED BLOWER MOTOR CONTRO L. THEN STARTED TRUCK AND TEST DROVE. TO VERIFY PROPER OPERATION OF A C. A C IS NOW OPERATING PROPERLY.
1FTSW21R28EB59987 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 13-JUN-2007 17-JUL-2007 152068 USA 11 6E01 * * * * * * 31000
AWS Claim Key: 1110835 Trx Code: 08C01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN MERCURY Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-MAY-2008 Doc #:588914E
Cust Comments: RECALL 08C01
Tech Comments: PERFORMED RECALL
1FTSW21R28EB59987 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 13-JUN-2007 17-JUL-2007 152068 USA 11 6D01 011001 8C3Z 2862901 DD S50 31 31000
AWS Claim Key: 1110834 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN MERCURY Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-MAY-2008 Doc #:588914A
Cust Comments: CUSTOMER STATES FRONT SEAT COVER BOTTOMS ARE COMING APART
Tech Comments: CHECK AND VERIFIED BOTH FRT. SEAT BOTTOM COVER ARE COMING APART. REMOVE DRIVER AND PASS FRONT SEAT ASSY. DISASSEMBLE BOTH SEAT REPL. BOTH SEAT BOTTOM COVER AND REASSEMBLE. REINSTALLED BOTH PASS FRT. AND DRIVER'S SEAT ASSY.
1FTSW21R28EB59987 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 13-JUN-2007 17-JUL-2007 152068 USA 11 2E02 * * * * * * 31000
AWS Claim Key: 1110836 Trx Code: 08C04 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN MERCURY Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-MAY-2008 Doc #:588914F
Cust Comments: RECALL 08C04
1FTSW21R28EB59987 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 13-JUN-2007 17-JUL-2007 152068 USA 11 5R02 110601 7C3Z 3600 CB S27 D4 31000
AWS Claim Key: 1110837 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN MERCURY Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-MAY-2008 Doc #:588914G
Cust Comments: CUSTOME STATES STEERING WHEEL FADING
Tech Comments: CHECK AND VERIFIED STEERING WHEEL IS FADING. REMOVED STEERING COLUMN COVERS AND DRIVER AIRBAG MODULE TO ACCESS. REPL. STEERING
1FTSW21R28EB59987 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 13-JUN-2007 17-JUL-2007 152068 USA 16 7F06 011603 7C3Z 17603 A W03 42 47123
AWS Claim Key: 1909452 Trx Code: OTC Labor Hrs: 0
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN MERCURY Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-NOV-2008 Doc #:596977A
Cust Comments: WINDSHIELD WASHER WILL NOT SPRAY.
Tech Comments: OVER THE COUNTER RETURN
1FTSW21R28EB59987 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 13-JUN-2007 17-JUL-2007 152068 USA 25 1F01 * * * * * * 71841
AWS Claim Key: 4013262 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04584 - * Name: CHAMPION FORD Ph: 361-9946200 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-JUL-2009 Doc #:464020C
Cust Comments: 08B06 COOLING SYSTEM RECALL
Tech Comments: 71841 INSTALLED COOLING SYSTEM VENTURI TEE PER RECAL.
1FTSW21R28EB59987 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 13-JUN-2007 17-JUL-2007 152068 USA 25 1F01 030301 * * * * * 71841
AWS Claim Key: 4078075 Trx Code: 08B06 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 04584 - * Name: CHAMPION FORD Ph: 361-9946200 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-JUL-2009 Doc #:464020E
Cust Comments: CUST STATES COOLANT LEAK
Tech Comments: 71841 LEAKING RADIATOR PRESSURE TESTED COOLING SYSTEM.FOUND RADIATOR LEAKING AT LEFT TANK.REPLACED RADIATOR AS RELATED DAMAGE PER RECAL 08B06.RECHECKED FOR LEAKS.OK AT THIS TIME.
1FTSW21R28EB59987 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 13-JUN-2007 17-JUL-2007 152068 USA 25 1D01 030201 8C3Z 6700 A L65 D8 71841
AWS Claim Key: 4013264 Trx Code: E72 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 04584 - * Name: CHAMPION FORD Ph: 361-9946200 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-JUL-2009 Doc #:464020F
Cust Comments: CUST STATES OIL LEAK
Tech Comments: 71841 SEAL LEAKING VERIFIED ENGINE OIL LEAK FROM FRONT ENGINE AREA.ADDED OIL DYE TO ENGINE OIL AND ROAD TESTED.PINPOINTED LEAK TO FRONT CRANK SEAL USING BLACK LIGHT DIAGNOSIS.REPLACED FRONT ENGINE CRANK SEAL.CLEANED AREA.RECHECKED FOR LEAKS.OK AT THIS TIME.
1FTSW21R28EB59987 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 13-JUN-2007 17-JUL-2007 152068 USA 25 2G01 * * * * * * 71841
AWS Claim Key: 4013263 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04584 - * Name: CHAMPION FORD Ph: 361-9946200 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-JUL-2009 Doc #:464020D
Cust Comments: 08B07 PCM UPDATE
Tech Comments: 71841 REPROGRAMMED PCM AND IC PER RECAL.
1FTSW21R28EB59987 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 13-JUN-2007 17-JUL-2007 152068 USA 25 2G02 031403 8C3Z 12B591 D D42 42 71841
AWS Claim Key: 4013261 Trx Code: E72 Labor Hrs: 1
Dlr Cd-Sub Cd: 04584 - * Name: CHAMPION FORD Ph: 361-9946200 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-JUL-2009 Doc #:464020A
Cust Comments: CUST STATES WHILE DRIVING VEHICLE LOST POWER
Tech Comments: 71861 FAULTY SENSOR ROAD TESTED.ENGINE RUNNING NORMAL AT THIS TIME.EEC TESTED KOEO P1111 KOER P1111 KOEC P242D P242E.PERFORMED PINPOINT TESTS PER PCED.MONITORED EGT SENSOR DATA.FOUND REAR EGT SENSOR BIASED.REAR EGT SENSOR READING ABOUT 40 DEGREES HIGHER THAN FRONT AND MIDDLE EGT SENSORS KOEO.REPLACED FAULTY REAR EGT SENSOR.FINAL QUICK TEST.ROAD TESTED.OK AT THIS TIME.
1FTSW21R28EB59987 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 13-JUN-2007 17-JUL-2007 152068 USA 32 4C01 090201 9C3Z 5H221 B E29 69 85589
AWS Claim Key: 5337669 Trx Code: S07 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 04584 - * Name: CHAMPION FORD Ph: 361-9946200 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-FEB-2010 Doc #:477422A
Cust Comments: C S: CHECK ENGINE LIGHT CAME ON, DRAIN WATER SEP LIGHT CAME ON, THEN ENGINE DIED. (WAS TOWED IN)
Tech Comments: 85595 FAULTY EBP,EGR,DPF VERFIED MIL ON AND ENGINE STALLIN AFTER STARTING.EEC TESTED KOEO P006B P1335 KOEC P006B P042F P1335.PERFORMED PINPOINT TESTS AND MONITORED PID DATA.FOUND EBP SENSOR BIASED SHOWING 37.04 PSI AND EGR VALVE STUCK OPEN SHOWING 1.44 VOLTS KOEO.REPLACED FAULTY EBP SENSOR AND EGR VALVE.EEC TESTED PASS CODES.STARTED ENGINE AND FOUND ENGINE LACKING
Reactions: 6L strokin
TDG Mafia Member#67
wow... that seems like a lot of stuff... should i have got this truck? was messin around at a car lot and they offered me more trade in than i paid for the truck... should i take em up? LOL
