Just wondering if anybody has any advice. I have to take my truck into ford for a cab off repair I returned everything to stock except my FASS filter system. Just wondering if anybody has taken their truck in with the fass or airdog (i think they are about the same thing) Also....any recomendations on anything else I should have done while the cab is off. any info is appreciated.
Why is the cab coming off? Is your truck tuned?
ya its tuned. im getting a code p0088. according to ford it means the high psi fuel pump needs replaced "fuel rail psi too high" could cause injector tips to blow off causing catastrophic engine failure. they have a service buletin about it...sounds expensive if i can't get it under warantee.
will ford give me any grief about installing aftermarket head studs, does anybody have any problems with stock studs if they dont run any programmers
6.4's don't have head studs stock, they have head bolts, which can stretch, then cause leaks.
