VIN is 1FDXE4FS1ADA64795
This is the chassis of a Class C Motorhome. Could you also tell me if it has the remainder of a 5 year / 60,000 powertrain warranty?
Thank you
jvanbox
OASIS RESULT: 1FDXE4FS1ADA64795 USA: EN 16-JANUARY-2013 / 06:08:59 EST/ APP2
Local Time: 16-JANUARY-2013 / 4:09:03 AM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2010 E-SERIES
BODY STYLE: E-450 COMM CUTAWAY
ENGINE: 6.8L SOHC EFI NA V10 Gas
TRANSMISSION: 5R110W 5 Speed Auto Trans NAAO
AXLE CODE: 83
ENGINE CALIBRATION: AE418N0A
PAINT COLOR: Oxford White Solid C/C
PAINT CODE: YZ
RADIO: Less Radio
AXLE RATIO: 4.56 Ratio
WHEEL SIZE: 6.0 X 16" Steel Wheels - White
FRONT TIRE: LT225/75R-16E BSW A-S
GROSS VEHICLE WEIGHT: 14,500 LB. GVW
GENERAL WARRANTY INFORMATION
New Vehicle Base Warranty
WARRANTY START DATE: 01-JUNE-2010 <<---(Ford states gas vehicles 3yr, 36k)
BUILD DATE: 17-MARCH-2010
SALE MILEAGE: 00357
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE <---(No Extended Warranty)
CLAIMS:
Customer Concern Code S39-AIR BAG WARNING LIGHT TROUBLES
Condition Code 42-DOES NOT OPERATE PROPERLY
Technician Comment CHECKED AIR BAD LIGHT ON HAD CODE 1212 13 IN IT FOR THE DRIVERS SIDE PRETENSIONER OPEN.DID PIN PINT TEST FROM H1 TO H12 & I FOUND THAT THE RCM WAS BAD.I DEPOWERED THE AIR BAD SYSTEM & DID MODULE REP RGRAM.INSTALLED NEW MODULE & FINISHED REPROGRAM & REPOWERED THE AIR BAG SYSTEM,REDID AIR TEST & IT PASSED. 42 14B321
Customer Comment AIR BAG LAMP IS ON
