Standard Claims List For Model Year 2005
1FDWX37P45ED30126 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 08-MAY-2005 29-JUL-2005 152660 USA 14 6R01 01XXXX 5C3Z 2561203 AAA S26 42 12816
AWS Claim Key: 5732892 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 02388 - * Name: NIX FORD-MERCURY Ph: 918-4232800 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2006 Doc #:093080A
Cust Comments: C S DRIVERS SIDE SEAT BELT WILL NOT BUCKLE
Tech Comments: 12816 VERIFIED CONCERN. FOUND DRIVER FRONT SEAT BELT BUCKLE BROKEN. RR DRIVER FRONT SEAT FOR ACCESS. REPLACED DRIVER FRONT SEAT BELT BUCKLE. VERIFIED REPAIR.
1FDWX37P45ED30126 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 08-MAY-2005 29-JUL-2005 152660 USA 16 * * * * * * * 14075
AWS Claim Key: 6204855 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02388 - * Name: NIX FORD-MERCURY Ph: 918-4232800 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-2006 Doc #:094021B
Cust Comments: MODULE RECALIBRATION L
Tech Comments: RECAL MODULES PER RECALL 05E16B 3911
1FDWX37P45ED30126 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 08-MAY-2005 29-JUL-2005 152660 USA 41 2A01 031202 * 6C646 * E29 42 30652
AWS Claim Key: 10584414 Trx Code: E72 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 02388 - * Name: NIX FORD-MERCURY Ph: 918-4232800 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:17-NOV-2008 Doc #:108339A
Cust Comments: E29 C S CHECK ENGINE LIGHT IS ON
Tech Comments: 30656 CAC TUBE BOOT BLEW UP CHECKED OUT AND FOUDN CODE P0299. RAN KOER AND P0299. FOUND THE CAC TUBE BOOT AT THE TURBO WAS TORN, REPLACED CAC TUBE BOOT AND RETESTED AND ALL PASSES, EGR TEST PASSES, TURBO BOOST TEST PASSES, KOEO AND KOER, AND WHILE DRIVING EBP AND EBP DSD STAY TOGETHER AS SHOULD. TRUCK MAKES PLENTY OF BOOST AND RUNS FINE, RETURNED TO CUSTOMER. 3500 Y
1FDWX37P45ED30126 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 08-MAY-2005 29-JUL-2005 152660 USA 41 * * * * * * * 30652
AWS Claim Key: 10584415 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02388 - * Name: NIX FORD-MERCURY Ph: 918-4232800 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:17-NOV-2008 Doc #:108339B
Cust Comments: DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: 30656 INSTALLED STICKER ON DEGAS BOTTLE PER RECALL. 3500
1FDWX37P45ED30126 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 08-MAY-2005 29-JUL-2005 152660 USA 60 2E03 031403 4C3Z 12B599 BARM E29 42 52370
AWS Claim Key: 11532413 Trx Code: S07 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 02388 - * Name: NIX FORD-MERCURY Ph: 918-4232800 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2010 Doc #:120223B
Cust Comments: C S VEH HAS A ENGINE LIGHT HAS COME ON ADVISE
Tech Comments: VERIFY CONCERN. CHECK CODES, P0279, P0611. MONITOR PIDS AS PER TSB 10 12 06. FOUND FICM VOLTAGE DROPS TO 41 VOLTS. PERFORM PMI AND RETEST, STILL DROPS TO 41 VOLTS. REMOVE FICM AND REPLACE FICM HALF SHELL AS PER TSB. CLEAR CODES AND RETEST, PASS. MONITOR VOLTAGES NOW STAYS AT 48 VOLTS. ROAD TEST TO VERIFY REPAIRS, OK. 8670
1FDWX37P45ED30126 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 08-MAY-2005 29-JUL-2005 152660 USA 62 2H01 030407 5C3Z 9G489 AARM E29 42 53294
AWS Claim Key: 11583918 Trx Code: W32 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 02388 - * Name: NIX FORD-MERCURY Ph: 918-4232800 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:04-AUG-2010 Doc #:121027A
Cust Comments: C S VEH WRENCH LIGHT COMES ON AND VEH LOOSES POWER, UNDER LOAD PULLING HILLS
Tech Comments: CKD OUT,FOUND CEL ON.TST DRV,WRNCH LT WOULD COME ON,ENG WOULD LOSE ALL POWER.RN SLF TST & FOUND CODE P0236.TURBO OVER BOOST.FOLLWD DSL DIAG SHEET,FOUND TURBO STCKNG AT TIMES.REMVD TURBO & DISASSMBLD & FOUND CHRA WAS PITTED.REPLCD CHRA & INSTLLD NEW DRAIN TUBE.REASSMBLD & TRK RUNS BETTER BUT STILL LOOSESAT WOT.NO DTCS NOW.CKD FUEL PSI & IT WAS BELOW SPEC. REPLCD FUEL FILTERS & THIS HELPED.FUEL PSI
