Okay so just the other day my 03' silverado's speedometer started to act up...Then it started working better for a couple of days. Then the other day I started my truck and now all the gauges don't work (entire cluster just sits as if the truck were off) do I need to just replace my cluster?? I know alot of the 03's had crappy stepper motors which is what I thought I was experiencing but it threw me when they all don't respond now...... Thanks
Have your batteries load tested first. The cluster had to see a minimum voltage to "wake up" and if one or both the batteries are discharging, then this will occur.
If the batteries check out ok, then look into cluster replacement.
