Hey guys, I have a 2000 pete with a cat motor that peterbilt says came factory with a 6nz, but I can't verify it. The sticker is gone and it's not on the ecm. I have attached what we pulled off the ecm. Its a twin v belt setup and has c-15 covers. I know it's supposed to be etched somewhere on the passenger side block but no one can tell me exactly where.
Ok, it won't let me upload or log in from phone so here it is
Vehicle I'd 533913n
Engine serial not programmed
Ecm serial number 33890117ka
Personality module part number 2707067-00
Personality module release date may05
Personality module code 6
Using the last six of the Pete serial number, it come up with 6NZ03504.
6NZ03504 has a build date of 1999-12-19
533913 has a build date of 2000-01-05
Build dates look correct. I found a ECM download from 2007. Lists off 25819hrs on the engine. Model is described as 379 daycab. Pete factory records show it as a daycab.
I would like to believe that engine is factory.
The serial number should be below number 5 exhaust etched into the block. Paint will need to be removed and the block cleaned up. Sometimes very hard to see.
