I have a 97 250 that has recently started missing at idle when you start it up.
I sounds like the fuel is coming and going, The rpms jump from 700 down to 200 back and forth. Sounds a lot like a gas burner with a really big cam. I thank it may be sucking air but am not sure where to start looking. I did change the fuel filter and made sure it was sealing. Any help would be great.
thanks
Also the truck has 167k own it and was wondering if it would be okay to put a chip in it.
That could be the cps and yes a tuner would not hurt the truck . Be sure to install the basic supporting mods ; exhaust and intake .
You can idle the truck up a little for a second and the lope goes away. And the other day when it first started i had a very big lose of power.
Got the problem fixed it was a NPR sensor on the tranny.
