Standard Claims List For Model Year 2004
1FTNW21P74EE00142 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 05-JUN-2004 18-JUN-2004 123003 USA 37 1B01 0302XX 3C3Z 6C751 A L85 42 21057
AWS Claim Key: 11815342 Trx Code: E84 Labor Hrs: 5.4
Dlr Cd-Sub Cd: 08804 - * Name: ELK GROVE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-JUN-2007 Doc #:44011301
Cust Comments: VEHICLE LEAKING OIL CK & ADVISE (OIL SPOTS ON INSIDE OF HOOD (SPRAY PATTERN)
Tech Comments: CHECKED VEHICLE TO VERIFY CUSTOMER CONCERN.I THEN ADDED OIL DYE AND TEST DROVE.I FOUND VEHICLE TO HAVE SEVERAL LEAKS. I FOUND FOLLOWING LEAKS:CAM SENSOR O RINGS,BREATHER TUBE O RING,HOT CAC TUBE I REPLACED CAM SENSOR O RINGS,BREATHER TUBE O RING,HOT CAC TUBE SLEEVE(AT TURBO) AND TIGHTENED REMAINING CAC SLEEVE CLAMPS.I STEAM CLEANED ENGINE,RETEST DROVE AND RECHECKED FOR OTHER POSSIBLE LEAKS.I FOUN
1FTNW21P74EE00142 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 05-JUN-2004 18-JUN-2004 123003 USA 37 2G88 000615 * NPF * N50 82 21057
AWS Claim Key: 11815343 Trx Code: E84 Labor Hrs: 0.1
Dlr Cd-Sub Cd: 08804 - * Name: ELK GROVE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-JUN-2007 Doc #:44011302
Cust Comments: CUSTOMER STATES AT ANY SPEED WHEN LETTING OFF GAS, MAKES A GROUWLING NOISE. ADVISE
Tech Comments: TURBO IS MAKING NOISE, EDGE KIT IS SET AT 0 AND TURBO BOOST IS AT 30PSI (NORMAL RANGE IS 15 20PSI EXHAUST NOISE (AFTERMARKET PIPE) TIRES MAKES RUBBING
1FTNW21P74EE00142 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 05-JUN-2004 18-JUN-2004 123003 USA 38 7S12 180101 4C2Z 12A690 BA L85 63 21511
AWS Claim Key: 11878459 Trx Code: E72 Labor Hrs: 3.5
Dlr Cd-Sub Cd: 08804 - * Name: ELK GROVE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:24-JUL-2007 Doc #:44368601
Cust Comments: VEHICLE LEAKING OIL CK & ADVISE SEE HISTORY.
Tech Comments: CHECKED VEHICLE TO VERIFY CUSTOMER CONCERN.I CHECKED TO FIND LOCATION OF LEAK BUT COULD NOT TELL EXACT LOCATION.I STEAM CLEANED ENGINE AND TEST DROVE.I RECHECKED USING BLACK LIGHT AND FOUND THAT THE L I REPLACED GLOW PLUG HARNESS,STEAM CLEANED,TEST DROVE AND RECHECKED FOR LEAKS.NO OTHER LEAKS AT THIS TIME. NOTE VEHICLE HAS AN AFTERMARKET PERFORMANCE KIT(EDGE).
1FTNW21P74EE00142 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 05-JUN-2004 18-JUN-2004 123003 USA 40 * * * * * * * 21917
AWS Claim Key: 12094638 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08804 - * Name: ELK GROVE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:24-SEP-2007 Doc #:44810203
Cust Comments: PERFORM CAMPAIGN 59B01 (ONE TIME CUST. ASSURANCE TEST DRIVE)
Tech Comments: PERFORMED 59B01 59B01A .3
AWS Claim Key: 12094639 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 08804 - * Name: ELK GROVE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:24-SEP-2007 Doc #:44810202
Cust Comments: PERFORM RECALL 05E15 ((EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM AND ENGINE CONTROL MODULE RECAL.)
Tech Comments: PERFORMED 05E15 RECALL 05E15M 1.0
1FTNW21P74EE00142 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 05-JUN-2004 18-JUN-2004 123003 USA 59 2H01 03XXXX * 6K682 * D41 42 29855
AWS Claim Key: 13147053 Trx Code: S07 Labor Hrs: 5.3
Dlr Cd-Sub Cd: 07862 - * Name: HARROLD FORD Ph: 916-9221535 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-APR-2009 Doc #:409980A
Cust Comments: CUST STATES UNDER LOAD THERE WAS A POP NOISE AND NOW VEHICLE LOST ALL POWER ON ACCELERATION
Tech Comments: RD TEST, VERIFY ENG LACKS PWR & AIR NOISE IN ENG COMPARTMENT, VISUAL INSP, HAS CLEAN FUEL, OIL LEVEL OK, KOEO PASS, KOEC P0238 P0299 P0401 P0478 P2262 P2263, RUN OASIS, TSB 08 16 13, TEST TURBO.VGT, FOUND TURBO VANES STICKING, TEST FOR LEAK IN CAC SYS, FOUND INNER COOLER TANK RT SIDE BLOWN OUT DUE TO TURBO OVERBOOST, REMOVE TURBO & INSP, FOUND CHRA EXCESSIVELY RUSTED, UNISON RING
Thanks for your help!!
Any comments on that Turbo replacement? Should I be concerned about EGR valve damage or would all of that been inspected? It's a low mileage truck, about 42K currently.
