Standard Claims List For Model Year 2008
1FTSW21R18EE33700 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 30-JUN-2008 29-DEC-2008 113457 USA 1 2G01 * * * * * * 788
AWS Claim Key: 2656160 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 20630 - * Name: SMITH MOTOR COMPANY, INC. Ph: 908-6893737 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2009 Doc #:10221602
Cust Comments: PERFORM 08B07 REFLASH
Tech Comments: REFLASH PCM PER PROGRAM
1FTSW21R18EE33700 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 30-JUN-2008 29-DEC-2008 113457 USA 1 7K11 130101 * 10890 * A59 42 788
AWS Claim Key: 2656158 Trx Code: 1 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 20630 - * Name: SMITH MOTOR COMPANY, INC. Ph: 908-6893737 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2009 Doc #:10221604
Cust Comments: CUSTOMER STATES:CHECK NAVAGATION SYSTEM,SHOWS DISC ERROR
Tech Comments: 1 TEST ACM.B1140 PER PPT.REMOVE DISC AND CLEAN.IF PROBLEM PERSIST MUST REPLACE ACM
1FTSW21R18EE33700 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 30-JUN-2008 29-DEC-2008 113457 USA 1 7K11 130101 8C3Z 10890 C G32 81 788
AWS Claim Key: 2656159 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 20630 - * Name: SMITH MOTOR COMPANY, INC. Ph: 908-6893737 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2009 Doc #:10221603
Cust Comments: CUSTOMER STATES: THE CLEAR PLASTIC LENS OVER INSTRUMENT CLUSTER HAS SPOTS ON IT.
Tech Comments: LENS SCRATCHED,ORDER NEW PART 1
1FTSW21R18EE33700 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 30-JUN-2008 29-DEC-2008 113457 USA 1 1G04 030509 7C3Z 8678 B N12 42 788
AWS Claim Key: 2656161 Trx Code: 1 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 20630 - * Name: SMITH MOTOR COMPANY, INC. Ph: 908-6893737 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2009 Doc #:10221601
Cust Comments: CUSTOMER STATES: IDLER CHIRPS WHEN COLD PERFORM TSB 07.23.09
Tech Comments: 1 REPLACE PULLEY AS PER 07 23 09.STILL MADE NOISE REPLACE BELT,RETEST OK
1FTSW21R18EE33700 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 30-JUN-2008 29-DEC-2008 113457 USA 4 7M01 190703 * 18K931 * A60 42 8425
AWS Claim Key: 3448022 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 20630 - * Name: SMITH MOTOR COMPANY, INC. Ph: 908-6893737 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:27-APR-2009 Doc #:10378202
Cust Comments: CUSTOMER STATES:NAVIGATION UNIT ERROR CODE, TOUCH SCREEN IS HOT, NAVIGATION ERROR SCREEN ONLY HAPPENS WITH HEAT ON. HAPPENS AN HOUR AFTER DRIVING WITH HEAT TURNED ON.
Tech Comments: CHECK FOR CODES THERMAL SHUT DOWN CODE THIS IS THE CORRECT MILAGE FOR THIS VEHICLE ON THIS DATE
1FTSW21R18EE33700 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 30-JUN-2008 29-DEC-2008 113457 USA 4 2E03 * * * * * * 8425
AWS Claim Key: 3428901 Trx Code: 09B08 Labor Hrs: 6.7
Dlr Cd-Sub Cd: 20630 - * Name: SMITH MOTOR COMPANY, INC. Ph: 908-6893737 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:27-APR-2009 Doc #:10378201
Cust Comments: CUSTOMER STATES:pERFORM RECALL 09B08
Tech Comments: RECALL PERFORM RECALL AS REQUIRED REPLACE 8 INJECTORS AS PER VIN CHANGE OIL AND FILTER CLEAN CAC TUBES THIS IS THE CORRECT MILAGE FOR THE VEHICLE AT THIS DATE
1FTSW21R18EE33700 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 30-JUN-2008 29-DEC-2008 113457 USA 4 7M01 190703 7C3T 18K931 AG A07 42 6655
AWS Claim Key: 3383835 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: 67803 - * Name: FORD COMPONENT SALES, LLC Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:27-APR-2009 Doc #:03700709
Tech Comments: Dealer RO# 103782 1878# A0310872
