I could sure use an Oasis Report for my Ford...
2007 FORD F350 SUPER DUTY
VIN: 1FTWW33P87EA15233
Body Style: CREW PICKUP
Engine Size: 6.0L V8 FI
Thanks Charlie....
Standard Claims List For Model Year 2007
1FTWW33P87EA15233 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-MAY-2006 13-FEB-2007 153507 USA 1 7J05 0502XX 6L3Z 9E731 A H19 42 544
AWS Claim Key: 273157 Trx Code: S07 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2007 Doc #:14171001
Cust Comments: ABS LIGHT IS ON
Tech Comments: PDA WOULD NOT COMMUNICATE TO MODULE. PERFORMED MANUAL VEHICLE ENTRY TO GET IN. ABS SYSTEM DIAGNOSIS. REAR WHEEL SPEED SENSOR FAILURE. REPLACED SENSOR & PIGTAIL DUE TO WATER INTRUSION AT CONNECTOR. CLEARED CODE & RETESTED.
1FTWW33P87EA15233 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-MAY-2006 13-FEB-2007 153507 USA 13 2E03 030402 4C3Z 9E527 BRM D36 42 49018
AWS Claim Key: 1981682 Trx Code: S07 Labor Hrs: 7.1
Dlr Cd-Sub Cd: 03182 - * Name: WESTERN SLOPE AUTO COMPANY Ph: 970-2430843 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:18-FEB-2008 Doc #:355853A
Cust Comments: CUST STATES RUNS ROUGH ON COLD START. CUST STATES COULDF BARELY GET STARTED THIS AM. SMOOTHS OUT AFTER WARM BUT CUST STATES BELIEVES IS LOW ON PWR. NO MIL
Tech Comments: 49023 42 VERIFY RUNS ROUGH COLD PERFROM TSB 07 05 04 REFLASH MODULES WITH INDUCTIVE INJ HEAT STRATAGIE RETEST STILL RUNS ROUGH NECESSARY TO RUN PERFORMANCE SHEET RETRIEVED DTCS P 0266 P 0275 #2 AND #5 BALANCE FAULT FUEL PSI AT 56 PSI RUN ENHANCED INJ DIAG FOUND #2 AND #5 INJ BAD REMOVE BOTH VALVE COVERS REPLACE #2 LEFT BANK AND #5 RIGHT BANK REASSEMBLE CLEAR DTCS TEST DRIVE
1FTWW33P87EA15233 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-MAY-2006 13-FEB-2007 153507 USA 17 7B02 140201 * 10346 * C26 42 49828
AWS Claim Key: 2799533 Trx Code: P05 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER FORD Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:09-JUN-2008 Doc #:112160C
Cust Comments: CUSTOMER STATES CHARGING SYSTEM LIGHT COMES ON
Tech Comments: 49828 ALTERNATOR LOW VOLTAGE VERIFY CUSTOMER CONCERN, PERFORM STARTING AND CHARGING SYSTEM DIAGNOSTICS FOUND ALTERNATOR CHARGING AT 11.8 VOLTS. FAIL. REPLACE ALTERNATOR AND RETEST.
1FTWW33P87EA15233 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-MAY-2006 13-FEB-2007 153507 USA 17 2E03 030402 4C3Z 9E527 BRM D21 42 49828
AWS Claim Key: 2808697 Trx Code: S07 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER FORD Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:09-JUN-2008 Doc #:112160A
Cust Comments: DIED WHILE DRIVING
Tech Comments: 49828 REPLACED #1 FUEL INJECTOR VERIFIED CONCERN OF RUNS ROUGH, PERFORMED DIAG SHEETPERFORMED ENHANCED POWER BALANCE FOUND #1 FUEL INJECTOR LOW, REMOVED VAVLE COVER REPLACED #1 FUEL INJECTOR ROAD TESTED VERIFIED REPAIR.
Thanks
Thanks 00f3fiddy for the Quick Response to the Oasis Request....
Now I just have to learn to read it...
Thanks again....Charlie
