Standard Claims List For Model Year 2005
1FTWX31P15EB98973 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JAN-2005 24-MAR-2005 113465 USA 13 6A07 010203 * 16005 * F07 P4 15066
AWS Claim Key: 5089752 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 20573 - * Name: LEO KAYTES FORD, INC. Ph: 845-9861132 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:13-APR-2006 Doc #:01634204
Cust Comments: CUSTOMER STATES PASSENGER SIDE FENDER PAINT IS BUBBLING
Tech Comments: TOOK PICTURES DIGITAL IMAGING APPROVED TO REFINISH FENDER SUBLET TO PAINT SHOP SAND AND REFINISH R&R MOULDING THAT DAMAGED WHEN R&R TO PAINT
1FTWX31P15EB98973 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JAN-2005 24-MAR-2005 113465 USA 13 * * * * * * * 15066
AWS Claim Key: 4791091 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 20573 - * Name: LEO KAYTES FORD, INC. Ph: 845-9861132 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:13-APR-2006 Doc #:01634202
Cust Comments: INSPECT FOR RECALL
Tech Comments: INSTALLED LABEL AS PER RECALL 05B32
AWS Claim Key: 4791092 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 20573 - * Name: LEO KAYTES FORD, INC. Ph: 845-9861132 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:13-APR-2006 Doc #:01634206
Cust Comments: QUALITY ASSURANCE ROADTEST
Tech Comments: PERFORM ROADTEST OK
1FTWX31P15EB98973 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JAN-2005 24-MAR-2005 113465 USA 13 6N04 010807 5C3Z 9942528 CA B66 05 15066
AWS Claim Key: 5089753 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 20573 - * Name: LEO KAYTES FORD, INC. Ph: 845-9861132 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:13-APR-2006 Doc #:01634205
Cust Comments: CUSTOMER STATES TAILGATE EMBLEM PEELING
Tech Comments: BLACK LETTERING PEELING ON EMBLEM TOOK PICTURES SENT TO DIGITAL IMAGING AUTH TO REPLACE EMBLEM REPLACED EMBLEM
AWS Claim Key: 4791090 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 20573 - * Name: LEO KAYTES FORD, INC. Ph: 845-9861132 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:13-APR-2006 Doc #:01634201
Tech Comments: REPLACE EXHAUST PRESSURE SENSOR AND RECALIBRATE AS PER RECALL 05E15M
1FTWX31P15EB98973 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JAN-2005 24-MAR-2005 113465 USA 25 7T03 050300 6C3Z 2C204 BA H19 28 29187
AWS Claim Key: 7588666 Trx Code: E83 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 20573 - * Name: LEO KAYTES FORD, INC. Ph: 845-9861132 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2007 Doc #:02285803
Cust Comments: REPORTS ABS LIGHT IS ON
Tech Comments: PERF ABS DIAG RETREIVED CODE C1155 PERF PNPT FD FAULTY FRONT SENSOR REPL SENSOR CLEAR CODE RD TESTED OK
1FTWX31P15EB98973 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JAN-2005 24-MAR-2005 113465 USA 25 6G09 011103 * 5425712 * G07 42 29187
AWS Claim Key: 7588667 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 20573 - * Name: LEO KAYTES FORD, INC. Ph: 845-9861132 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2007 Doc #:02285804
Cust Comments: REPORTS REAR WINDOW NOT OPERATING PROPERLY
Tech Comments: VERIFIED CONCERN REMOVE DOOR PANEL CHECK SLIDER FD SLIDER SEIZED LUBE SLIDER WINDOW TRACKS RECHECK OPERATING PROPERLY NOW
1FTWX31P15EB98973 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JAN-2005 24-MAR-2005 113465 USA 25 2A01 031202 * 6C646 * L65 55 29187
AWS Claim Key: 7588665 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 20573 - * Name: LEO KAYTES FORD, INC. Ph: 845-9861132 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:10-APR-2007 Doc #:02285801
Cust Comments: REPORTS SEEING AN OIL LEAK
Tech Comments: VERIFIED CONCERN OIL LEAK DIAG FD LEAK COMING FROM CAC TUBE R&I TUBE CLEAND CAC TURBO & REASSY RECHECK NO LEAK FD REQ M TIME TO CLEAN CAC
1FTWX31P15EB98973 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JAN-2005 24-MAR-2005 113465 USA 47 2I04 030709 4C3Z 12A342 AA E29 28 45833
AWS Claim Key: 10722607 Trx Code: S07 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 20573 - * Name: LEO KAYTES FORD, INC. Ph: 845-9861132 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:21-JAN-2009 Doc #:03474401
Cust Comments: CUSTOMER REPORTS CHECK ENGINE LIGHT IS ON
Tech Comments: CHECK AND PERFORM DIESEL DIAGNOSTICS, TRACE TO GLOW PLUG CIRCUIT, TEST GLOW PLUGS, REPLACE NUMBER 4 CYLINDER GLOW PLUG AND CLEAR CODES AND RETEST
1FTWX31P15EB98973 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JAN-2005 24-MAR-2005 113465 USA 48 2A01 031202 * 6C646 * L65 42 46901
AWS Claim Key: 10898460 Trx Code: E72 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 20573 - * Name: LEO KAYTES FORD, INC. Ph: 845-9861132 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:06-FEB-2009 Doc #:03505601
Cust Comments: CUSTOMER REPORTS OIL LEAK UNDER VEHICLE
Tech Comments: CHECK AND VERIFIED LEAK, DYE TEST, LOCATE LEAK, FOUND TSB DESCRIBING CONCERN, PERFORM TSB AND REPLACE REINFORCING RING WITH CAC TUBE, RECHECK OK
1FTWX31P15EB98973 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JAN-2005 24-MAR-2005 113465 USA 59 2E03 031403 4C3Z 12B599 ABRM D03 28 52689
AWS Claim Key: 11350055 Trx Code: S07 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 20573 - * Name: LEO KAYTES FORD, INC. Ph: 845-9861132 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:04-JAN-2010 Doc #:04189202
Cust Comments: CUSTOMER REPORTS HARD START
Tech Comments: CHECK AND VERIFIED HARD START, PERFORM DIESEL DIAGNOSTIC FOR HARD START, REPLACE FUEL INJECTOR CONTROL MODULE, CLEAR CODES AND RETEST OK
1FTWX31P15EB98973 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JAN-2005 24-MAR-2005 113465 USA 61 2H01 03XXXX * 6K682 * D42 42 54475
AWS Claim Key: 11426972 Trx Code: S07 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 20573 - * Name: LEO KAYTES FORD, INC. Ph: 845-9861132 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:22-MAR-2010 Doc #:04337101
Cust Comments: CUSTOMER REPORTS TURBO IS OVERBOOSTING, WHITE SMOKE
Tech Comments: CHECK AND PERFORM DIESEL DIAGNOSTICS AND PINPOINT TESTS, TEST TURBO, FOUND TSB 09 16 05, FOLLOW PROCEDURES, DISASSMEBLE TURBO, REPLACE CENTER HOUSING AND UNISON RING, INSTALL TUBE AND REASSEMBLE AND RETEST OK, ROADTEST OK
