OASIS RESULT:
1FTWW31P15EA78495
07/25/2006
17:21:42
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
ZF M6HD-W 6-SPEED AXLE CODE
3L ENGINE CALIBRATION
5F720Q0A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/16/2004 BUILD DATE
09/23/2004 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-14-06
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
OTHER WTYS MAY APPLY/REACQUIRED VEH WTY EXP 09-26-2006
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
06/06/2006
DEALER: Capitol Expressway Ford
WARRANTY CLAIM NUMBER: 056883 ODOMETER: 029071M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15M
REPLACE EP AND REFLASH PCM
06/06/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
COMPLETED RECALL
06/06/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B32B
INSTALLED LABEL
06/06/2006
LABOR OP
CONDITION CODE
CONDITION DESC
BXT 65750 MOTORCRAFT BATTERY 001 10654CA 42 DOES NOT OPERATE PROPERLY
000 10654C1
PERFORM SELF TEST-LOW BATTERY VOLTAGE.CHECKED DRAW-SELF TEST IC MONITOR.REP LACED BATTERY RECHECKED OK
06/06/2006
LABOR OP
CONDITION CODE
CONDITION DESC
YR3Z 6365070AA SEAT BELT BUTTON KIT 002 MT65070 42 DOES NOT OPERATE PROPERLY
INSTALLED KIT ASSY
08/18/2005
DEALER: Michael Stead's Hilltop Ford
WARRANTY CLAIM NUMBER: 068071 ODOMETER: 016493M
LABOR OP
CONDITION CODE
CONDITION DESC
RAV REACQUIRED VEHICLE 000 RAV 82 FREIGHT/POSTAGE/MAINTENANCE
1 PERFORMED RAV INSPECTION AS PER SHEET
08/18/2005
LABOR OP
CONDITION CODE
CONDITION DESC
TDRIVE PDI TEST DRIVE 000 TDRIVE 82 FREIGHT/POSTAGE/MAINTENANCE
. PERFORMED 1.0 6.0L DI INSPECTION TO INCLUDE A COLD START, HOT SOAK, EXT ENDED ROAD TEST AND UPDATE PCM AS PER SHEET
08/18/2005
LABOR OP
CONDITION CODE
CONDITION DESC
NPF NO PROBLEM FOUND (NR 000 NPF 82 FREIGHT/POSTAGE/MAINTENANCE
TESTED AND INSPECTED VEHICLE FOR ENGINE NOISE FOUND NO ABNORMAL SOUNDS FROM THIS ENGINE AT THIS TIME. CALLED OASIS 515 574 030 AND FOUND NO TSB OR SSM S
08/18/2005
LABOR OP
CONDITION CODE
CONDITION DESC
12B637 WIRING ENG CNTRL SNS 000 12650D 30 CHAFED,EXCESSIVE WEAR,FRAYED
000 12650D45
000 12650D80
000 12650D81
000 12650D47
000 9350B
000 12650D84
000 8080A
000 9601A
000 9438A2
000 12650D67
000 6584AL
000 14200A
EEC TEST, RETEST, PINPOINT, DCL, MONITOR, POWERBALANCE, TEST FUEL PRESSURE, REPROGRAMMED PCM (5U7A-12A650-AEA), REMOVED AND INSTALLED THE COOLANT BOTTLE , AIR CLEANER ASSEMBLY, THE TURBO CHARGER INLET TUBE, THE FICM AND THE LEFT ROCKER COVER TO ACCESS AND REPAIR THE HARNESS 12B637 AT C1313 CKT31 (WH- RD) LOOSE.
08/18/2005
LABOR OP
CONDITION CODE
CONDITION DESC
MISC FOR REPAIRS NOT COVE 000 MTMISC 82 FREIGHT/POSTAGE/MAINTENANCE
XL3Z 17B807AAA STEP REAR BUMPER 001
F81Z 17B807AA STEP REAR BUMPER 001
F81Z 17B807AB STEP REAR BUMPER 001
REPLACED REAR BUMPER COVERS
END OF OASIS REPORT FOR 1FTWW31P15EA78495
Standard Claims List For Model Year 2005
1FTWW31P15EA78495 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 23-SEP-2004 16-OCT-2004 172300 USA 2 2G01 031401 5C3Z 12A650 KLB D42 42 3199
AWS Claim Key: 258131 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 07742 - * Name: BIG VALLEY FORD Ph: 209-8704400 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-2004 Doc #:49548101
Cust Comments: CUSTOMER STATES PULLING A TRAILER ENGINE ACTS LIKE IT WILL STALL 1600 1800 RPM RANGE AND MUST KEEP DOWNSHIFTING BUT
Tech Comments: EEC TEST,REPLACE PCM PER FSE DON DONLEVY,LIGHT CAME ON KOEO P1639 FLASH ELECTRICITY ERASEABLE PROGRAMABLE READ ONLY MEMORY,PERFORMED PMI,PROGRAM VID BLOCK IN PCM,TCM,CLEAR CODE S,ROAD TEST RECORD & MONITOR PIDS,RETEST OK
1FTWW31P15EA78495 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 23-SEP-2004 16-OCT-2004 172300 USA 2 7C01 170503 * 14018 * L19 42 3199
AWS Claim Key: 258130 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 07742 - * Name: BIG VALLEY FORD Ph: 209-8704400 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-2004 Doc #:49548102
Cust Comments: CUSTOMER STATES RF DOOR AJAR LITE KEEPS COMING ON OPEN AND RESHUT RF DOOR AND WILL GO OFF AND REPAIR
Tech Comments: ROAD TEST MONITOR PIDS,REMOVE RIGHT FRONT DOOR TRIM PANEL INSPECT CONNECTOR,OK,CHECK CONNECTOR AT KICK PANEL RUBBER BOOT BETWEEN BODY & DOOR,OK AT THIS TIME,LUBED DOOR SWITCH ,CHECK FUSES,NO PROBLEMS FOUND AT THIS TIME
1FTWW31P15EA78495 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 23-SEP-2004 16-OCT-2004 172300 USA 4 2G02 031201 3L3Z 12B579 AB D36 42 6706
AWS Claim Key: 574149 Trx Code: S07 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 07742 - * Name: BIG VALLEY FORD Ph: 209-8704400 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2005 Doc #:49988801
Cust Comments: CUSTOMER STATES ENGINE SURGES USUALLY WHEN PULING A HILL AROUND 1800 RPM,BARKING NOISE,NO POWER WORSE WHEN PULLING
Tech Comments: 1 VISUAL TEST AND ROAD TEST,UNABLE TO DUPLICATE CONCERN, EEC TEST AND MONITOR TEST PASSED,HOOKED UP FLIGHT RECORDER AND CUSTOMER TOOK VEHICLE,CUSTOMER RETURNED WITH RECORDINGS
1FTWW31P15EA78495 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 23-SEP-2004 16-OCT-2004 172300 USA 6 2H01 030008 4C3Z 6K682 AARM D36 42 10893
AWS Claim Key: 747468 Trx Code: S07 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 07742 - * Name: BIG VALLEY FORD Ph: 209-8704400 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-APR-2005 Doc #:50430601
Cust Comments: CUSTOMER STATES ENGINE SURGES USUALLY WHEN PULLING A HILL AROUND 1800 RPM WITH A DOG PARKING NOISE NOTE PROBLEM WORSE PULLING A TRAILER AND REPAIR SEE HISTORY
Tech Comments: 1 VIEW RECORDINGS,MONITOR PIDS,PIN POINT TEST,REPLACED FAILED TURBO,INSTALLED HARDWARE KIT,RETEST OK DONE
1FTWW31P15EA78495 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 23-SEP-2004 16-OCT-2004 172300 USA 6 6Y05 000001 * ESPRCR * A9* 82 10893
AWS Claim Key: 757038 Trx Code: RCR Labor Hrs: 0
Dlr Cd-Sub Cd: 07742 - * Name: BIG VALLEY FORD Ph: 209-8704400 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-APR-2005 Doc #:50430603
Cust Comments: RENTAL CAR ISSUED TO CUSTOMER THROUGH BIG VALLEY FORD.
Tech Comments: ESP RENTAL COUPON 404012499 RENTAL BILL INVOICE # D660756
AWS Claim Key: 757037 Trx Code: RCR Labor Hrs: 0
Dlr Cd-Sub Cd: 07742 - * Name: BIG VALLEY FORD Ph: 209-8704400 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-APR-2005 Doc #:50430604
Cust Comments: ESP RENTAL COUPON
Tech Comments: COUPON 404012500 RENTAL INVOICE# D660756
1FTWW31P15EA78495 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 23-SEP-2004 16-OCT-2004 172300 USA 7 1H03 030008 5C3Z 9F452 AA D41 42 11510
AWS Claim Key: 1145538 Trx Code: S07 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 07742 - * Name: BIG VALLEY FORD Ph: 209-8704400 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:23-APR-2005 Doc #:50524501
Cust Comments: CUSTOMER STATES ENGINE SURGES 1600 2000 RPM RANGE AND MAKES A DOG BARKING NOISE AND REPAIR CUSTOMER WOULD LIKE FLIGHT RECORDER INSTALLED
Tech Comments: 1 INSTALLED VDR FOR CUSTOMER,CUSTOMER DROVE VEHICLE AND MADE RECORDINGS,CUSTOMER CAME BACK AND DROPPED OFF VDR,PLAYED BACK VDR AND FOUND FAILED EGR VALVE,ORDERED VALVE,CUSTOMER RETURNED REPLACED EGR VALVE AND RETEST OK
1FTWW31P15EA78495 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 23-SEP-2004 16-OCT-2004 172300 USA 11 6Y20 000079 * RAV * A9* 82 16493
AWS Claim Key: 1695844 Trx Code: RAV Labor Hrs: 1
Dlr Cd-Sub Cd: 01724 - * Name: MICHAEL STEAD'S HILLTOP FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-2005 Doc #:06807101
Cust Comments: PERFOM RAV INSPECTION PER INSPECTION SHEET.
Tech Comments: 1 PERFORMED RAV INSPECTION AS PER SHEET
1FTWW31P15EA78495 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 23-SEP-2004 16-OCT-2004 172300 USA 11 6Y05 000001 * TDRIVE * A9* 82 16493
AWS Claim Key: 1911659 Trx Code: P86 Labor Hrs: 1
Dlr Cd-Sub Cd: 01724 - * Name: MICHAEL STEAD'S HILLTOP FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-2005 Doc #:06807102
Cust Comments: PERFORM 1.0 6.0 DI INSPECTION AS PER RAV GUIDELINE SHEET
Tech Comments: . PERFORMED 1.0 6.0L DI INSPECTION TO INCLUDE A COLD START, HOT SOAK, EXTENDED ROAD TEST AND UPDATE PCM AS PER SHEET
1FTWW31P15EA78495 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 23-SEP-2004 16-OCT-2004 172300 USA 11 1A88 000615 * NPF * N11 82 16493
AWS Claim Key: 1695843 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 01724 - * Name: MICHAEL STEAD'S HILLTOP FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-2005 Doc #:06807103
Cust Comments: ORIGINBAL OWNER STATES NOISE ENGINE(UPPER)
Tech Comments: TESTED AND INSPECTED VEHICLE FOR ENGINE NOISE FOUND NO ABNORMAL SOUNDS FROM THIS ENGINE AT THIS TIME. CALLED OASIS 515 574 030 AND FOUND NO TSB OR SSM S
1FTWW31P15EA78495 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 23-SEP-2004 16-OCT-2004 172300 USA 11 7S06 180101 * 12B637 * D41 30 16493
AWS Claim Key: 1695842 Trx Code: S07 Labor Hrs: 6.6
Dlr Cd-Sub Cd: 01724 - * Name: MICHAEL STEAD'S HILLTOP FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-2005 Doc #:06807105
Cust Comments: ORIGINAL OWNER STATES SURGE ACCELERATE ALL ENG TEMP.
Tech Comments: EEC TEST, RETEST, PINPOINT, DCL, MONITOR, POWERBALANCE, TEST FUEL PRESSURE, REPROGRAMMED PCM (5U7A 12A650 AEA), REMOVED AND INSTALLED THE COOLANT BOTTLE, AIR CLEANER ASSEMBLY, THE TURBO CHARGER INLET TUBE, THE FICM AND THE LEFT ROCKER COVER TO ACCESS AND REPAIR THE HARNESS 12B637 AT C1313 CKT31 (WH RD) LOOSE.
1FTWW31P15EA78495 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 23-SEP-2004 16-OCT-2004 172300 USA 11 6Y20 000001 * MISC * A9* 82 16493
AWS Claim Key: 1695841 Trx Code: P86 Labor Hrs: 2
Dlr Cd-Sub Cd: 01724 - * Name: MICHAEL STEAD'S HILLTOP FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-2005 Doc #:06807110
Cust Comments: (L)PER RAV REPLACWE REAR BUMPER COVERS.X3
Tech Comments: REPLACED REAR BUMPER COVERS
1FTWW31P15EA78495 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 23-SEP-2004 16-OCT-2004 172300 USA 20 * * * * * * * 29071
AWS Claim Key: 5100291 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 06098 - * Name: CAPITOL EXPRESSWAY FORD Ph: 408-2656000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2006 Doc #:056883A
Cust Comments: PERFORM RECALL
Tech Comments: REPLACE EP AND REFLASH PCM
AWS Claim Key: 5100292 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06098 - * Name: CAPITOL EXPRESSWAY FORD Ph: 408-2656000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2006 Doc #:056883B
Tech Comments: COMPLETED RECALL
AWS Claim Key: 5100293 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06098 - * Name: CAPITOL EXPRESSWAY FORD Ph: 408-2656000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2006 Doc #:056883C
Tech Comments: INSTALLED LABEL
1FTWW31P15EA78495 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 23-SEP-2004 16-OCT-2004 172300 USA 20 7A01 140101 BXT 65 750 C25 42 29071
AWS Claim Key: 5100294 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 06098 - * Name: CAPITOL EXPRESSWAY FORD Ph: 408-2656000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2006 Doc #:056883G
Cust Comments: CUSTOMER STATES BATTERY HAS TO JUMP STARTED EVERY MORNING TO START VEHICLE
Tech Comments: PERFORM SELF TEST LOW BATTERY VOLTAGE.CHECKED DRAW SELF TEST IC MONITOR.REPLACED BATTERY RECHECKED OK
1FTWW31P15EA78495 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 23-SEP-2004 16-OCT-2004 172300 USA 20 6R01 012001 YR3Z 6365070 AA S40 42 29071
AWS Claim Key: 5100295 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 06098 - * Name: CAPITOL EXPRESSWAY FORD Ph: 408-2656000 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2006 Doc #:056883H
Cust Comments: CUSTOMER STATES BOTH DRIVERS AND PASSENGERS FRONT SEAT BELTS HAVE LOSS BUTTONS THAT HOLD MALE END OF SEAT BELT FROM SLIDING ALL THE WAY DOWN
Tech Comments: INSTALLED KIT ASSY
