8LUG Truck Gear proud to announce a new line of 2.5" Coil Spring Systems for the 2003-up Dodge Ram HD 2500 4x4's from Pure Performance.
These systems will accomodate up to a 35" tall tires.
The first is the 2.5" Starter System... It includes 2.5" progressive rate front coils and 1" tall billet aluminum blocks and u bolts.
We are offering these systems with multiple options starting at $449.
Pure Performance 2.5 Starter System
The second is the 2.5" Stock Mod System. Above and beyond the Starter System it adds:
billet aluminum sway bar end links
HD adjustable track bar made from 1.5" diameter solid chromoly steel with a high quality 7/8 FK heim joint and the required hardware to upgrade your track bar hardware to 5/8.
We are offering these with multiple options starting at $799.
Pure Performance 2.5 Stock Mod System
The third is the 2.5" Max Travel System and is the ultimate in performance for the 2.5" lifts. Above and beyond the Stock Mod System it adds:
Double adjustable front lower control arms made from 2" diameter solid alloy steel for improved axle positioning and caster settings
Rear Deaver mini packs improve the ride in the rear
We are offering these with multiple options starting at $1349.
Pure Performance 2.5 Max Travel System
All hard parts come with our exclusive abuse proof lifetime warranty.... We now offer the new Pure Performance All Aluminum 2.0 Prodigy Direct Fit Shocks for these applications as well! We will be offering these for $169 per shock. They are fully rebuildable, fully revalveable, and even upgradeable to remote reservoirs.
The direct fit part numbers are as follows;
PPS02084 2.5" Front Shock for Gas Models
PPS02085 2.5" Front Shock for Diesel Models
PPS02086 2.5" Rear Shock for all Models
Here are the images of the new 2.0 Prodigy Shocks​
