Vendor
https://www.youtube.com/watch?v=C-VZzYC8KFE
There is plenty of reasons out there why people want their trucks lifted. Whatever is yours, get it lifted with no-hassle at all with our newest premium quality 4.5-Inch Lift Kit at CARiD. Rancho, the leading manufacturer of technologically advanced suspension systems, has made a perfect fit 4.5" x 3.5" Front and Rear Suspension Lift Kit for all 2017-2018 Ford F-150. Manufactured from the finest quality materials using up-to-date equipment, they will offer exceptional performance, fit and durability to you. Guaranteed to offer exceptional performance and durability, it will also ensure proper driving experience, and allow you to achieve the next-level ride control. Built for quick and easy installation, this kit consists of CAD designed components, which ensure a precise fit and comes with everything required for the successful install.
Rancho® RS66505B - 4.5" x 3.5" Front and Rear Suspension Lift Kit at CARiD.com
Notes:
* Max Tire Size: 37";
* Requires replacement Rancho shock absorbers and replacement wheels;
* Replacement front driveshaft may be required;
As usual, Greg is gonna go over every single aspect of this kit to provide you with the comprehensive review of the product. What's you'll get in a package, and what you don't, materials and even helpful installation tips are waiting for you, make sure to watch the complete overview to not to miss a single detail.
The Rancho lift kit includes:
* (1) Subframe (Part Number RS176880B)
* (1) Left 4.5" Knuckle (Part Number RS176753)
* (1) Right 4.5" Knuckle (Part Number RS176754)
* (1) Front Left Diff Drop Bracket (Part Number RS176881B)
* (1) Front Right Diff Drop Bracket (Part Number RS176882B)
* (1) Left Aft Diff Drop (Part Number RS176883B)
* (4) Cam Bolt Assembly (Part Number RS176578)
* (4) Hex Cam (Part Number RS176858)
* (2) Sway Bar Drop Bracket (Part Number RS176579)
* (1) Skid Plate (Part Number RS176884B)
* (1) Front Driveshaft Spacer (Part Number RS176586)
* (2) Front Brake Line Bracket (Part Number RS176780)
* (1) Rear Drive Shaft Spacer (Part Number RS176691)
* (4) U-Bolt 9/16-18 X 3.16 X 12 (Part Number RS740017)
* (2) Winged Spacer Block (Part Number RS15104)
* (1) Parking Brake Cable Drop (Part Number RS176748)
* (1) Rear Brake Hose Drop (Part Number RS176314)
* (1) Vent Hose (Part Number RS860749)
Installation Instructions: https://www.carid.com/images/rancho/items/pdf/rs66505b-installation-instructions.pdf
Experience an uncompromising safety, stability, and durability, no matter how crazy your off-road adventure is, with the 4.5" x 3.5" Front and Rear Suspension Lift Kit from Rancho.
More details on the manufacturer which you really can rely on when far off the trail can be found here: https://www.carid.com/rancho/
