Cam Caster Adjuster Kit
Helps make cam caster adjustments easy!
Caster is the angle at which the steering pivot axis is tilted either forward (negative) or rearward (positive) from the vertical or center position. Most conventional steering systems are designed with a positive caster angle to achieve good self-centering of the wheels while driving.
Alterations to the drive train such as installing a suspension lift or a simple level lift can cause the steering pivot axis and tire position to swing rearward making the castor negative resulting in potential wandering, wobble, pulling, stiff steering or even the inability to keep your truck on the road. Even larger tires can exaggerate the problem and require more positive castor.
By installing BD's Cam Caster Adjustor kit on the radius control arms of the Ford 2005-2010 Super Duty pick-ups, correcting the caster to a more positive angle is made easier. The Cam Caster Adjustor kit will help prevent a number of potential steering problems and have your rig driving straight again! Other adjustments such as camber may be out of specification therefore a proper alignment should be done as part of this installation.
http://www.dieselperformance.com/index.php/product/index/238P
