1 - 10 of 10 Posts
The Oracle
installed a new mech. fuel pump yesterday because i was having a problem with my Fp droping off idle....
new pump in and Fp is now steady but its seems low....
im getting 48 at idle 50 at cuise and 48 at full go pedal.....
shouldnt it be up in the high 50s?
is there a way to shim the regulator in the OBS trucks?
thanks guys
~Tim
You can install a bb in the FPR. I don't recall the exact way to do this. There is a excellent wright up on Steve Baze's web page. Someone will probly be along shortly to help you out.
The Oracle
can that be done on OBS trucks?
i was under the impression it was only for SD's
thanks
Ol Dirt Contractor
On the OBS you can change the regulator spring or shim it. We ran ours up to 70 psi ..
Fuel Pressure Regulator Spring
(International) 1823643-C1 (federal emissions; 94-98
(International) 1825854-C1 (CA emissions; engine serial no. 201681-98
The Oracle
Lowboy-- how do i go about shimming the regulator on my 97?
Ol Dirt Contractor
As you are looking down a the filter it’s under the large brass nut on the right (drivers) side.
Ford spring kit part # is: F6TZ-9K061-AA
The Oracle
ive had the regulator off before but ive never seen a spring..????
darryl just did this for me its as ur lookin down on the filter its a brass nut drivers side front of the filter just above the plug where an aftermarket fuel pres. gauge would go i believe it should have what looks like a pressure reader looks like an air stem on a tire
TDG MAFIA MEMBER #77
Place a rag under the FPR to make sure you don't lose any parts in the valley.
The Oracle
approx. how much will a BB up the pressure?
im at 48psi right now
thanks again
1 - 10 of 10 Posts
