I just received my new injectors,,, I hope to be putting them in this weekend.. They are whole injectors so it should not be to bad.. I got the 175 hp from DPS, they are Extrude Honed... Anyone have any numbers on hp.. I have a Comp box Aurora 5000 and I will have the new 175hp injectors... Hopefully it runs good.....
what fuel system are you running? and is it a comp or drag comp. there isn't a huge difference in power, maybe 20-30hp. My guess would be mid 400's to the wheels, depends on the dyno. You can always get close by calculating your ET's on the 1/4 so go back out and run the truck. Get it certified weighed as well, in the same trim that you are running it in, driver included. that will help you be more accurate in your calculations.
