LLROT
I was noticing some turbo lag and possible glow plug issues and wanted to look into it. Having little to no diesel engine experience, I got some help of some buddies. We pulled off the intake and I immediately saw oil in the line coming from the breather. I took the hot side off and it had some standing oil in it as well. I now know of the CCV mod and plan to execute it. I live in the south, so I doubt I'll have issues with the line freezing. My turbo definitely needs a rebuild or replacement. Trying to figure out what would be best. As well as if I need to mod anything else while I'm in there. My buddies work on diesels rather regularly and said my engine didn't look anywhere near 230,000 miles. Which made me feel better about the whole thing. Any ideas on what to do about the turbo and other mods there?
I am also considering re-gearing my differentials. How do I know what type of Dana 60 I have? I've heard of reverse and some other type. Now I don't know what to buy.
Are redheaded steering gears really worth that muh more money?
If I replace my power steering pump, should I change my brake booster as well?
LLROT
and what is best to clean up the engine bay?
LLROT
Gentlemen, I could really use some help and input. Thanks
Stuck in Commiefornia...
Cleanup can be accomplished with a variety of degreasers, Castrol Super Clean and Purple Power come to mind, and there are a variety of foaming spray degreasers available too. I've had good success mixing up about 2 cups of Tide powder in about a gallon of super hot water, then spray it down. The trick I prefer is using hot water for the wash, it lifts the oil and grease better than cold water.
Your truck should have tags on the axles, get the tag info and use it when you call a proper gear seller. There are advantages to going with guys like Randy's Ring & Pinion, they have specific data that can help identify transition year trucks like yours where you could have a Dana 50 or a Dana 60.
If you're serious about considering injectors and you're planning a turbo rebuild or replacement, upgrade to a Garrett GTP38R and call it good, the you're good to go with about any injector you'd like all the way up to a 250/200. The only problem you have is that with an '02 you have PMRs or Powdered Metal Rods, which most guys won't push past 400hp due to a high failure rate. You can push the PMRs farther but it's not a good idea if you like having a running truck.
My plan is to run a 38R with either 175/80 single shots, or 200/80 hybrids. The consideration for me is the ability to run any stock or readily available stock HPOP. Hybrids take significantly less oil volume than singles or split shots. The only drawback to a hybrid is the loss of injection pressure, peak attainable is only about 16,000psi vs 22,000psi, and with the larger nozzle the atomization quality is slightly lower. The thing they don't seem to do with 7.3 injectors that they do with 12-valves is increase the number of holes as well as alter the size to maintain better fuel atomization.
250/200s with a 38R will make 550hp+ pretty easily, the 200/80s will make 500hp pretty easily and 175/80s will make 450hp. With PMRS, you could de-tune 175/80s to make 400, but the temptation to make more can get you in trouble. A more appropriate choice would be a 160/30, it can make a bit over 400hp, but you'd have to try harder and push for it with your tuner. Also, the 160/30 can be run with a stock turbo and an upgraded compressor wheel and maybe the compressor cover.
With over 150k on the engine if you plan on injectors and turbo upgrades, you definitely need to do valve springs, and with valve springs you need to do pushrods. Being it's a PMR engine, you'll not need to do head studs or anything radical, you'll break a rod before you hurt a head gasket. And as long as the high pressure oil system is healthy, you should be in good shape, but if you end up with HPO codes after tuning or running injectors, you'll want to look into the IPR and possibly a fresh HPOP.
