Farmer how many miles are on your truck I haver a leak somewere on pasenger side I can see it leaking on the bottom of the block up front pasenger side Truck goes back in tuesday for repairs Axel U joints water leak lower control arm dif input seals both other than that truck run great
53-54,000 milesat the time. Leak was coming from area you describe. It was impossible to see where it was coming from as it was running down the block. I was not even able to get my fingers in to feel around to find the actual leak. At least it was under warrantee. There is a weep hole in the casting right next to one of the pumps mounting bolts, it was more like a groove between the pumps mounting flange and the block.
Hopefully Dodge has pumps in there inventory now as when mine was in there was only 5 pumps:thumbdown in the Dodge system, I was able to locate one faster from a cummins dealer and had my dealer order it from cummins instead of waiting for the mopar system to get it. Also it is not the same as the 5.9 engine. 6.7 uses a a higher volume and pressure pump.
I had a radiator shop tell me the orange long life antifreeze is c**P :fanand he recommends not going over 20k miles without changing it. The lubricants in it swells the seals and rubber hoses. He recommends going to the green stuff once the engine is out of warrantee. :happymugs
