We have sold over 100 Huspower Mufflers in the last couple of years, and not one dissatisfied customer. The fact still remains that this beauty of a muffler is quite expensive, and does not fit everyone's program.
FTE Diesel now has a new style of resonator / muffler for the Diesel Enthusiast. This unit is available in 4" and 5" and is affordable. We have tested this unit on 3 trucks so far....
  • 2005 CR with 5" Straight Pipe
  • 2001 24V with 4" Straight To Stacks
  • 1997 12V with 4" to single 7" Stack
All test trucks had a drone at highway cruise speed, this was the target. The 2005 CR was a customer living in an apartment complex who has upset neighbors.
One of the biggest issues with resonators is that they commonly use a batting material to deaden sound, as exhaust heat flows through them that material breaks down over time and the effectiveness is reduced / lost.
Our new designed resonator is a solid piece, it uses a corkscrew design which passes half of the exhaust straight through and the other half around the screw (twice the distance). No degregation of performance over time since this piece is made of steel and no Batting or fluff is used. There is very little backpressure, no significant egt gain, and the noise cancellation properties are awesome. It is not the Hushpower muffler, but it is the next best thing.
  • Easy install, eliminates drone
  • Fits any system, 5" Diameter with 12" Body
  • Solid 14 Gauge Aluminized Construction
  • Inexpensive compared to other options
In the test trucks above, all customers gladly paid retail after the tests. The Apartment neighbors claimed that the idle and warm up period of said customers truck was greatly improved once this unit was installed. Performance and Cummins Tone were still totally available.
Since our test trucks we have Duramax, Powerstroke, and Cummins testimonials that strengthen our case that this resonator is the answer to many diesel truck owners drone delema. Trucks with traditional out the back and Stacks see the same result since the noise is cancelled at the outlet of the resonator.
Bottom line, if your on a budget or too cool to install a muffler FTE Diesel is looking for cost effective solutions to improve your ownership experience of your Diesel Powered Truck. :thumbsup
Recently a customer of ours was kind enough to do a video write up of this product, Thanks Brett and you can see his info here:
Likewise, we are also a sponsor of another forum where cheap 16 gauge straight pipe exhaust kits are sold regularly.... we help hedge the effects of the low dollar kits with this resonator / muffler. There are many user testimonials that see great sound control from this product.
click here to read more
Always in stock..... 5" Stainless Steel is on the way for those of you that did not want to mix ALZ w/Stainless Stee
