So today I went by a yard and struck a deal on a complete but lightly damaged frame for $cheap$ and all the peripherals I needed to complete the OE donor parts set, except for the reaward brackets for the overload springs. I can buy the rear brackets from Ford for $60 for the pair, but I do t think they'll do me any good, because I've decided to order the PMF 3.5" Lift Rear Shackle Flip bracket. Paired with a 2" F-250 block, instead of the 3-3/4" F-350 block, I'll have 5.5" to go with the 6" coils that the extra weight of the 7.3 vs a 6.0 should make 5.5" coils.
I'm getting excited to do this swap. Once the suspension is done, I'm going to add a 6.0 transmission cooler, just because the bigger tires are going to create more heat in the transmission. Once the original small E99 cooler is out of the loop I'm going to repurpose it as a power steering cooler. Then it's on to cosmetics.
