So last night noticed my boost guage wasnt reading anything if 2-5# at the most.so today i looked over all the i/c piping the guage the line to the guage, so on and so forth.. Driving around and giving it you can hear the turbo spool but nothing. lots of smoke but no go??? TIA anything helps!!!
You probably have a cracked intercooler boot. Lets you build a tiny bit of boost, but blows off everything else.
Inspect all the boots and tighten. You have 2 on the Hot (driver's) side, 2 on the Cold (pass) side, and 2 orange ones under the Y-pipe tha feeds the cold air into the intake plenums.
Take a look behind the turbo for soot, like Joe said it could be up-pipes, but I'm inclinded to think intercooler boots if it happened "all of a sudden".
Thanks i'll look at them!!
check your intercooler out too. I have seen them crack before.
well looked over every thing.....Found that all but one of the bolts that hould the compresor shroud one gone. soo i took it off inspected the wheel and went got some more bolts anf loctite.. tightened backup and took a drive.20# like nothing.. found some another mod the boostube thing to the wastegate.. i guess its better than a blown turbo!!
