i have a 1994 idi turbo 7.3 when i crank it up it has oil pressure but get about mile down road and stop oil pressure drops to zero any ideas thanks
i would start by removing the oil sending unit,then the nipple extension that comes out of the engine block,the extension nipple has a habit of getting stopped up or restricted somewhat,atleast i hope you have only a small problem,good luck,also i would replace sending unit.
yeah that was the first thing i did but ill check the other too some one told me the spring in the oil cooler cap might have gottin weak u can put it in neutral and idle it up and the pressure goes back up like the oil pumps weak or something
