Got a question for you guys? Not to sure what is goin on with my truck, I got a shutter when braking just before I come to a complete stop. Also though I noticed it did the same thing at low speeds with no brakes applied. Could this be a sign that the trans could be on the way out or would it just be that the rotors are warp?:shrug:
TDG Mafia # 81
Check your front wheel bearings and both the idler and pitman arms for play. Most common parts to wear out and cause the symptoms, and also as you already stated, the rotors could have some warp to them.
Hope you find the problem,
Tony
is it possibly the tc or clutch packs not releasing in the trans?
