Heres the run down
82 big cam ntc400
0531 cpl
hx60 air-air
H&h rebuilt fuel pump with a .05 button and 2500 governer spring.
Im currently having a set of injectors opened up from a 195cc to a 275cc. Im concered that i might need to change out the cam key or reduce the timing. I know there are some big cam gurus here so im figured id ask for some advice.
The other guy
Heres the run down
82 big cam ntc400
0531 cpl
hx60 air-air
Road truck leave stock. Pullin truck advance .005". If front end is tight, use gaskets for the 005.
