OASIS RESULT:
1FTSF21P36EC91135
02/28/2008
21:42:12
FCXWS446
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 REG CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/25/2007 BUILD DATE
02/11/2006 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0994 - USA 2006 NEW 60/60,000 P'TRAINCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: . CHANDLER TRANSPORTATION
OPTIONS:
EXPIRATION DATE: 01/25/2012
DISTANCE: 60,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 40919
ESP CONTRACT START DATE: 01/25/2007
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
WARRANTY REPAIR HISTORY
01/28/2008
DEALER: Carson Ford, Inc.
WARRANTY CLAIM NUMBER: 005787 ODOMETER: 028466M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 005 9527AT 42 DOES NOT OPERATE PROPERLY
5C3Z 9A332A HOSE ASY (FUEL HIGH 002 6005E
WA 7SBA 003 6005E2
000 6005E3
000 6005E4
000 6005E5
000 6005E6
000 6005E7
000 6005E8
000 6005E45
000 VERIFY60
OASIS NO SSM OR TSB APPLYS--PERFOREM ENG SIAG STEPS NO START STEPS 1-9 ALSO PIN POINT TEST-REPLACE INJECTOR #8 ON LH BANK ALSO 1 3 5 7 ON RH BANK--ROAD TEST AFTER REPAIR OK--VEH TOWED IN
01/04/2008
WARRANTY CLAIM NUMBER: 005398 ODOMETER: 026730M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 9527AR 42 DOES NOT OPERATE PROPERLY
5C3Z 9A332A HOSE ASY (FUEL HIGH 001 6005E
000 6005E2
000 6005E3
000 6005E4
000 6005E5
000 6005E6
000 6005E7
000 6005E8
000 6005E45
000 VERIFY60
OASIS CK TSB'S NONE APPLICABLE--PERFORM DIAG HARD START-NO START STEPS 1 THR U 9 ALSO PINPOINT TEST--REPLACE #5 INJECTOR- ROAD TEST & CLEAR CODES
11/14/2007
WARRANTY CLAIM NUMBER: 004625 ODOMETER: 021195M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9A332A HOSE ASY (FUEL HIGH 001 12650D
W302725 001 12650DX1
WA 7SBA 002 12650D81
000 12650D82
OASIS PERFORMED EEC SCAN & NGS MONITOR TEST- PERFORMED PINPOINT & SIMULATION TEST-RETREIVE CODE--REPLACE #2 FUEL INJECTOR--RETEST & ROAD TEST OK
11/12/2007
WARRANTY CLAIM NUMBER: 004581 ODOMETER: 020943M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 003 9527AL 42 DOES NOT OPERATE PROPERLY
5C3Z 9A332A HOSE ASY (FUEL HIGH 001 6005F
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F33
000 VERIFY60
OASIS PERFORMED PERF DIAG STEPS PER DIAG 6.0 SHEET--STEPS 1 TRU 6 ALSO 33--R ETREIVE CODES --REPLACE 4 6 8 INJECTORS LH SIDE--ROAD TEST AFTER REPAIR OK
07/16/2007
WARRANTY CLAIM NUMBER: 002403 ODOMETER: 011067M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9A564A TUBE ASSY-FUEL RET 001 062302B 42 DOES NOT OPERATE PROPERLY
WA 7SBA 002 VERIFY60
6F089 ACTUATOR ASSY 000
ON ACCEL OASIS RETREIVE TSB 06-23-02 PERFORMED TURBO INSPECTION & PIN POINT EEC CODES--TURBO PASSEDINSPECTION,CLEANED,REINSTALLED-ROAD TEST OK
| On-line 1878
END OF OASIS REPORT FOR 1FTSF21P36EC91135
Standard Claims List For Model Year 2006
1FTSF21P36EC91135 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 11-FEB-2006 25-JAN-2007 153387 USA 6 2H02 030008 * 6F089 * D42 42 11067
AWS Claim Key: 4044726 Trx Code: S07 Labor Hrs: 7
Dlr Cd-Sub Cd: 20029 - * Name: CARSON FORD, INC. Ph: 217-3573154 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:16-JUL-2007 Doc #:00240301
Cust Comments: D42 CK ENGINE OPERATION VEH LACKS POWER
Tech Comments: ON ACCEL OASIS RETREIVE TSB 06 23 02 PERFORMED TURBO INSPECTION & PIN POINT EEC CODES TURBO PASSEDINSPECTION,CLEANED,REINSTALLED ROAD TEST OK
1FTSF21P36EC91135 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 11-FEB-2006 25-JAN-2007 153387 USA 10 2E03 030402 4C3Z 9E527 AA D42 42 20943
AWS Claim Key: 4932900 Trx Code: S07 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 20029 - * Name: CARSON FORD, INC. Ph: 217-3573154 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:12-NOV-2007 Doc #:00458101
Cust Comments: D42 VEH SLOW TO ACCELL NO POWER
Tech Comments: OASIS PERFORMED PERF DIAG STEPS PER DIAG 6.0 SHEET STEPS 1 TRU 6 ALSO 33 RETREIVE CODES REPLACE 4 6 8 INJECTORS LH SIDE ROAD TEST AFTER REPAIR OK
1FTSF21P36EC91135 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 11-FEB-2006 25-JAN-2007 153387 USA 10 2E03 030402 4C3Z 9E527 AA D42 42 21195
AWS Claim Key: 5023214 Trx Code: S07 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 20029 - * Name: CARSON FORD, INC. Ph: 217-3573154 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:14-NOV-2007 Doc #:00462501
Tech Comments: OASIS PERFORMED EEC SCAN & NGS MONITOR TEST PERFORMED PINPOINT & SIMULATION TEST RETREIVE CODE REPLACE #2 FUEL INJECTOR RETEST & ROAD TEST OK
1FTSF21P36EC91135 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 11-FEB-2006 25-JAN-2007 153387 USA 12 2E03 0304XX 4C3Z 9E527 AA D21 42 26730
AWS Claim Key: 5355391 Trx Code: S07 Labor Hrs: 5.4
Dlr Cd-Sub Cd: 20029 - * Name: CARSON FORD, INC. Ph: 217-3573154 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:04-JAN-2008 Doc #:00539801
Cust Comments: D21 TOW IN QUIT GOING DOWN ROAD CUST SEEKS ASSIST
Tech Comments: OASIS CK TSB'S NONE APPLICABLE PERFORM DIAG HARD START NO START STEPS 1 THRU 9 ALSO PINPOINT TEST REPLACE #5 INJECTOR ROAD TEST & CLEAR CODES
1FTSF21P36EC91135 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 11-FEB-2006 25-JAN-2007 153387 USA 13 2E03 0304XX 4C3Z 9E527 AA D21 42 28466
AWS Claim Key: 5485511 Trx Code: S07 Labor Hrs: 6.9
Dlr Cd-Sub Cd: 20029 - * Name: CARSON FORD, INC. Ph: 217-3573154 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:28-JAN-2008 Doc #:00578701
Cust Comments: D21 WEH WILL NOT START TOWED IN CUST UNHAPPY HAD PREVIOUS REPAIR
Tech Comments: OASIS NO SSM OR TSB APPLYS PERFOREM ENG SIAG STEPS NO START STEPS 1 9 ALSO PIN POINT TEST REPLACE INJECTOR #8 ON LH BANK ALSO 1 3 5 7 ON RH BANK ROAD TEST AFTER REPAIR OK VEH TOWED IN
