i just bought a 2007 F-350 6.0 39,000 miles noticed it already has a oil leak in back can i please get a Oasis report to see what i got myself into i greatly appreciate all your help and :)the hard work you do thank you much again.:) VIN #1FTWW31P47EA11103
OASIS RESULT: 1FTWW31P47EA11103 USA: EN 16-JANUARY-2013 / 06:23:37 EST/ APP1
Local Time: 16-JANUARY-2013 / 4:23:42 AM
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2007 F-SERIES
BODY STYLE: F-350 CREW CAB 4X4
ENGINE: 6.0L OHV Diesel V8
TRANSMISSION: 5 Speed Auto 5R110W - HI/Torque
AXLE CODE: 3L
ENGINE CALIBRATION: 6F710H0A
PAINT COLOR: Ebony WB C/C
PAINT CODE: UD
RADIO: AM/FM CD Changer/Clock
AXLE RATIO: 3.73 Ratio
WHEEL SIZE: 20X8 Prem Forged Polished Alum Whl
FRONT TIRE: LT275/65R 20E A/T OWL Tire
GROSS VEHICLE WEIGHT: 11,500 LB. GVW
CLAIMS:
Customer Concern Code D21-ENGINE STALLS
Condition Code 41-STICKS/BINDS/GRABS
Technician Comment 23030 VERIFY CONCERN, RUN EEC TEST P0299 IN PCM. DATALOGGER PID MONITOR WITH ROADTEST, FUEL PUMP PRESSURE TEST 56PSI, TURBO BOOST TEST, VVT TEST, INJECTOR TEST, POWER BALANCE. REMOVED TURBOCHARGER AND DISASSEMBLE FOR INSPECTION, FOUND UNISON RING FROZE AND CRACKED, AND TURBIN HOUSING PITTED. REPLACED COMPLETE TURBO ASSEMBLY AND EXHAUST CLAMPS, AND REVISED DRAIN TUBE. CLEAR CODES AND RETEST
Customer Comment D21 CUSTOMER STATES VEHICLE LACKS POWER ON ACCELERATION
Customer Concern Code E29-CHECK ENGINE LIGHT TROUBLE
Condition Code 42-DOES NOT OPERATE PROPERLY
Technician Comment 23030 VERIFY CONCERN RUN EEC TEST P02290 IN PCM MEMORY. PERFORM TSB# 08 18 6 LABOR OPS C, D, F . INSPECT HIGH PRESSURE OIL RAILS, D PLUGS, STANDPIPES AND INJECTORS OK. REMOVED HIGH PRESSURE PUMP COVER AND AIRTEST, FOUND STC FITTING LEAKING. REMOVED PUMP AND INSTALL REVISED STC BRACKET KIT. REINSTALL PUMP AND PRESSURE TEST OK. 580 PSI ICP PRESSURE CRANKING AND RUNNING AT
Customer Comment E29 CUSTOMER STATES CHECK ENGINE LIGHT STAYS ON PLEASE ADVSIE
