OASIS RESULT:
1FTSW21R58EA73704
USA
EN
06/28/2009
20:50:31
FCXWS447
© Copyright 2002-2009 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2008 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.4L TC DIESEL V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
8F716A0A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
Click here for CUDL
ARN MESSAGES
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/17/2007 BUILD DATE
03/29/2007 SALE MILEAGE
00345
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0968 - USA 2007 NEW 60/100000 PREMIUMCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 50 USD
OWNER NAME: RAYMOND ALEXANDER
OPTIONS: $50,DED.
EXPIRATION DATE: 09/17/2012
DISTANCE: 100,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 05471
ESP CONTRACT START DATE: 09/17/2007
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
06/08/2009
DEALER: Jim Burke Ford
WARRANTY CLAIM NUMBER: 262605 ODOMETER: 103879M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 9E527A NOZZLE ASY-FUEL INJE 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F2
000 6005F6
000 9527AL
000 6005F1X1
103899 #8 INJECTOR 0 CHECK FOR NO POWER,PERFORM SYSTEM PERFORMACNE TESTS,CE HCK CODES,P0128,P0231,P1558,P0208,P115A,P2291,CLEAR CODES,ROAD TEST,FOUND #8 INJECTOR FAULTY,DRAIN COOLANT,REMOE DE-GAS BOTTLE,FUEL COOLER,CROSSOVER TU BE ASSY,LEFT VALVE COVER,#8 INJECTOR,INSTALL NEW INJECTOR,REINSTALL VALVE C OVER,CROSSOVER TUBE ASSY,FUEL COOLER,DE- GAS BOTTLE,ADD COOLANT,RE-PROGRAM P
04/30/2009
WARRANTY CLAIM NUMBER: 259453 ODOMETER: 098227M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 9J559BA CONTROL ASY-ENG AIR 001 6089A 42 DOES NOT OPERATE PROPERLY
000 6005F
000 6005F1
000 6005F2
000 6005F6
000 6005F45
000 6005F1X1
000 MT6005F45
98258 TURBO ACTUATOR 0 CHECK FOR CHEKC ENGINE LIGHT ON,NO POWER ON ACCEL,PE RFORM SYSTEM PERFORMANCE TESTS,CHECK CODES,P132B,PERFORM PINPOINT TEST AK, AK1-YES,AK2-NO,AK-3-NO,AK-4 YES,AK5-NO,AK6-12.4 VOLTS,AK7-0.5 OHMS,AK8-PIN3 - PIN6 3 OHMS,PIN 4-PIN-PIN 14,3 OHMS,AK9-YES CONCERN STILL PRESENT,REMOVE TUBO ACTUATOR ASSY,INSTALL NEW ACTUATOR ,CLEAR CODES,ROAD
02/23/2009
WARRANTY CLAIM NUMBER: 253891 ODOMETER: 091242M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 6009A CYLINDER BLOCK 001 6005F 42 DOES NOT OPERATE PROPERLY
8C3Z 9G805AA KIT-CVR PMP FUEL 001 6005F1
3C3Z 6D083AA GASKET-RR COVER 001 6005F2
3C3Z 6701B CRANKSHAFT REAR SEAL 001 6005F6
8C3Z 6020D GASKET CYL TIMING GE 001 6005F10
8C3Z 9E933B GSKT-EGR TO-TH-BDY 001 6005F1X1
8C3Z 9E933A GSKT-EGR TO-TH-BDY 001 6007B
8C3Z 6N640B GASKET TURBO TO MANI 002 6007B1
8C3Z 6N640A GASKET TURBO TO MANI 002 MT6007
W302494 010
W302649 010
W302508 001
8C3Z 6A642A COOLER CRANKCASE OI 001
3C3Z 6731AA ELEMENT ASY OIL FILT 001
VC 7B 003
8C3Z 6079C GASKET SET-VALVE GRI 001
8C3Z 6019B COVER ASY-TIMING GEA 001
8C3Z 9229A GASKET CARB FUEL INL 008
8C3Z 6B041A DOWEL-CYL CVR PLATE 001
3C3Z 6766CA CAP ASY OIL FILLER 001
XT 5QMC 002
XO 15W40QSD 015
6500 TAPPET ASY 000
91250 LIFTERS 0 PERFORM SYSTEM PERFORMANCE TESTS,CHECK CODES,NO CODES,PERFO RM POWER BALANCE,ALL OK,PERFORM RELATIVE COMPRESSION,ALL OK,REMOVE CAB,REM OVE ENGINE ASSY,INSTALL ENGINE ONTO STAND,DISASSEMBLE ENGINE,FOUND LIFTERS FOR CYLS 1 AND 5 DAMAGED,FRONT COVER AND BASE OIL PUMP DAMAGED,INSTALL NEW SHORT BLOCK ONTO STAND,INSTALL NEW OIL COOLER DUE TO METAL
01/20/2009
WARRANTY CLAIM NUMBER: 251089 ODOMETER: 086341M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 6W651A HOS-ENG CHG AIR TUB 001 6646AC D8 FAILED GASKET/SEAL
6C3Z 6K786EA CLAMP AIR COOLING 001
6C3Z 6K786CA CLAMP AIR COOLING 001
86341 INTER COOLER TUBE 0 CHECK FOR INTER COOLER LEAKING,FOUND LOWER HOSE F ROM INTER COOLER TORN,REMOVE HOSE,INSTALL NEW HOSE AND CLAMPS,STEAM CLEAN,R OAD TEST,CEHCK FOR LEAKS
01/20/2009
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 8B379B GASKET SET RAD TANK 001 08B06B
86341 RECALL 0 PERFORM RECALL 08B06
01/20/2009
LABOR OP
CONDITION CODE
CONDITION DESC
000 08B07B
86341 RECALL PERFORM RECALL008B07
09/20/2008
WARRANTY CLAIM NUMBER: 241069 ODOMETER: 058257M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 8009B RADIATOR & SUPP ASY 001 8005D 42 DOES NOT OPERATE PROPERLY
8C3Z 8B379B GASKET SET RAD TANK 001 8005A
58264 RADIATOR PRESSURIZE COOLING SYSTEM,FOUND RADIATOR LEAKING,DRAIN COOLA NT,REMOVE INTER COOLER TUBES,P-S COOLER,TRANS COOLER,INTER COOLER,CROSSMEM BER,SHROUD,RADIATOR HOSES,RADIATOR,INSTALL NEW RADIATOR,REISNTALL SHROUD,HOS ES,ALL COOLERS,ADD COOLANT,ROAD TEST,CEHCK FOR LEAKS
09/20/2008
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 9F464D COOLER ASSY EGR RECI 001 9456AH 42 DOES NOT OPERATE PROPERLY
8C3Z 6N640B GASKET TURBO TO MANI 001
VC 7B 003
XO 15W40QSD 015
58271 HORIZONTAL EGR COOLER 0 CHECK FOR BLOWS SMOKE,FOUND LOW ON COOLANT,EN GINE HYDROLOCKEDREMOVE ALL GLOW PLUGS,CRANK ENGINE OVER TO REMOVE COOLANT F ROM CYLINDERS,REINSTALL GLOW PLUGS,FOUND COOLANT COMING OUT OF EXHAUST,DRAIN ALL FLUIDS,REMOVE CAB,TURBO DOWN PIPE,ALL EXHAUST PIPES,BOTH EGR COOLERS,B ENCH TEST EGR COOLERS,FOUND HORIZONTAL EGR COOLER LEAKING,INSTALL NEW
06/18/2008
WARRANTY CLAIM NUMBER: 232118 ODOMETER: 038802M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 9F479A MAP SENSOR 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F2
000 6005F6
000 6005F45
000 6005F1X1
000 12650D13
38810 MAP SENSOR 000 ENGINE PERFORMANCE DIAGNOSTICS,KOEO=PASS,CONT=P0106,KOE R=PASS,DCL DISPLAY: ALL READINGS ARE NORMAL,DCL RECORDER-MONITOR ROAD TEST: MAP SENSOR READING AT IDLE IS ERRATIC INTERMITTANTLY,PINPOINT TEST MAP SENS OR AND CIRCUITS,ALL CIRCUITS TEST GOOD,REPLACE MAP SENSOR (OUT OF RANGE),C LEAR CODES, ROAD TEST,RETEST:SYS PASS.
06/18/2008
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z25600A58C KIT - SEAT FASTENERS 001 08C01B
38810 RECALL 08C01 30 LINE B
ERFORM RECALL 08C01 INSTALL CLAMP KIT
06/18/2008
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 5D090A PLT FR RL BK FUL TNK 001 08C04B
38810 RECALL 08C04 90 LINE C
ERFORM RECALL 08C04 INSTALL FUEL TANK STOPPER BRACKET
1FTSW21R58EA73704 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 17-SEP-2007 171439 USA 6 1F01 030301 8C3Z 8009 B L87 42 20285
AWS Claim Key: 535754 Trx Code: E84 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 05471 - * Name: JIM BURKE FORD Ph: 661-3283600 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-FEB-2008 Doc #:220251A
Cust Comments: CUST STATES CK FOR RADIATOR LEAKING COOLANT ADVISE
Tech Comments: 20285 RADIATOR 000 PRESSURE TEST COOLING SYSTEM,FOUND RADIATOR LEAKING AT RIGHT TANK SEAL, REPLACE RADIATOR ASSY.,REPLENISH COOLING SYSTEM AND RETEST FOR LEAKS,OK AT THIS TIME.
1FTSW21R58EA73704 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 17-SEP-2007 171439 USA 10 6E01 * * * * * * 38802
AWS Claim Key: 1061597 Trx Code: 08C01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05471 - * Name: JIM BURKE FORD Ph: 661-3283600 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-JUN-2008 Doc #:232118B
Cust Comments: 08C01 C R AWARENESS COMMUNICATION C 2008 M Y F 250 F 550 S D V E 40 20 40 F S L F D S B
Tech Comments: 38810 RECALL 08C01 30 LINE B
1FTSW21R58EA73704 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 17-SEP-2007 171439 USA 10 2E02 * * * * * * 38802
AWS Claim Key: 1095871 Trx Code: 08C04 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 05471 - * Name: JIM BURKE FORD Ph: 661-3283600 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-JUN-2008 Doc #:232118C
Cust Comments: C 2008 M Y F 250 F 350 4X4 10,000 LBS AND UNDER GVW, 156 WHEEL BASE V E T P D S F T S B I
Tech Comments: 38810 RECALL 08C04 90 LINE C
1FTSW21R58EA73704 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 17-SEP-2007 171439 USA 10 2G02 031403 8C3Z 9F479 A D42 42 38802
AWS Claim Key: 1053255 Trx Code: S07 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 05471 - * Name: JIM BURKE FORD Ph: 661-3283600 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-JUN-2008 Doc #:232118A
Cust Comments: CUST STATES CK FOR NO POWER ON ACCEL ADVISE CK ENGINE LIGHT COMES ON AT TIMES
Tech Comments: 38810 MAP SENSOR 000 ENGINE PERFORMANCE DIAGNOSTICS,KOEO PASS,CONT P0106,KOER PASS,DCL DISPLAY: ALL READINGS ARE NORMAL,DCL RECORDER MONITOR ROAD TEST:MAP SENSOR READING AT IDLE IS ERRATIC INTERMITTANTLY,PINPOINT TEST MAP SENSOR AND CIRCUITS,ALL CIRCUITS TEST GOOD,REPLACE MAP SENSOR (OUT OF RANGE),CLEAR CODES, ROAD TEST,RETEST:SYS PASS.
1FTSW21R58EA73704 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 17-SEP-2007 171439 USA 13 1F01 030301 8C3Z 8009 B L87 42 58257
AWS Claim Key: 1649763 Trx Code: 0968D Labor Hrs: 2.7
Dlr Cd-Sub Cd: 05471 - * Name: JIM BURKE FORD Ph: 661-3283600 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2008 Doc #:241069A
Cust Comments: CUST STATES CK FOR COOLANT LEAK ADVISE
Tech Comments: 58264 RADIATOR PRESSURIZE COOLING SYSTEM,FOUND RADIATOR LEAKING,DRAIN COOLANT,REMOVE INTER COOLER TUBES,P S COOLER,TRANS COOLER,INTER COOLER,CROSSMEMBER,SHROUD,RADIATOR HOSES,RADIATOR,INSTALL NEW RADIATOR,REISNTALL SHROUD,HOSES,ALL COOLERS,ADD COOLANT,ROAD TEST,CEHCK FOR LEAKS
1FTSW21R58EA73704 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 17-SEP-2007 171439 USA 13 1H03 030804 8C3Z 9F464 D L87 42 58257
AWS Claim Key: 1649764 Trx Code: S07 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 05471 - * Name: JIM BURKE FORD Ph: 661-3283600 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2008 Doc #:241069B
Cust Comments: CUST STATES CK FOR ROUGH IDLE,BLOWS BLUE SMOKE AND CK ENGINE LIGHT ON ADVISE
Tech Comments: 58271 HORIZONTAL EGR COOLER 0 CHECK FOR BLOWS SMOKE,FOUND LOW ON COOLANT,ENGINE HYDROLOCKEDREMOVE ALL GLOW PLUGS,CRANK ENGINE OVER TO REMOVE COOLANT FROM CYLINDERS,REINSTALL GLOW PLUGS,FOUND COOLANT COMING OUT OF EXHAUST,DRAIN ALL FLUIDS,REMOVE CAB,TURBO DOWN PIPE,ALL EXHAUST PIPES,BOTH EGR COOLERS,BENCH TEST EGR COOLERS,FOUND HORIZONTAL EGR COOLER LEAKING,INSTALL NEW
1FTSW21R58EA73704 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 17-SEP-2007 171439 USA 17 2A01 031202 8C3Z 6W651 A L65 D8 86341
AWS Claim Key: 2649719 Trx Code: E72 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 05471 - * Name: JIM BURKE FORD Ph: 661-3283600 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN-2009 Doc #:251089C
Cust Comments: CUST STATES CK FOR INNER COOLER LEAKING ADVISE
Tech Comments: 86341 INTER COOLER TUBE 0 CHECK FOR INTER COOLER LEAKING,FOUND LOWER HOSE FROM INTER COOLER TORN,REMOVE HOSE,INSTALL NEW HOSE AND CLAMPS,STEAM CLEAN,ROAD TEST,CEHCK FOR LEAKS
1FTSW21R58EA73704 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 17-SEP-2007 171439 USA 17 1F01 * * * * * * 86341
AWS Claim Key: 2849848 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05471 - * Name: JIM BURKE FORD Ph: 661-3283600 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN-2009 Doc #:251089E
Cust Comments: RECALL 08B06 COOLING SYSTEM VENTURI TEE
Tech Comments: 86341 RECALL 0 PERFORM RECALL 08B06
1FTSW21R58EA73704 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 17-SEP-2007 171439 USA 17 2G01 * * * * * * 86341
AWS Claim Key: 2649720 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 05471 - * Name: JIM BURKE FORD Ph: 661-3283600 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN-2009 Doc #:251089F
Cust Comments: RECALL 08B07 RECALIBRATION
Tech Comments: 86341 RECALL PERFORM RECALL008B07
1FTSW21R58EA73704 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 17-SEP-2007 171439 USA 18 1C01 030902 * 6500 * N11 42 91242
AWS Claim Key: 3140702 Trx Code: E72 Labor Hrs: 31.1
Dlr Cd-Sub Cd: 05471 - * Name: JIM BURKE FORD Ph: 661-3283600 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2009 Doc #:253891A
Cust Comments: CUST STATES CK FOR ENGINE KNOCK ADVISE
Tech Comments: 91250 LIFTERS 0 PERFORM SYSTEM PERFORMANCE TESTS,CHECK CODES,NO CODES,PERFORM POWER BALANCE,ALL OK,PERFORM RELATIVE COMPRESSION,ALL OK,REMOVE CAB,REMOVE ENGINE ASSY,INSTALL ENGINE ONTO STAND,DISASSEMBLE ENGINE,FOUND LIFTERS FOR CYLS 1 AND 5 DAMAGED,FRONT COVER AND BASE OIL PUMP DAMAGED,INSTALL NEW SHORT BLOCK ONTO STAND,INSTALL NEW OIL COOLER DUE TO METAL
1FTSW21R58EA73704 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 17-SEP-2007 171439 USA 20 2E03 030008 8C3Z 9J559 BA E29 42 98227
AWS Claim Key: 3473157 Trx Code: E72 Labor Hrs: 4
Dlr Cd-Sub Cd: 05471 - * Name: JIM BURKE FORD Ph: 661-3283600 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-APR-2009 Doc #:259453A
Cust Comments: CUST STATES CK ENGINE LIGHT ON,VEH LACKS POWER ON ACCEL 0 40 MPH AND AT HIGHWAY SPEEDS TRYING TO PASS ADVISE
Tech Comments: 98258 TURBO ACTUATOR 0 CHECK FOR CHEKC ENGINE LIGHT ON,NO POWER ON ACCEL,PERFORM SYSTEM PERFORMANCE TESTS,CHECK CODES,P132B,PERFORM PINPOINT TEST AK,AK1 YES,AK2 NO,AK 3 NO,AK 4 YES,AK5 NO,AK6 12.4 VOLTS,AK7 0.5 OHMS,AK8 PIN3 PIN6 3 OHMS,PIN 4 PIN PIN 14,3 OHMS,AK9 YES CONCERN STILL PRESENT,REMOVE TUBO ACTUATOR ASSY,INSTALL NEW ACTUATOR ,CLEAR CODES,ROAD
1FTSW21R58EA73704 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 29-MAR-2007 17-SEP-2007 171439 USA 22 2E03 030402 8C3Z 9E527 A D42 42 103879
AWS Claim Key: 3811828 Trx Code: W32 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 05471 - * Name: JIM BURKE FORD Ph: 661-3283600 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:08-JUN-2009 Doc #:262605A
Cust Comments: CUSTOMER STATES THAT THE VEHICLE WILL NOT RUN OVER 25 MPH AND RPMS WONT GO OVER 1800 PLEASE CHECK AND ADVISE
Tech Comments: 103899 #8 INJECTOR 0 CHECK FOR NO POWER,PERFORM SYSTEM PERFORMACNE TESTS,CEHCK CODES,P0128,P0231,P1558,P0208,P115A,P2291,CLEAR CODES,ROAD TEST,FOUND #8 INJECTOR FAULTY,DRAIN COOLANT,REMOE DE GAS BOTTLE,FUEL COOLER,CROSSOVER TUBE ASSY,LEFT VALVE COVER,#8 INJECTOR,INSTALL NEW INJECTOR,REINSTALL VALVE COVER,CROSSOVER TUBE ASSY,FUEL COOLER,DE GAS BOTTLE,ADD COOLANT,RE PROGRAM PCM TO NEWEST
