Standard Claims List For Model Year 2008
1FTWW31R68EC80772 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 02-NOV-2007 15-APR-2008 4B6229 CAN 1 2G04 000615 * DIAG * E29 42 2677
AWS Claim Key: 823051 Trx Code: 2 Labor Hrs: 0.9
Dlr Cd-Sub Cd: B6205 - * Name: RODEO FORD SALES LIMITED Ph: 403-5292777 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:06-MAY-2008 Doc #:152215A
Cust Comments: CHECK & ADVISE CHECK ENGINE LIGHT IS ONE
Tech Comments: 4319 CGHECK & HAS MEMORY CODE P2263 & PASSES RUNING TESTS.CHECK OASIS & SSM 20160 FR THIS CODE.ENGINEERING IS INVESTIGATING AT THIS TIME & NO REPAIR.
1FTWW31R68EC80772 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 02-NOV-2007 15-APR-2008 4B6229 CAN 1 1F03 030304 8C3Z 8590 A L87 42 3212
AWS Claim Key: 865231 Trx Code: 2 Labor Hrs: 1.3
Dlr Cd-Sub Cd: B6205 - * Name: RODEO FORD SALES LIMITED Ph: 403-5292777 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:12-MAY-2008 Doc #:152375A
Cust Comments: CHECK & ADVISE VEHICLE IS LEAKING ANTI FREEZE, VEHICLE LEFT HERE MAY 8TH AND WE FOUND NOTHING, CHECK HISTORY
Tech Comments: 5170 UPPER RAD HOSE O RING IS LEAKING PRESSURE TEST COOLING SYSTEM REMOVE UPPER RAD HOSE AND REPLACE LEAKING O RING TOP UP COOLANT RETEST PASS.
1FTWW31R68EC80772 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 02-NOV-2007 15-APR-2008 4B6229 CAN 2 2E03 030008 8C3Z 9J559 BA D50 42 7108
AWS Claim Key: 1136091 Trx Code: 2 Labor Hrs: 3.7
Dlr Cd-Sub Cd: B6205 - * Name: RODEO FORD SALES LIMITED Ph: 403-5292777 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:09-JUN-2008 Doc #:153012A
Cust Comments: CHECKAND ADVISE TURBO APPEARS TO KICK OUT SOMETIMES.
Tech Comments: 11440 ORDERED TURBO ACTUATOR CHECK & HAD P132A & 2263.CHECK WIRING & LINKAGE AS PER HOT LINE & WAS OK REPLACE ACTUATOR & RETEST & WAS OK MT WAS USED FOR THE WIRING AND LINKAGE CHECK THAT TECH HOTLINE HAD TECH PERFORM
1FTWW31R68EC80772 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 02-NOV-2007 15-APR-2008 4B6229 CAN 8 7W07 000301 7L2Z 19G365 AA D02 42 12356
AWS Claim Key: 2189541 Trx Code: ACCC Labor Hrs: 1.5
Dlr Cd-Sub Cd: B6229 - * Name: HARWOOD FORD SALES LTD Ph: 403-3626900 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:14-NOV-2008 Doc #:02076601
Cust Comments: PLEASE REPAIR PLEASE REPAIR FACTORY REMOTE START
Tech Comments: DIAG NO START REPLACED FAULTY BYPASS MODULE
1FTWW31R68EC80772 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 02-NOV-2007 15-APR-2008 4B6229 CAN 10 1F01 * * * * * * 13820
AWS Claim Key: 2640593 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: A6035 - * Name: BIG M FORD LINCOLN LTD. Ph: 403-5274406 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:28-JAN-2009 Doc #:14622803
Cust Comments: PERFORM RECALL 08B06
Tech Comments: INSTALLED T KIT AS PER RECALL
1FTWW31R68EC80772 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 02-NOV-2007 15-APR-2008 4B6229 CAN 10 2E02 * * * * * * 13820
AWS Claim Key: 2640591 Trx Code: 08B03 Labor Hrs: 0.9
Dlr Cd-Sub Cd: A6035 - * Name: BIG M FORD LINCOLN LTD. Ph: 403-5274406 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:28-JAN-2009 Doc #:14622801
Cust Comments: PERFORM RECALL 08B03
Tech Comments: INSTALLED FUEL TANK STOPPER BRACKET
1FTWW31R68EC80772 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 02-NOV-2007 15-APR-2008 4B6229 CAN 10 2G01 * * * * * * 13820
AWS Claim Key: 2640592 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: A6035 - * Name: BIG M FORD LINCOLN LTD. Ph: 403-5274406 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:28-JAN-2009 Doc #:14622802
Cust Comments: PERFORM RECALL 08B07
Tech Comments: REPROGRAM PCM AND IC AS PER RECALL
1FTWW31R68EC80772 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 02-NOV-2007 15-APR-2008 4B6229 CAN 12 1D05 031001 8C3Z 6753 A L65 D8 15469
AWS Claim Key: 3411281 Trx Code: E84 Labor Hrs: 1.9
Dlr Cd-Sub Cd: B6205 - * Name: RODEO FORD SALES LIMITED Ph: 403-5292777 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:02-APR-2009 Doc #:159602A
Cust Comments: CHECK AND ADVISE FOR OIL LEAK
Tech Comments: 24897 6753 CHECKED FOR OIL LEAK WITH BLACK LIGHT AND FOUND OIL DIPSTICK TUBE LEAKING AT O RING SEAL SO I ORDERED NEW SEAL FROM EDMONTON. I REMOVED ENGINE OIL DIPSTICK AND REPLACED O RING SEAL THEN CLEANED OFF AREA AND RECHECHECK.OK
1FTWW31R68EC80772 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 02-NOV-2007 15-APR-2008 4B6229 CAN 18 7W07 000301 * 19G365 * D02 42 25183
AWS Claim Key: 4567560 Trx Code: ACCC Labor Hrs: 1.1
Dlr Cd-Sub Cd: B6080 - * Name: METRO FORD SALES LIMITED Ph: 403-2634530 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:30-SEP-2009 Doc #:395928A
Cust Comments: COMMAND START INOPERATIVE..ONE REMOTE WILL BEEP FOUR TIMES, AND SECOND ONE WILL FLASH THEFT LIGHT CODE 14..SOP IN STOCK
Tech Comments: VERIFIED CONCERN. TESTED SYSTEM AND FOUND THE THEFT LIGHT FLASHING. TRIED RE PROGRAM OF PATS MODULE AND DID NOT WORK. TESTED THE POWER AND GROUND WIREFROM MODULE ON START UP AND BOTH ARE OK. REPLACED THE PATS INTERFACE MODULE AND PROGRAMMED. REMOTE START WORKING CORRECTLY.
1FTWW31R68EC80772 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 02-NOV-2007 15-APR-2008 4B6229 CAN 25 7W07 000301 7L3Z 19A498 AA L20 42 31560
AWS Claim Key: 5834856 Trx Code: ACCC Labor Hrs: 1.1
Dlr Cd-Sub Cd: B6080 - * Name: METRO FORD SALES LIMITED Ph: 403-2634530 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:14-APR-2010 Doc #:406134A
Cust Comments: REMOTE NOT WORKING SAME ISSUE AS LAST TIME
Tech Comments: VERIFIED REMOTE START NOT WORKING. FOUND THE THEFT LIGHT FLASHING. TRIED RE PROGRAM OF THE PATSINTERFACE KIT AND IT DID NOT WORK. TESTED THE POWER AND GROUND SUPPLY FOUND NO GROUND SUPPLY ON REMOTE START UP REQUEST. REPLACED THE DNA CHIP FOR THE REMOTE MODULE. RE PROGRAMMED SYSTEM AND RE TESTED. REMOTE START WORKING CORRECTLY.
1FTWW31R68EC80772 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 02-NOV-2007 15-APR-2008 4B6229 CAN 28 7H11 120305 7C3Z 19972 D C05 42 36395
AWS Claim Key: 6281387 Trx Code: E83 Labor Hrs: 2
Dlr Cd-Sub Cd: B6080 - * Name: METRO FORD SALES LIMITED Ph: 403-2634530 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:21-JUL-2010 Doc #:411590B
Cust Comments: CHECK AND ADVISE ON A C NO LONGER BLOWING COLD AIR
Tech Comments: 58573 THE HIGH SIDE LINE GOING INTO THE CONDENSER LEAKS FREON & NEEDS TO BE REPLACED. REMOVE & REINSTALL AFTERMARKET AIR SHUT OFF KIT FOR ACCESS. REPLACE HIGH SIDE LINE INTO THE CONDENSER. A C SERVICE. (EVAC & RECHARGE) AFTER. ADDED OIL CHARGE & USED 1 LB 11 OZ OF R 134A FREON. A C SERVICE.19700A. 0.7 HRS. REPLACE LINE. 19700A25C. 0.3 HRS. ADD 1.0 HRS. (ACTUAL TIME) TO REMOVE &
1FTWW31R68EC80772 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 02-NOV-2007 15-APR-2008 4B6229 CAN 29 7W07 190102 8L3Z 19G365 BA L20 42 37158
AWS Claim Key: 6352654 Trx Code: ACCC Labor Hrs: 1
Dlr Cd-Sub Cd: B6080 - * Name: METRO FORD SALES LIMITED Ph: 403-2634530 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:10-AUG-2010 Doc #:412616A
Cust Comments: CHECK AND ADVISE FOR REMOTE NOT WORKING. WORKED THE DAY AFTER REPAIRS, BUT WONT START THE VEHICLE NOW
Tech Comments: VERIFEID REMOTE START NOT WORKING. INSPECT AND FOUND THE THEFT LIGHT FLASHING. TRIED A RE PROGRAM OFTHE PATS SYSTEM AND IT DID NOT TAKE. TEST THE POW ER AND GROUND SUPPLY FROM REMOTE START MODULE TO PATS KIT AND BOTH OK. REPLACED THE PATS INTERFACE MODULE AND WIRING. RE PROGRAM THE PATS INTERFACE. RE TEST AND REMOTE START WORKING CORRECTLY.
