1FTSW20P15EB21386
THANKS !!!
Just bought it a week ago. Would like to see the PO history. Carfax says one owner out of Odessa, Tx.....
Shawn
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION TORQSHIFT
AXLE CODE 3L
ENGINE CALIBRATION
PAINT COLOR OXFORD WHITE WB C/C-W/B RADIO
AM/FM STRO/CD CHANGER/CLK GROSS VEHICLE WEIGHT
9800 LB. GVW
AXLE RATIO
3.73 FINAL DRIVE RATIO
WHEEL SIZE 8X18" FRGD POLSH ALU WHL SYT 2 FRONT TIRE
LT 275/65R 18E BSW A/S
Standard Claims List For Model Year 2005
1FTSW20P15EB21386 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 08-NOV-2004 02-MAY-2005 152451 USA 0 6X04 010904 4C3Z 17D743 CAA M05 33 4
AWS Claim Key: 206082 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02622 - * Name: SYKORA FAMILY FORD, INC. Ph: 254-8265314 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2004 Doc #:09261551
Cust Comments: DRIVERS OUTSIDE MIRROR OUTER SHELL IS LOOSE.
Tech Comments: FASTENER FAILURE DEFECT REMOVE & REPLACE MIRROR COVER
1FTSW20P15EB21386 T/F7 F T/BC T/BD T/B A1 T/BE T/YB 08-NOV-2004 02-MAY-2005 152451 USA 10 * * * * * * * 9676
AWS Claim Key: 3704127 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 03080 - * Name: PILOT POINT FORD Ph: 940-6862236 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2006 Doc #:03917840
Cust Comments: 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM A
Tech Comments: RECALL EP SENSOR, CONNECTOR, AND RECALIBRATION
AWS Claim Key: 3704128 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03080 - * Name: PILOT POINT FORD Ph: 940-6862236 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2006 Doc #:03917841
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: RECALL 59B01
AWS Claim Key: 3704129 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03080 - * Name: PILOT POINT FORD Ph: 940-6862236 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2006 Doc #:03917842
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: RECALL COOLANT DEGAS BOTTLE LABEL INSTALLATION AND COOLANT LEVEL AD
