Mine is a happy 2007 6.0L, my brother is looking at a 2006, Vin 1FTSW21P96EB32992 , Assistance appreciated, Thanks
Standard Claims List For Model Year 2006
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 0 5O01 110200 * 3504 * H21 07 106
AWS Claim Key: 1698765 Trx Code: 2 Labor Hrs: 3
Dlr Cd-Sub Cd: 00015 - * Name: COWLES PARKWAY FORD, INC. Ph: 703-9865500 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:26-AUG-2006 Doc #:19344201
Cust Comments: CUSTOMER STATES THAT THE STEERING WHEEL SEEMS LOOSE WHEN DRIVING AT HIGHWAY SPEEDS
Tech Comments: WARR ROAD TESTED AND VERIFIED THE CONCERN PERFORMED NVH EVA TEST PERFORMED PINPOINT TEST AND FOUND THAT THE STEERING GEAR BOX HAD PLAY IN IT R AND R THE AIR FILTER AND TUBES TO GAIN ACCESS TO THE TOP OF THE GEAR BOX ADJUSTED THE GEAR BOX AND BALANCE ALL TIRES.
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 2 5H02 050101 EOTZ 4A209 A N51 42 1789
AWS Claim Key: 1863745 Trx Code: 2 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 00015 - * Name: COWLES PARKWAY FORD, INC. Ph: 703-9865500 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:29-SEP-2006 Doc #:19622602
Cust Comments: WHEN TOWING AND TAKING OFF FROM A STOP OR WITH THE BED LOADE D YOU CAN FEEL A VIBRATION
Tech Comments: TSB 05 17 06 CODE 051706C ROAD TESTED TO VERIFY CONCERN CONSULTED OASIS AND FOUND TSB FOR THE DRIVELINE VIBRATION INSTALLED ONE SHIM TO LOWER THE DRIVELINE ANGLE ROAD TESTED AND THE VIBRATION WAS STILL THERE INSTALLED A SECOND SHIM AND REROAD TEST STILL HAD A SLIGHT VIBRATION INSTALLED A THIRD SHIM AND ROAD TESTED AGAIN AND VIBRATION WAS STILL THERE
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 2 5G05 040001 * FRONT * N25 W6 1789
AWS Claim Key: 1863746 Trx Code: 2 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 00015 - * Name: COWLES PARKWAY FORD, INC. Ph: 703-9865500 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:29-SEP-2006 Doc #:19622601
Cust Comments: CHECK FOR THE STEERING WHEEL VIBRATING WHEN HITTING BUMPS AT 40MPH PLUS
Tech Comments: TSB 06 15 1 CODE 061501C ROAD TESTED AND VERIFIED THE CONCERN SET THE PSI PER TSB REROAD TESTED AND THE VIBRATION WAS STILL THERE TORQUED ALL OF THE FRONT STEERING AND SUSPENSION COMPONENTS AND CHECKED THE STEERING STABILIZER, IT WAS NOT LEAKING, HAD TO INSTALL TWO NEW CASTER ADJUSTERS AND LOWERED THE CASTER .5 DEGREE ON BOTH SIDES SET THE CAMBER AND TOE ALSO REROAD TESTED OKAY
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 2 6F02 011103 F81Z 2521452 AA B66 34 1794
AWS Claim Key: 2205098 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: 00015 - * Name: COWLES PARKWAY FORD, INC. Ph: 703-9865500 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:04-OCT-2006 Doc #:19657603
Cust Comments: CUSTOMER STATES FRONT WINDOWS ARE SCRATCHING ON OUTSIDE
Tech Comments: REPLACE BOTH DOOR BELT MOULDINGS AND DRIVERS SIDE GLASS
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 17 7S02 180102 * 14401 * L15 X2 16935
AWS Claim Key: 5423071 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 10019 - * Name: MALLOY LINCOLN MERCURY OF MANASSAS Ph: 703-6311181 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:29-DEC-2007 Doc #:10158503
Cust Comments: CHECK FOR THE POWER DOOR LOCK NOT WORKING ON THE PASSANGER FRONT DOOR
Tech Comments: 1 VERIFIED THE CONCERN CHECKED THE FUSES AND THEY WERE GOOD R AND R BOTH FRONT DOOR SWITCH BEZELS AND FOUND THAT THE DRIVERS LOCK SWITCH HAD POWER TO IT BUT THE PASSANGER SWITCH DID NOT CONSULTED OASIS AND FOUND NO MESSAGES PERTAINING TO THIS CONCERN HOOKED UP THE IDS AND TESTED THE VEHICLE SECURITY MODULE AND FOUND NO CODES GAINED ACCESS
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 17 7M81 150301 8C3Z 18808 A A06 42 16935
AWS Claim Key: 5354478 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 10019 - * Name: MALLOY LINCOLN MERCURY OF MANASSAS Ph: 703-6311181 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:29-DEC-2007 Doc #:10158501
Cust Comments: CHECK FOR THE DRIVERS FRONT SPEAKER CRACKLING
Tech Comments: CODE 42 VERIFIED THE CONCERN R AND R THE DRIVERS FRONT DOOR PANEL AND REPLACED THE SPEAKER
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 17 7N02 011108 6C3Z 2523201 BC G07 41 16935
AWS Claim Key: 5354477 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 10019 - * Name: MALLOY LINCOLN MERCURY OF MANASSAS Ph: 703-6311181 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:29-DEC-2007 Doc #:10158502
Cust Comments: CHECK FOR BOTH FRONT WINDOWS MAKING A CREAKING NOISE WHEN THEY GO ALL THE WAY UP
Tech Comments: NOISY WINDOW REGULATORS CODE 42 VERIFIED THE CONERN R AND R BOTH FRONT DOOR PANELS AND LUBED THE WINDOW REGULATOR TRACKS WITH TEFLON GREASE OPERATED THE WINDOWS UP AND DOWN NUMEROUS TIMES TO WORK IN THE GREASE BUT THE NOISE WAS STILL THERE REMOVED BOTH WINDOW REGULATORS AND INSTALLED NEW REGULATORS REINSTALLED EVERYTHING AND RECHECKED THE NOISE IS NOW GONE
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 19 2C01 030603 6C2Z 11002 AA D02 42 19565
AWS Claim Key: 5761107 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 10019 - * Name: MALLOY LINCOLN MERCURY OF MANASSAS Ph: 703-6311181 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:14-MAR-2008 Doc #:10225501
Cust Comments: CHECK FOR A LOUD NOISE FROM THE STARTER AREA WHEN STARTING
Tech Comments: FOUND STARTER MAKING THE NOISE BUT FLYWHEEL WAS NOT DAMAGED REPLACED THE STARTER AND RECHECKED NOISE GONE NOW
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 22 6Q05 011901 * 17D957 * N59 33 21209
AWS Claim Key: 6626532 Trx Code: E84 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 10019 - * Name: MALLOY LINCOLN MERCURY OF MANASSAS Ph: 703-6311181 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:12-JUN-2008 Doc #:10316201
Cust Comments: CHECK FOR A SQUEAKING NOISE WHEN DRIVING OVER BUMPS AT ANY SPEEDS OVER 5MPH AND ON ROUGH ROADS OR SPEED BUMPS
Tech Comments: FRONT BUMPER BRACKETS LOOSE AT FRAME CONDITION CODE 33 ROAD TESTED AND VERIFIED THE CONCERN HOOKED UP THE CHASSIS EARS AND PERFORMED EVA TEST TRACED IT DOWN TO THE FRONT BUMPER AREA FOUND THE BOLTS HOLDING THE BUMPER BRAKETS ON TO THE FRAME WERE SLIGHTLY LOOSE RETORQUED THE BOLTS AND REROAD TESTED TO VERIFY REPAIR
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 22 7T03 050300 6C3Z 2C204 BA H19 42 21209
AWS Claim Key: 6626531 Trx Code: E83 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 10019 - * Name: MALLOY LINCOLN MERCURY OF MANASSAS Ph: 703-6311181 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:12-JUN-2008 Doc #:10316206
Cust Comments: CHECK AND ADVISE WHY THE ABS LIGHT IS COMING ON CONCERN CODE H19
Tech Comments: CONDITION CODE 42 TESTED THE ABS SYSTEM FOUND CODES C1145 C1234 PERFORMED PINPOINT TEST AND FOUND THE RIGHT FRONT SPEED SENSOR BAD REPLACED THE SENSOR AND RETESTED OKAY NO MORE CODES
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 35 3A15 070100 5C3Z 7G391 C P69 41 31873
AWS Claim Key: 8464956 Trx Code: S07 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 10019 - * Name: MALLOY LINCOLN MERCURY OF MANASSAS Ph: 703-6311181 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2009 Doc #:10731003
Cust Comments: WHEN THE TRANSMISSION UPSHIFTS INTO THIRD GEAR IT SEEMS TO SLIP AT TIMES AND ALSO GETTING A BANGING AT 20MPH ON DOWNSHIFTS
Tech Comments: STICKING VALVE IN THE VALVE BODY CONCERN CODE P69 CONDITION CODE 41 ROAD TESTED AND VERIFIED THE CONCERN TESTED THE TRANS CONTROL MODULE AND FOUND NO CODES PERFORMED THE PINPOINT TEST PER THE SYMPTOM CHART FOUND THAT ONE OF THE VALVES IN THE VALVE BODY WAS STICKING, R AND R THE TRANS PAN AND INSTALLED THE NEW VALVE BODY REFILLED THE PAN WITH FLUID AND REPROGRAMMED THE PCM TCM ROAD TESTED AND THE
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 35 6E01 0110XX 8C3Z 1565501 A S06 01 31873
AWS Claim Key: 8464957 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 10019 - * Name: MALLOY LINCOLN MERCURY OF MANASSAS Ph: 703-6311181 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2009 Doc #:10731002
Cust Comments: CHECK FOR REASON THAT THE DRIVERS SEAT LUMBAR DOES NOT PUMP UP WHEN YOU MANUALY TURN THE LUMBAR KNOB
Tech Comments: CONCERN CODE S06 CONDITION CODE 01 VERIFIED THE CONCERN R AND R THE SEAT BACK COVER WHILE THE SEAT WAS OUT FOR THE REPAIR ON LINE 01 AND INSTALLED THE NEW LUMBAR ASSEMBLY RECHECKED AND IT IS WORKING FINE NOW
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 35 6P07 010301 F81Z 2523552 AA N40 69 31873
AWS Claim Key: 8464954 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 10019 - * Name: MALLOY LINCOLN MERCURY OF MANASSAS Ph: 703-6311181 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2009 Doc #:10731005
Cust Comments: CHECK AND ADVISE ON A CLUNKING CLICKING TYPE NOISE WHEN OPENING AND CLOSING THE DRIVERS FRONT DOOR
Tech Comments: CONCERN CODE N40 CONDITION CODE 69 FOUND THAT THE DRIVERS FRONT DOOR CHECK HINGE WAS MAKING THE NOISE R AND R THE FRONT DOOR PANEL AND INSTALLED THE NEW CHECK HINGE, RECHECKED AND THE DOOR IS OPERATING QUITELY NOW
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 35 5R01 07XXXX * 7326 * P51 07 31873
AWS Claim Key: 8464955 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 10019 - * Name: MALLOY LINCOLN MERCURY OF MANASSAS Ph: 703-6311181 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2009 Doc #:10731004
Cust Comments: WHEN SHIFTING FROM PARK TO DRIVE OR PARK TO REVERSE ON FLAT GROUND THERE IS A CLUNK NOISE WHEN TAKING OFF AT FIRST FROM A STOP AND IT ALSO SEEMS LIKE THE SHIFTER LINKAGE IS OUT OF
Tech Comments: CONCERN CODE P01 CONDITION CODE 07 VERIFIED THE CONCERN CHECKED AND FOUND THAT THE SHIFT CABLE WAS SLIGHTLY OUT OF ADJUSTMENT, ADJUSTED THE CABLE AND RECHECKED IT IS SHIFTING SMOOTHLY NOW
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 35 6N07 010801 6C3Z 8200 BA B62 81 31873
AWS Claim Key: 8464953 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 10019 - * Name: MALLOY LINCOLN MERCURY OF MANASSAS Ph: 703-6311181 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2009 Doc #:10731006
Cust Comments: CHECK FOR REASON THAT THE CHROME IS PEELING OFF THE PASSANGER FRONT DOOR EMBLEM AND ALSO THE TAIL GATE EMBLEM AND THE CHROME ON THE TOP OF THE GRILLE IS FADING
Tech Comments: CONCERN CODE B62 CONDITION CODE 81 INSTALLED A NEW EMBLEM ON THE RF DOOR AND THE TAIL GATE ALSO INSTALLED A NEW GRILLE AND FORD EMBLEM
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 35 6E01 0110XX 2C3Z 25632A23 AA S03 63 31873
AWS Claim Key: 8464958 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 10019 - * Name: MALLOY LINCOLN MERCURY OF MANASSAS Ph: 703-6311181 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2009 Doc #:10731001
Cust Comments: CHECK FOR REASON THAT THE DRIVERS SEAT BOTTOM CUSHION IS SITTING LOW ON ONE SIDE VERSUS THE OTHER
Tech Comments: CONCERN CODE S03 CONDITION CODE 63 VERIFIED THE CONCERN R AND R THE DRIVERS FRONT SEAT AND REMOVED THE SEAT BOTTOM COVER INSTALLED A NEW CUSHION AND RECHECKED IT IS FINE NOW
1FTSW21P96EB32992 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2005 29-AUG-2006 127048 USA 49 2E03 031403 4C3Z 12B599 ABRM E29 42 49972
AWS Claim Key: 9362421 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 05322 - * Name: MALLOY FORD Ph: 540-6674434 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:01-SEP-2010 Doc #:671650A
Cust Comments: CUSTOMER STATES THE CHECK ENGINE LIGHT IS ON
Tech Comments: FOUND FICM INTERNALLY FAILED REPLACED AND RECHECKED
Reactions: baldone
