TDG MAFIA MEMBER #77
Looking at a 2006 F350 with aprox 34k on the clock.
Vin: 1FTWW31PX6EA66573
Thanks!
Standard Claims List For Model Year 2006
1FTWW31PX6EA66573 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-JUL-2005 18-OCT-2006 156023 USA 0 * * * * * * * 43
AWS Claim Key: 313289 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03028 - * Name: WILLEY FORD LINCOLN MERCURY Ph: 801-2924433 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:13-JAN-2006 Doc #:57866901
Cust Comments: GUEST REQUESTS: RECALL 05E16 TO BE DONE. (RECALIBRATION)
Tech Comments: 1 987685 RECALIBRATE PER RECALL
AWS Claim Key: 313288 Trx Code: 05B34 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03028 - * Name: WILLEY FORD LINCOLN MERCURY Ph: 801-2924433 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:13-JAN-2006 Doc #:57866902
Cust Comments: GUEST REQUESTS: RECALL 05B34 TO BE DONE. (TIRE INSPECTION)
Tech Comments: 1 987685 INSPECT ONLY
1FTWW31PX6EA66573 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-JUL-2005 18-OCT-2006 156023 USA 28 5A11 0502XX F81Z 4630 AA N12 42 20758
AWS Claim Key: 7734999 Trx Code: E84 Labor Hrs: 4.4
Dlr Cd-Sub Cd: 03028 - * Name: WILLEY FORD LINCOLN MERCURY Ph: 801-2924433 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:15-JAN-2009 Doc #:62389901
Cust Comments: GUEST STATES: THERE IS A ROTATIONAL NOISE (HEARS IT AT 60 MPH) CHECK AND ADVISE.
Tech Comments: 1 DIAG NOISE IN VEHICLE.REPLACE PINION BRGS,4205A,4205A6 5055
1FTWW31PX6EA66573 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-JUL-2005 18-OCT-2006 156023 USA 30 5V01 060301 7C3Z 1104 B N50 82 22051
AWS Claim Key: 8000724 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 08379 - * Name: ED KENLEY FORD INC Ph: 801-7764201 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:12-MAR-2009 Doc #:76926201
Cust Comments: CHECK AND ADVISE OF GRINDING WHEN TURNING FROM LEFT FRONT AXLE. T FRONT AXLE. T FRONT AXLE.
Tech Comments: TEST DRIVE VERIFIED A NOISE W/CUSTOERM, REPLACED RIGHT FRONT WHEEN BRG HUB ASSY. RETEST GOOD. NOW ONLY HEARD IS TIRES.
1FTWW31PX6EA66573 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-JUL-2005 18-OCT-2006 156023 USA 36 5V01 060301 7C3Z 1104 B N12 42 24974
AWS Claim Key: 8641768 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 03028 - * Name: WILLEY FORD LINCOLN MERCURY Ph: 801-2924433 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:30-SEP-2009 Doc #:00317101
Cust Comments: LIGHT LINE GUEST STATES: THERE IS A ROTATIONAL NOISE FROM THE FRONT END. SOUNDS LIKE A BEARING GOING OUT. HEARS IT MORE FROM THE LEFT SIDE. CHEC
Tech Comments: CHECKED AND FREPLACED THER LH FRONT WHEEL BEARING ASSEMBLY. PEROFMREDQUALITY CHECK. JP1626
1FTWW31PX6EA66573 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-JUL-2005 18-OCT-2006 156023 USA 36 6N04 010807 5C3Z 9942528 CA B66 01 24974
AWS Claim Key: 8641769 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03028 - * Name: WILLEY FORD LINCOLN MERCURY Ph: 801-2924433 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:30-SEP-2009 Doc #:00317102
Cust Comments: LIGHT LINE GUEST STATES: REAR EMBLEM HAS PAINT COMING OFF OF IT. CHECK AND ADVISE.
Tech Comments: INSTALLED THE EMBLEM. JP1626
1FTWW31PX6EA66573 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-JUL-2005 18-OCT-2006 156023 USA 39 5G05 040001 * FRONT * C50 W6 26665
AWS Claim Key: 8820154 Trx Code: P18 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 03028 - * Name: WILLEY FORD LINCOLN MERCURY Ph: 801-2924433 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:23-DEC-2009 Doc #:00619603
Cust Comments: ALIGNMENT PERFORM ALIGNMENT SERVICE
Tech Comments: CP: FRONT 1.0H 3596 FRONT END ALIGNMENT AFTER TIEROD REPLACEMENT.
