I turn my own wrenches
Oasis please - Ford F-350 VIN: 1FTWW31R88EC20072
Looking to purchase an off-lease field service truck from my company.
OASIS RESULT: 1FTWW31R88EC20072
USA: EN-US
22-JULY-2011 / 23:49:29 / FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2008 F-SERIES BODY STYLE: F-350 CREW CAB 4X4 ENGINE: 6.4L TC DIESEL V8
TRANSMISSION: TORQSHIFT AXLE CODE: 3L ENGINE CALIBRATION: 8F716A0A
PAINT COLOR: OXFORD WHITE WB C/C-W/B RADIO: ELETR PREM AM/FM STRO/DISC GROSS VEHICLE WEIGHT: 11,400 LB. GVW
AXLE RATIO: 3.73 FINAL DRIVE RATIO WHEEL SIZE: 8 X 18" PREM CHROME STEEL WHL FRONT TIRE: LT 275/70R18E A/T OWL
WARNING MESSAGES
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
ACCURATE REPAIR NOTIFICATIONS
TO ENSURE OPTIMUM COOLING SYSTEM PREFORMANCE, REFER TO 09-08-05
FOR DTC P040D SEE 11-06-15
FOR RADIATOR COOLANT LEAKS SEE 11-06-06
GENERAL WARRANTY INFORMATION
New Vehicle Base Warranty
WARRANTY START DATE: 18-JULY-2008 BUILD DATE: 31-AUGUST-2007 SALE MILEAGE
11B23 POWERTRAIN CONTROL MODULE RECALIBRATION
11S19 CONTINENTAL TIRE INSPECTION - CANADA
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTWW31R88EC20072 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-AUG-2007 18-JUL-2008 4B6080 CAN 0 2E02 * * * * * * 6
AWS Claim Key: 1092456 Trx Code: 08B03 Labor Hrs: 0.9
Dlr Cd-Sub Cd: B6080 - * Name: METRO FORD SALES LIMITED Ph: 403-2634530 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:26-JUN-2008 Doc #:372744B
Cust Comments: RECALL:INSTALL FUEL TANK STOPPER BRACKET
Tech Comments: 10 INSTALL FUEL STOPPER BRACKET RECALL .9HR 271
1FTWW31R88EC20072 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-AUG-2007 18-JUL-2008 4B6080 CAN 1 5K07 040401 8C2Z 1A189 A A40 42 22
AWS Claim Key: 1212899 Trx Code: 1 Labor Hrs: 0.4
Dlr Cd-Sub Cd: B6080 - * Name: METRO FORD SALES LIMITED Ph: 403-2634530 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:21-JUL-2008 Doc #:374064C
Cust Comments: TIRE WARNING LIGHT ON
Tech Comments: REPLACED FAULTY TIRE WARNING SENSOR.
1FTWW31R88EC20072 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-AUG-2007 18-JUL-2008 4B6080 CAN 9 1F01 * * * * * * 19630
AWS Claim Key: 3289097 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B6190 - * Name: BOUNDARY FORD SALES LTD. Ph: 780-8727755 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:02-APR-2009 Doc #:02934703
Cust Comments: D DISEL MAINT PERFORM RECALL 08B06 VENTURI TEE
Tech Comments: INSTALL VENTURI AS PER RECALL.
AWS Claim Key: 3373960 Trx Code: 08B06 Labor Hrs: 2.7
Dlr Cd-Sub Cd: B6190 - * Name: BOUNDARY FORD SALES LTD. Ph: 780-8727755 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:02-APR-2009 Doc #:02934701
Cust Comments: D DIESEL ENGINE & CONT. DIAG AND REPORT CUST SAYS LOST ALL HEAT WHILE DRIVING YESTER DAY DID NOT ADD ANY ANTIFREEZE (RAD??)
Tech Comments: COOLING SYSTEM PRESSURE TEST/ REPLACED RADIATOR ASSY AND RETEST/OK
1FTWW31R88EC20072 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-AUG-2007 18-JUL-2008 4B6080 CAN 9 2G01 * * * * * * 19630
AWS Claim Key: 3289096 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B6190 - * Name: BOUNDARY FORD SALES LTD. Ph: 780-8727755 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:02-APR-2009 Doc #:02934702
Cust Comments: D RECALLS PERFORM RECALL 08B07 REPROGRAM PCM & INSTRUMENT CLUSTER
Tech Comments: REFLASH MODULES AS PER RECALL.
1FTWW31R88EC20072 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-AUG-2007 18-JUL-2008 4B6080 CAN 17 1H03 030804 8C3Z 9D475 D D42 42 42887
AWS Claim Key: 4905482 Trx Code: S07 Labor Hrs: 3.3
Dlr Cd-Sub Cd: B6258 - * Name: PEACE RIVER FORD SALES INC. Ph: 780-6243450 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:08-DEC-2009 Doc #:068157A
Cust Comments: INSPECT FOR CEL ON IN DASH AND VEH LACKING THROTTLE RESPONSE
Tech Comments: TEST FOR CODES,P0404,P1335.KOEO P0404.EGR VP STUCK IN 28%.ATTEMPT TO OPEN VALVE WITH SCAN TOOL,VALVE STUCK.USED TOOL 303 1267 TO REMOVE VALVE.TOOL BROKE.ATTEMPT TO WIGGLE VALVE OUT,VALVE STUCK IN MIXING BOWL BORE.REPLACED MIXING & EGR VALVE.CLEARED EGR TABLES & ALL CODES. RD TEST & RETEST,OK.
1FTWW31R88EC20072 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-AUG-2007 18-JUL-2008 4B6080 CAN 18 1G01 030305 * 8575 * C04 69 46016
AWS Claim Key: 5056916 Trx Code: E72 Labor Hrs: 3.1
Dlr Cd-Sub Cd: B6258 - * Name: PEACE RIVER FORD SALES INC. Ph: 780-6243450 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:05-JAN-2010 Doc #:068639A
Cust Comments: INSPECT FOR UNIT BLOWING COLD AIR ALL THE TIME
Tech Comments: 74074 NO HEAT CHECK FOR NO HEAT, TEMPERATURE NOT GOING UP, MONITOR PIDS TEMP STAYIN BELOW 120 DEG F. REPLA CE THERMOSTAT AND RETEST OK.
1FTWW31R88EC20072 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-AUG-2007 18-JUL-2008 4B6080 CAN 20 5A09 0502XX 1L3Z 4676 A L88 D8 49943
AWS Claim Key: 5258729 Trx Code: E95 Labor Hrs: 1.4
Dlr Cd-Sub Cd: B6258 - * Name: PEACE RIVER FORD SALES INC. Ph: 780-6243450 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:08-FEB-2010 Doc #:069252A
Cust Comments: INSPECT FOR REAR PINION SEAL LEAKING
Tech Comments: 80377 VERIFIED CUST CONCERN FOR REAR PINION LEAKING. FOUND THAT THEV SEAL WAS AT FAULT.REPLACED SEAL ROAD TESTED GOOD.
1FTWW31R88EC20072 T/F7 F T/BC T/CD T/E A1 T/BE T/QL 31-AUG-2007 18-JUL-2008 4B6080 CAN 27 2G02 130101 * 9278 * L65 D8 70360
AWS Claim Key: 6739543 Trx Code: E72 Labor Hrs: 0.9
Dlr Cd-Sub Cd: B6258 - * Name: PEACE RIVER FORD SALES INC. Ph: 780-6243450 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:24-SEP-2010 Doc #:073429A
Cust Comments: UNIT TOWED IN. INSPECT FOR OIL LEAK
Tech Comments: 113241 INSPECT FOR AN OIL LEAK. FOUND OIL LEAKING DOWN THE REAR OF THE ENGINE. WASHED ENGINE AND ADDED OIL. RECHECKED AND FOUND THE OIL PRESSURE SWITCH LEAKING. REMOVED AND REPLACED THE SWITCH AND FILLED WITH OIL. STEAMED THE ENGINE AND RECHECKED FOR LEAKS. NO OTHER LEAKS FOUND. FAXED DOCUMENTS.ATTN; 912
