Smokin
my vin is 1ftsw21p86ea56696.
I would like to see this
OASIS RESULT:
1FTSW21P86EA56696
07/27/2006
23:55:01
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
6F710D0A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/30/2005 BUILD DATE
06/27/2005 SALE MILEAGE
00512
ARN MESSAGES
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-14-06
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
05/22/2006
DEALER: Rountree Ford, L.L.C.
WARRANTY CLAIM NUMBER: 748654 ODOMETER: 019236M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 8200BA RADIATOR GRILLE 001 8200A 81 TARNISHED/FADED
REPLACE PEELING GRILLE
03/10/2006
WARRANTY CLAIM NUMBER: 739392 ODOMETER: 017538M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 16720VA PLATE,NAME 002 999A 81 TARNISHED/FADED
VERIFIED PAINT PEELING ON EMBLEM NAME PLATES REPLACED NAME PLATE EMBLEMS
03/10/2006
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 8200AAA RADIATOR GRILLE 001 8200A 81 TARNISHED/FADED
VERIFIED CHROME PEELING OFF OF FRONT GRILLE REPLACED GRILLE
03/10/2006
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z28422B30AA WDO KIT SLIDG BK 001 42006A 41 STICKS/BINDS/GRABS
VERIFIED MOTOR IN OP REMOVED INTERIOR TRIM SEAT BELTS TO REPLACE SLIDING BACK GLASS
03/10/2006
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 19980AA CONTROL A/C 001 19700A 42 DOES NOT OPERATE PROPERLY
000 19980A
EATC DIAG PINPOINT TEST REPLACE EATC CONTROL ASY RETEST
03/10/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 05E16B
1 PERFORM RECALL 05E16 RECALL PCM
03/10/2006
LABOR OP
CONDITION CODE
CONDITION DESC
9OO2 04567561120 002 05B34C
RECALL 05B34 INSPECT TIRES AND REPLACE TWO FRONT TIRES PER RECALL
03/10/2006
LABOR OP
CONDITION CODE
CONDITION DESC
YC3Z 13A613BA LAMP ASY RR HI MOUNT 001 13613A 68 SEALER MISSING/SKIPPED
VERIFIED LEAK HSG NOT SEALED REPLACED HIGH MOUNT BRAKE LIGHT ASSY
12/06/2005
DEALER: Wray Ford, Inc.
WARRANTY CLAIM NUMBER: 093329 ODOMETER: 011600M
LABOR OP
CONDITION CODE
CONDITION DESC
F6DZ 8100A CAP ASY RADIATOR 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F11
000 6005F12
000 6005F13
000 8100A
FAILED 8100 CC--42 RAN ENGINE PERFORANCE TEST 1--13 ALSO PERSSURE TEST COO LANT SYSTEM 19 PSI LET IT SIT OVER NIGHT-IN THE MORNING 17PSI NO LEAKS REPLA CED COOLANT BOTTLE CAP TEST DROVE 10 MILES RETEST ALL SYSTEMS PASSED
12/06/2005
LABOR OP
CONDITION CODE
CONDITION DESC
3504 GEAR ASY-STEERING 000 052201A 42 DOES NOT OPERATE PROPERLY
PERFORM TSB 05=22-1 052201A 052201H 3600 42
10/14/2005
WARRANTY CLAIM NUMBER: 090912 ODOMETER: 007648M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9942528DA PLATE-LUGG COMPT T G 001 999A 81 TARNISHED/FADED
CODE 81. LETTERING ON NAMEPLATE FADING. INSPECTED AND REPLACED TAILGATE N AMEPLATE.
END OF OASIS REPORT FOR 1FTSW21P86EA56696
Standard Claims List For Model Year 2006
1FTSW21P86EA56696 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JUN-2005 30-AUG-2005 123038 USA 2 6N04 010807 5C3Z 9942528 DA B66 81 7648
AWS Claim Key: 87796 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06554 - * Name: WRAY FORD, INC. Ph: 318-6867300 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:14-OCT-2005 Doc #:09091202
Cust Comments: F 250 BADGE ON TAILGATE PEELING
Tech Comments: CODE 81. LETTERING ON NAMEPLATE FADING. INSPECTED AND REPLACED TAILGATE NAMEPLATE.
1FTSW21P86EA56696 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JUN-2005 30-AUG-2005 123038 USA 4 1F06 030304 F6DZ 8100 A L87 42 11600
AWS Claim Key: 216311 Trx Code: 2 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 06554 - * Name: WRAY FORD, INC. Ph: 318-6867300 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:06-DEC-2005 Doc #:09332902
Cust Comments: C S BLOWING COOLANT OUT OF BOX. HAS BLOWN ALL OVER MOTOR
Tech Comments: FAILED 8100 CC 42 RAN ENGINE PERFORANCE TEST 1 13 ALSO PERSSURE TEST COOLANT SYSTEM 19 PSI LET IT SIT OVER NIGHT IN THE MORNING 17PSI NO LEAKS REPLACED COOLANT BOTTLE CAP TEST DROVE 10 MILES RETEST ALL SYSTEMS PASSED
1FTSW21P86EA56696 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JUN-2005 30-AUG-2005 123038 USA 4 5O01 110200 * 3504 * C50 42 11600
AWS Claim Key: 216310 Trx Code: 2 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 06554 - * Name: WRAY FORD, INC. Ph: 318-6867300 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:06-DEC-2005 Doc #:09332903
Cust Comments: C S HITS BUMP STEERING WHEEL SHAKES BAD AND HE HAS NO CONTROL OF VEHICLE
Tech Comments: PERFORM TSB 05 22 1 052201A 052201H 3600 42
1FTSW21P86EA56696 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JUN-2005 30-AUG-2005 123038 USA 7 6N04 010802 5C3Z 16720 VA B66 81 17538
AWS Claim Key: 671081 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2006 Doc #:73939202
Cust Comments: CHECK F250 EMBLEMS PEELING
Tech Comments: VERIFIED PAINT PEELING ON EMBLEM NAME PLATES REPLACED NAME PLATE EMBLEMS
1FTSW21P86EA56696 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JUN-2005 30-AUG-2005 123038 USA 7 6N07 010801 6C3Z 8200 AAA B66 81 17538
AWS Claim Key: 671080 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2006 Doc #:73939203
Cust Comments: CHECK GRILL CHROME COMING OFF
Tech Comments: VERIFIED CHROME PEELING OFF OF FRONT GRILLE REPLACED GRILLE
1FTSW21P86EA56696 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JUN-2005 30-AUG-2005 123038 USA 7 6H08 011105 6C3Z 28422B30 AA G07 41 17538
AWS Claim Key: 671079 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2006 Doc #:73939204
Cust Comments: CHECK REAR POWER SLIDING WINDOW IS DRAGGING
Tech Comments: VERIFIED MOTOR IN OP REMOVED INTERIOR TRIM SEAT BELTS TO REPLACE SLIDING BACK GLASS
1FTSW21P86EA56696 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JUN-2005 30-AUG-2005 123038 USA 7 7H12 12XXXX 6C3Z 19980 AA C20 42 17538
AWS Claim Key: 671078 Trx Code: E83 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2006 Doc #:73939205
Cust Comments: CHECK AC WOULD NOT WORK AT TIMES ....NO LIGHTS ON CONTROLER
Tech Comments: EATC DIAG PINPOINT TEST REPLACE EATC CONTROL ASY RETEST
1FTSW21P86EA56696 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JUN-2005 30-AUG-2005 123038 USA 7 * * * * * * * 17538
AWS Claim Key: 671077 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2006 Doc #:73939208
Cust Comments: AFFECTED VEH IDENTIFIED IN OASIS. SOME OF THE AFFECTED VEH THE ON BOARD DIAG SYS MAY NOT PROPERLY MONITOR PERFORMANCE
Tech Comments: 1 PERFORM RECALL 05E16 RECALL PCM
1FTSW21P86EA56696 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JUN-2005 30-AUG-2005 123038 USA 7 5K04 * * * * * * 17538
AWS Claim Key: 671076 Trx Code: 05B34 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2006 Doc #:73939210
Cust Comments: CONTINENTAL TIRE HAS INITIATED A RECALL TO REPLACE CERTIAN TIRES WHICH MAY NOT COMPLY WITH FEDERAL MTR VEH SAFETY
Tech Comments: RECALL 05B34 INSPECT TIRES AND REPLACE TWO FRONT TIRES PER RECALL
1FTSW21P86EA56696 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JUN-2005 30-AUG-2005 123038 USA 7 7D06 170301 YC3Z 13A613 BA L25 68 17538
AWS Claim Key: 671075 Trx Code: E83 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2006 Doc #:73939211
Cust Comments: THIRD BRAKE LIGHT IS HOLDING WATER
Tech Comments: VERIFIED LEAK HSG NOT SEALED REPLACED HIGH MOUNT BRAKE LIGHT ASSY
1FTSW21P86EA56696 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 27-JUN-2005 30-AUG-2005 123038 USA 9 6N07 010801 6C3Z 8200 BA B66 81 19236
AWS Claim Key: 1027173 Trx Code: E90 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06450 - * Name: ROUNTREE FORD, L.L.C. Ph: 318-7983673 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:22-MAY-2006 Doc #:74865401
Cust Comments: CHECK GRILL IS PEELING..........
Tech Comments: REPLACE PEELING GRILLE
